SFSDT-10-28-G-03.25-DR-NDX
    SAMTEC(申泰)
    .050(1.27)SOCKETDISCRETECABL
SFSDT-10-28-G-03.25-DR-NDX 数据手册
(1.27 mm) .050" PITCH • DISCRETE WIRE ASSEMBLY/COMPONENTS - SERIES - POSITIONS PER ROW SFSD –03, –04, –05, –07, –10, –15, –20, –25, –40, –50 = Double Row PVC Cable SFSDT –28 Board Mates: TFM, TFC (–SR & –DR requires –WT option) SPECIFICATIONS Insulator Material: Black LCP Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Current Rating: 2.9 A per pin (2 pins powered) Operating Temp Range: -10 °C to +80 °C (PVC) -40 °C to +125 °C (*Teflon®) Voltage Rating: 275 VAC (PVC) 235 VAC (*Teflon®) Wire: 28 or 30 AWG –G –28C PIN COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN VIOLET GRAY WHITE BLACK BLUE REPEAT - No. of Positions x (1.27) .050 + (0.38) .015 END OPTION = Single Ended –D = Double Ended For –(X) specify “S” for single ended and “D” for double ended. Assembled Length ± (3.18) .125 - POSITIONS PER ROW - –03, –04, –05, –07, –10, –15, –20, –25, –40, –50 ROW OPTION - –D –M = Double Row = Metal Retention Latch (Standard sizes) –S No. of Positions x (1.27) .050 + (0.38) .015 = Screw Down –NDX = Notch down, crossed (Pin 1 to Pin 1) Notes: Teflon® cable is intended for crimp only. Contact Samtec for solderable cable applications. SFSD OR SFSDT SERIES OPTION –NUX *DuPont™ Teflon® is a registered trademark of the E.I. du Pont de Nemours and Company or its affiliates. End 2 notch location determined by part number –D–NUS –NDS = Notch up, crossed (Pin 1 to Pin N) (11.18) .440 –SR –NUS = Notch up, straight (Pin 1 to Pin N-1) –(X)S = Screw Down (Not available in -03, -04 & -50 positions) (Mates with TFM-DS option) (6.35) .250 Requires –D, –DS, –DR (End 1 Notch Up) = Notch down, straight (Pin 1 to Pin 2) = Retention Latch (TFM-WT option required for mating) End 1 Notch (Always Up) END 2 OPTION –(X)R For wiring option information refer to drawings on web. View complete specifications at: samtec.com?SFSD & samtec.com?SFSDT ISDF - –S = Assembled Length in Inches (76.20 mm) 03.00" min. for –S end option (82.60 mm) 03.25" min. for –D end option –30 = 30 AWG ASSEMBLED LENGTH –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Gold Flash on balance = Color Coded Cable (SFSD only) –28C CABLE COLOR CODING SFSD(T) - PLATING OPTION = 28 AWG (Standard sizes) = Double Row Blue *Teflon® Cable - WIRE GAUGE CC03R = Contact, Full Reel (35,000 Parts per Reel) - WIRE GAUGE - 01 - PLATING –2830 –GF = 28 to 30 AWG CC03M = Gold flash contact –G = Contact, Mini Reel (1,000 - 5,000 Parts per Reel) = 10 µ" (0.25 µm) Gold on contact (6.35) .250 (11.18) .440 (15.37) .605 (6.32) .249 (3.81) .150 –D –M –S TOOLING Hand Tool: CAT-HT-203-2830-12 Mini Applicator: CAT-MC-203-2830-XX-01 Clamp for mounting hand tool: CAT-HT-MNT-01 Extraction Tool: CAT-EX-169-01 Note: Some lengths, styles and options are non-standard, non-returnable. View complete specifications at: samtec.com?ISDF, samtec.com?CC03R & samtec.com?CC03M samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
SFSDT-10-28-G-03.25-DR-NDX 价格&库存
很抱歉,暂时无法提供与“SFSDT-10-28-G-03.25-DR-NDX”相匹配的价格&库存,您可以联系我们找货
97-3106B36-10SY-417
  • 1+127.103281+15.90563
  • 10+117.5737610+14.71312
  • 25+83.7784425+10.48399
库存:165
