SM278-1/2
SM278-1/2"
    DABURNELECTRONICS
    HEATSHRINK DUAL WALL BLK 1/2"X4'
SM278-1/2" 数据手册
Daburn Electronics & Cable 44 Richboynton Road Dover, NJ 07849 Daburn SM278 Shrinkable Polyolefin Tubing - Flexible, Dual Wall Description: DAFLEX SM278 is a flexible, large ratio, heat shrinkable tubing with a meltable adhesive liner. When 120°C is applied, the tubing will shrink to 25% of its supplied size (4:1). Longitudinal shrinkage is 10% maximum. As the outer wall shrinks, the inner adhesive liner melts and flows. When cooled, it offers protection for a variety of electrical applications as well as "sealed-in" protection from chemicals and oils. Because of its large shrink ratio and adhesive liner, it offers excellent protection for cable repairs and retrofitting. Operating Temperature: -55°C to +135°C. Meets or exceeds MIL-I-23053/4 Class 3. UL VW-1, CSA OFT (outer wall only). This series is RoHS II, EU Directive 2011/65/EU compliant. Shelf Life is 3 years. Daburn Cat. No. Nom. Size Expanded ID Recovered ID Min. Rec. Wall IN. mm IN. mm IN. mm Standard Put-Up SM278-3/16 3/16 .157 4 .039 1 .0354 .90 200ft Spl* SM278-5/16 5/16 .315 8 .079 2 .0354 .90 200ft Spl** SM278-1/2 1/2 .472 12 .118 3 .0512 1.30 400ft 4ft lgths SM278-3/4 3/4 .630 16 .157 4 .0630 1.60 200ft 4ft lgths SM278-1" 1" .945 24 .236 6 .0827 2.10 100ft 4ft lgths SM278-1 1/4" 1 1/4" 1.260 32 .315 8 .0906 2.30 80ft 4ft lgths Standard Color: Black. Clear and other colors are available to order (Please Call). Standard Package Shown: *Available in 1000FT, **Available in 600FT. Specification Values: Property Physical Electrical Chemical Unaged Tensile strength Elongation Fluid Tensile strength Dielectric strength Resist. Heat shock Low temperature flex Secant Modulus Dielectric strength Volume resistivity Copper corrosion Fungus resistance Water Absorption Flammability Tel: 973-328-3200 Fax: 973-328-3130 Test Method ASTM D 638 ASTM D 638 ASTM D2671 250°C/4 hrs ASTM D746 ASTM 882 ASTM D2671 ASTM D876 121C/16hrs ASTM G21 ASTM D570 ASTM D2671 www.daburn.com Value Min. 1300 psi Min. 250% Min. 900 psi Min. 200 Volts/mil No cracks, flowing, or dripping No crack @-55C Max. 25,000 psi Min. 300 Volts/mil Min. 1x1012- cm No corrosion No growth Max. 1.0% Pass
SM278-1/2" 价格&库存
很抱歉,暂时无法提供与“SM278-1/2"”相匹配的价格&库存,您可以联系我们找货
