Technical Data 4149
Effective November 2015
Supersedes March 2007
SD53
Low profile shielded power inductors
Applications
Desktop computers
Notebook and laptop regulators
LED and White LED drivers
Digital cameras, media devices
Battery power systems
Environmental Data
Product description
Octagonal shape utilizes board space
Shielded drum core
Inductance range from 1.1 uH to 100 uH
Current range from 0.44 A to 4.8 A
5.7 mm x 5.2 mm footprint surface mount
package in a 3.0 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(Ambient plus self temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
SD53
Technical Data 4149
Product Specifications
Part Number5
OCL1 (μH) ±20%
Part marking
Irms2
(A)
Isat3
(A)
DCR (Ω) typical
@ 20 °C
DCR (Ω) maximum @
20 °C
K-factor4
0.017
0.020
48
SD53-1R1-R
1.10
A
3.25
4.80
SD53-2R0-R
2.00
B
2.64
3.30
0.023
0.027
35
SD53-3R3-R
3.30
C
2.26
2.60
0.029
0.034
28
SD53-4R7-R
4.70
D
2.01
2.10
0.039
0.045
21
SD53-6R8-R
6.80
E
1.65
1.85
0.059
0.068
SD53-100-R
10.0
F
1.41
1.40
0.077
0.090
15
SD53-150-R
15.0
G
1.10
1.10
0.122
0.142
12
SD53-220-R
22.0
H
0.81
0.94
0.179
0.208
10
SD53-330-R
33.0
I
0.75
0.76
0.221
0.257
8
SD53-470-R
47.0
J
0.64
0.64
0.303
0.352
7
SD53-680-R
68.0
K
0.52
0.58
0.452
0.525
6
SD53-101-R
100
L
0.44
0.45
0.689
0.801
5
1. 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc.
2. Irms: DC current for an approximate ∆T of 40 °C without core loss. Derating is necessary for AC currents. PCB layout,
trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature
rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating conditions
verified in the end application
3. lsat: Peak current for approximately 30% rolloff @ 25 °C.
4. K-factor: Used to determine B p-p for core loss (see graph). B p-p = K*L*∆I, B p-p(mT), K: (K factor from table),
L: (Inductance in uH), ∆I (Peak to peak ripple current in Amps).
5. Part Number Definition: SD53-xxx-R
SD53 = Product code and size; -xxx = Inductance value in uH; R = decimal point;
If no R is present then third character equals the number of zeros.
-R suffix = RoHS compliant.
53
Dimensions (mm)
Part Marking: Line 1: (1st digit= inductance value per Part Marking Designator); (2nd digit= Bi-weekly production date code); (3rd digit= Last
digit of the year produced), (4th digit= Internal manufacturing code). Line 2: 53=product size code)
Do not route traces or vias underneath the inductor
Packaging information (mm)
Parts packaged on 13” diameter reel, 2,600 parts per reel.
2
www.eaton.com/elx
SD53
Technical Data 4149
Core loss vs. Bp-p
10
1
1MH z
Core Loss (W)
0.1
500kH z
300kH z
200kH z
100kH z
0.01
0.001
0.0001
0.00001
0.000001
1
10
Bp-p (mT)
100
1000
Temperature rise vs. total loss
Inductance characteristics
www.eaton.com/elx
3
SD53
Technical Data 4149
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“SD53-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.205811+1.19441
- 10+8.3000310+1.07689
- 25+7.9081125+1.02604
- 75+7.4203975+0.96276
- 100+7.28104100+0.94468
- 1000+5.965921000+0.77405
- 2600+5.669802600+0.73563
- 5200+5.443365200+0.70625
- 7800+5.312727800+0.68930
