SFSD-10-28-H-10.00-DR-NDX 数据手册
REVISION BC
DO NOT
SCALE FROM
THIS PRINT
01
(No OF POS x .050[1.27])
+ .015[0.38] REF
CL
.250 6.35
REF
.050 1.27
REF
-NXX OPTION (END 2)
(ONLY AVAILABLE WITH -D, -DL, -DR & -DS)
-NUS: NOTCH UP, STRAIGHT
(PIN 1 TO PIN N-1)
-NDS: NOTCH DOWN, STRAIGHT
(PIN 1 TO PIN 2)
-NUX: NOTCH UP, CROSSED
(PIN 1 TO PIN N)
-NDX: NOTCH DOWN, CROSSED
(PIN 1 TO PIN 1)
-T: FEP (LEAVE BLANK FOR
STANDARD PVC INSULATION)
No OF POSITIONS
-02 THRU -50
(PER ROW)
.120 3.05 REF .145 3.68 REF
WIRE GAUGE (AWG)
-28, -30
COLOR CODE:
-S: SINGLE END
SFSD-10-28-XX-XX.XX-S SHOWN LEAVE BLANK FOR ALL BLACK WIRE
C: COLOR CODED WIRE
(SEE TABLE 4, SHEET 3)
ISDF-XX-D-NO
(NOT AVAILABLE FOR TEFLON OPTION,
TEFLON CABLE ONLY AVAILABLE IN BLUE)
.050 1.27 REF
PLATING SPECIFICATION
-H: 30µ" HEAVY GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-G: 10µ" LIGHT GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-F: 3µ" FLASH GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-GF: 3µ" FLASH SELECTIVE IN CONTACT AREA,
3µ" GOLD ON TAIL
.249 6.32
(ONLY AVAILABLE TO EXISTING
REF
CUSTOMERS; SEE -F PLATING)
(SEE TABLE 3, SHEET 1)
ASSEMBLED LENGTH
SPECIFY IN INCHES
(SINGLE END: 03.00 INCH [76.2mm]
MINIMUM,
DOUBLE END: 03.25 INCH [82.6mm]
C
MINIMUM)
END OPTION
(END OPTION COMBINATIONS NOT AVAILABLE)
FIG 1
02
.080 2.03 REF
"A"
C
SFSDX-XX-XXX-XX-XX.XX-XX-XXX
FEP CABLE OPTION
.440 11.18
REF
-S: SINGLE END
-D: DOUBLE END
(MUST CHOOSE FROM -NXX OPTIONS)
-SL: SINGLE ENDED WITH FRICTION LOCK
(SEE SHEET 2, FIG 3)(ONLY AVAILABLE ON
*5,*7, 10 THRU 50 POSITION)
-DL: DOUBLE ENDED WITH FRICTION LOCK
(SEE SHEET 2, FIG 4) (ONLY AVAILABLE
ON *5,*7, 10 THRU 50 POSITION)
-SR: SINGLE ENDED WITH RETENTION LATCH
(SEE SHEET 3, FIG 5)
(ONLY AVAILABLE ON -02 THRU -50 POS)
-DR: DOUBLE ENDED WITH RETENTION LATCH
(SEE SHEET 3, FIG 6)
-SS: DUAL SCREW DOWN, SINGLE ENDED CABLE
(SEE SHEET 4, FIG 7)
(NOT AVAILABLE WITH OPTIONS SL, DL, SR & DR
USES ISDF-XX-D-DS, CPS-RR-XX-XX-X & ACCRT-01)
-DS: DUAL SCREW DOWN, DOUBLE ENDED CABLE
(SEE SHEET 4, FIG 8)
USES ISDF-XX-D-DS, CPS-RR-XX-XX-X & ACCRT-01,
MUST CHOOSE FROM NXXX OPTIONS)
ASSEMBLED LENGTH:
(SEE NOTE 8)
(* = NOT AVAILABLE WITH POLARIZATION KEY)
DWCX-XX-XX-300
POLARIZATION KEY
C
ASSEMBLED LENGTH:
XX.XX .125[3.18]
BC
NOTES:
"A"
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PULLOUT FORCE: 3.0 LBS [13.3 N].
C 3. CONTACT MUST BE INSERTED UNTIL RETENTION FEATURE LOCKS INTO PLACE.
C 4. ALL FINISHED GOODS ARE TO BE ELECTICAL TESTED INCLUDING HI-POT TEST
AT 1000 VOLTS DC. AFTER FINAL ELECTRICAL TEST, MARK EACH ASSEMBLY
PER INSTRUCTIONS REFERENCED IN CO-{AD-ID}-WI-3092-M.
5. TINNED COPPER WIRE IS RoHS COMPLIANT.
6. NOTE DELETED.
7. NOTE DELETED.
8. FOR LENGTHS LESS THAN 12 in, TOLERANCE SHALL BE +/-.125.
FOR OTHER LENGTHS, TOLERANCE SHALL BE +/-2%.
9. NOTE DELETED.
10. REFER TO CRIMP SPECIFICATIONS PRINT FOR CRIMP AND STRIP
DIMENSIONS, TOLERANCES, TOOLING AND ITS REQUIREMENTS.
11. 3LB MIN WIRE CRIMP STRENGTH FOR -30 AWG AND 4.5LB MIN
WIRE CRIMP STRENGTH FOR -28 AWG.
12. NOTE DELETED.
13. -TC TEFLON USE FOR DOUBLE ENDED ASSEMBLIES ONLY,
ALL SINGLE ENDED ASSEMBLIES USE SILVER PLATED DWCT-XX-01.
14. CUT LENGTH IS ASSEMBLY LENGTH MINUS OVERALL LENGTH SUBTRACTOR.
15. NOTE DELETED.
16. SEE PACKAGING MANUAL FOR PACKAGING DETAILS.
SECTION "A"-"A"
FIG 2
-D: DOUBLE END
SFSD-10-28-XX-XX.XX-D-NUS SHOWN
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP UL 94V-0, COLOR: BLACK
CONTACT: BeCu
CABLE INSULATION: PVC OR FEP
WIRE: DWC: TINNED COPPER.
F:\DWG\MISC\MKTG\SFSDX-XX-XXX-XX-XX.XX-XX-XXX-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050[1.27] SOCKET DISCRETE CABLE ASSEMBLY
DWG. NO.
BY: BRATCHER 5/5/2005
SHEET 1 OF 5
REVISION BC
N-1
01
02
N
02
NOTCH END 1
NOTCH END 2
N-1
N
01
02
N-1
N
01
02
01
N
NOTCH END 1
N-1
(SEE TABLE 2)
-NUS
(END 2 NOTCH UP, CABLE STRAIGHT)
(SEE TABLE 5 FOR PIN MAPPING)
N-1
NOTCH END 2
-NDX
(END 2 NOTCH DOWN, CABLE CROSSED)
02
N
01
ISDF-XX-D-FL
ISDF-XX-D-FL
01
02
NOTCH END 1
NOTCH END 2
N
N-1
(SEE TABLE 2)
-NUX
(END 2 NOTCH UP, CABLE CROSSED)
N-1
N-1
N
N
FIG 3
01
01
02
02
-SL: SINGLE END FRICTION LOCK
SFSDX-10-28-XX-XX.XX-SL SHOWN
NOTCH END 1
-NDS
(END 2 NOTCH DOWN, CABLE STRAIGHT)
NOTCH END 2
PROPRIETARY NOTE
FIG 4
-DL: DOUBLE END FRICTION LOCK
SFSDX-10-28-XX-XX.XX-DL-NUS SHOWN
SHEET SCALE: 1:0.571429
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 2 OF 5
FIG 6
REVISION BC
.088 2.24 REF
.113 2.86 REF
-DR: DOUBLE END WITH RETENTION LATCH
SFSDX-05-28-XX-XX.XX-DR SHOWN
.080 2.03
REF
.113 2.86 REF
.088 2.24 REF
.080 2.03 REF
ISDF-XX-D-M
ISDF-XX-D-M
+ .145[3.68] REF
+ .145[3.68] REF (TYP)
FIG 5
-SR: SINGLE END WITH RETENTION LATCH
SFSDX-05-28-XX-XX.XX-SR SHOWN
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 3 OF 5
REVISION BC
(No OF POS X .050[1.27]) + .360 [9.14]
C
C
CPS-RR-M2-01-X
(No OF POS X .050[1.27]) + .360 [9.14] (TYP)
.079 2.00
REF
.145 3.68
C
CPS-RR-M2-01-X
ACCRT-01
.079 2.00
REF
C
.145 3.68
'A'
ISDF-XX-D-DS
ISDF-XX-D-DS
+.015[0.38] REF
+.015[0.38] REF
FIG 7
"B"
"B"
-SS: SINGLE END WITH SCREW DOWN
SFSDX-10-XXX-XX-XX.XX-SS SHOWN
FIG 8
-DS: DOUBLE END WITH SCREW DOWN
SFSDX-10-XXX-XX-XX.XX-DS-NDS SHOWN
MUST CHOOSE FROM -NXXX OPTIONS)
DETAIL 'A'
SCALE 4 : 1
ACCRT-01
PROPRIETARY NOTE
R.057 1.45 REF
SECTION "B"-"B"
SCALE 4 : 1
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 4 OF 5
REVISION BC
.105 2.67
.105 2.67
OVERALL LENGTH
(SEE TABLE 6)
OVERALL LENGTH
(SEE TABLE 6)
.105 2.67
-S: SINGLE END
-D: DOUBLE END
CABLE CUT IN-PROCESS
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: BRATCHER
5/5/2005 SHEET 5 OF 5
