FFMD-20-T-02.00-01-N 数据手册
REVISION AF
FFMD-XX-X-XX.XX-01-X-X-XXX
FIG 1
(FFMD-10-D-XX.XX-01-X SHOWN)
OPTION
-RW: REVERSE WIRING
-BXX: BREAKOUT OPTION
-O: OUTSIDE REVERSED
-M: MIDDLE REVERSED
-R: REVERSE
-DXX: DAISY CHAIN (MINIMUM 2.00[50.8],
1.00[25.4] INCREMENTS)
-SR: STRAIN RELIEF
(NOT AVAILABLE WITH -O, -M,
-R, -DXX OR -BXX)
(SOLD AS ASSEMBLIES ONLY)
No OF POSITIONS
-03 TO -25
C
DO NOT
SCALE FROM
THIS PRINT
END ASSEMBLY
-D: DOUBLE END
-S: SINGLE END
*-T: TRANSFER END
XX.XX [XX.X x 25.4] 1%
(SEE NOTE 7 & 9)
ASSEMBLY LENGTH
(2.00[50.8] MINIMUM)
C
LEAD STYLE
(No. OF POS x .050)
[1.27])+.165[4.19] REF
TRANSFER OPTION
-N: SOCKET HAS NOTCH POLARIZATION
(-T END ASSEMBLY ONLY)
(LEAVE BLANK FOR -S AND -D
END OPTIONS)
(NOT AVAILABLE ON POSITIONS -02
THRU -04)
PLATING OPTIONS
LEAVE BLANK FOR STANDARD
(USE T-1S57-01-T AND C-67-L)
-L: SELECTIVE LIGHT GOLD
(USE T-1S57-01-L AND C-67-L)
-F: FLASH SELECTIVE GOLD
(USE T-1S57-01-F AND C-67-F)
-S: SELECTIVE GOLD
(USE T-1S57-01-S AND C-67-S)
C
.120 3.05
REF
*16-25 POS TRANSFER END STRAIN RELIEF NOT RELEASED FOR PRODUCTION
FMC-XX-D
FLUSH TO .010 0.25 MAX
CABLE OVERHANG
(SEE NOTE 7)
FIG 2
COLORED WIRE TO SIDE
OF FIRST POS INDICATOR
(FFMD-10-S-XX.XX-01-X SHOWN)
(SAME AS FIG 1, DIFFERENT AS SHOWN)
2
C
C
.200±.010 5.08±0.25
T-1S57-01-X
XX.XX[XX.XX x 25.4] ±1%
(SEE NOTE 7 & 9)
3
FMB-XX-D-XX
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. FFSD ASSEMBLY TO BE USED FOR TRANSFER END ONLY.
C 3. ALL ASSEMBLIES TO BE 100% ELECTRONICALLY TESTED
FOR SHORTS AND OPENS.
4. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V.
5. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL.
6. FFMD CABLE ASSEMBLIES ARE LEAD FREE.
7.WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND
PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE
THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS
ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR.
8. REFERENCE FFMD-XX-XX-X-XX (AND FFSD-XX-XX-X-N-XX
FOR -T OPTION)DRAWING FOR CONNECTOR ASSEMBLY
DIMENSIONS AND ITS REQUIREMENTS.
9. FOR LENGTHS LESS THAN 12.5" TOLERANCE SHALL BE +/-.125, ALL
OTHER LENGTHS SHALL BE +/-1%.
10. PACKAGE PER IDC STYLE CABLE SECTION OF PACKAGING MANUAL.
F:\DWG\MISC\MKTG\FFMD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW
.121 3.07 REF
C
NOTCH DENOTES
FIRST POSITION
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: PBT, COLOR: BLACK
CONTACT: BeCu
TERMINAL: PHOS BRONZE
WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH
PVC INSULATOR
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.050 X .050 DOUBLE ROW MALE IDC CABLE ASSEMBLY
DWG. NO.
BY: T NEWTON 02/15/2008
SHEET 1 OF 5
REVISION AF
FIG 3
FIG 5
(FFMD-10-D-XX.XX-01-X-SR SHOWN)
FIG 4
(FFMD-10-X-XX.XX-01-X-RW SHOWN)
(FFMD-10-X-XX.XX-01-X-N SHOWN)
(SAME AS FIG 1 AND FIG 6, DIFFERENT AS SHOWN)
(FOR -T ONLY)
(IF OPTION IS SPECIFIED USE FFSD-XX-01-X-N)
02
01
03
COLORED WIRE TO OPPOSITE
SIDE OF FIRST POS INDICATOR
C
(No. OF POS. x .050[1.27]) + .315[8.00]
REF
NOTCH DENOTES FIRST POSITION
XX.XX[XX.X x 25.4] .13[3.2]
C
.075 1.91
REF
.040 1.02
REF
.039 1.00
5
C
.335±.01 8.51±0.254
FIG 6
4
(FFMD-10-T-XX.XX-01-X-N SHOWN)
FIG 7
(FFMD-10-T-XX.XX-01-X-N-B05 SHOWN)
"XX" = NO. OF CONDUCTORS PER ROW
BROKEN OUT FROM THE FIRST POSITION
"XX"
5.00[127.0] MAX
2.00[50.8] MIN
(MAY BE SMALLER THAN 2.00
ON AN ASSEMBLY LENGTH
OF 2.00, MUST BE SPLIT BACK
TO THE FIRST CONNECTOR)
IN-PROCESS 1
-SR ONLY
(XX.XX[XX.X x 25.4] + .4375[11.113]) .125[3.18]
C
+.006
+0.152
.200 - .003 5.08 - 0.076
IN-PROCESS 2
C
-SR ONLY
PROPRIETARY NOTE
C
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 2 OF 5
FIG 8
REVISION AF
FIG 9
(FFMD-10-D-XX.XX-01-X-DXX-O SHOWN)
(2.00[50.8] MINIMUM LENGTH, 1.00[25.4] INCREMENTS)
(NOT AVAILABLE WITH -R OR -M OPTIONS)
XX.00[XX.0 x 25.4] .13[3.2]
(MIN 2", SEE CALLOUT OPTION DXX)
(FFMD-10-D-XX.XX-01-X-DXX-M SHOWN)
(NOT AVAILABLE WITH -R OR -O OPTIONS)
FIRST POSITION
INDICATOR
FIRST POSITION INDICATOR
OUTSIDE CONNECTOR
REVERSED
WHEN DAISY CHAINED
MIDDLE CONNECTOR REVERSED
WHEN DAISY CHAINED
FIG 11
FIG 10
(FFMD-10-T-XX.XX-01-X-N-DXX-M SHOWN)
(FFMD-10-T-XX.XX-01-X-N-DXX-O SHOWN)
XX.00(XX.0 x 25.4) ±.13[3.2]
WHEN DAISY CHAINED
OUTSIDE CONNECTOR REVERSED
WHEN DAISY CHAINED
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 3 OF 5
REVISION AF
FIG 12
FIG 13
(FFMD-10-D-XX.XX-01-DXX-R SHOWN)
(NOT AVAILABLE WITH -M OR -O OPTIONS)
(FFMD-10-D-XX.XX-01-X-DXX)
BOTH CONNECTORS REVERSED
WHEN DAISY CHAINED
FIG 15
FIG 14
(FFMD-10-T-XX.XX-01-X-N-DXX)
(FFMD-10-T-XX.XX-01-X-N-DXX-R SHOWN)
WHEN DAISY CHAINED
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 4 OF 5
REVISION AF
FIG 17
FIG 16
(FFMD-25-T-XX.XX-01-X-N-SR SHOWN)
(SAME AS FIG 1 AND FIG 16, DIFFERENT AS SHOWN)
(FOR POSITIONS 16-25 ONLY)
(FFMD-10-T-XX.XX-01-X-N-SR SHOWN)
(SAME AS FIG 1 AND FIG 3, DIFFERENT AS SHOWN)
(FOR POSITIONS 2-15 ONLY)
*NOT RELEASED FOR PRODUCTION
5
.335±.010 8.51±0.254
C
6
7
8
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 5 OF 5
