10064-34-1-0500-002-1-TS 数据手册
P/N 10064-34-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: FEP Material)
UL10064 - FEP Insulated Hook-Up Wire 105°C 30V (34 AWG)
CONSTRUCTION:
CERTIFICATION & APPROVALS:
Tinned Strands, copper conductor, 7/0.060 mm strands.
Overall Diameter = 0.50 mm ± 0.05 mm
Insulation Thickness: 0.15mm (small AWG's = >Flexibility)
UL RATED AWM: Can be used in the USA.
UL Subject 758 UL FILE NO:E108485
Printed Markings:
“AWM 10064 105℃ 30V E108485 34AWG REIHSING VW-1 ”
Passes UL VW-1 Vertical Flame Test.
PHYSICAL
ELECTRICAL PROPERTIES:
APPLICATIONS:
PACKAGING:
ENVIRONMENTAL APPROVALS:
Rated Temperature: 105℃ ~ -80℃
Rated Voltage: 30V
Insulation Potential Strength: 500 VAC/min
Flexibility: hard FEP material, is slightly more rigid than
PVC insulation material.
Maximum Conductor Resistance: 728.5 Ω/km
Resistant to: Chemical solvents, abrasion, cutting,
extremes of hot & cold, flexing, shock, compression.
FEP wire, has good resistance to extremes of temp.,
compression and repeat flexing. Suitable for use in microelectronic appliances that require a more durable wire,
when shock or movement within portable devices are a
“wear and tear” factor. Resistant to frigid environments
500ft per reel.
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC. Current SGS reports for this wire
are available upon request.
P/N's & COLORS
10064-34-1-0500-001-1-TS 10064-34-1-0500-002-1-TS
BLACK
WHITE
10064-34-1-0500-006-1-TS
10064-34-1-0500-007-1-TS
BROWN
GREEN
10064-34-1-0500-003-1-TS
10064-34-1-0500-004-1-TS
10064-34-1-0500-005-1-TS
YELLOW
RED
BLUE
10064-34-1-0500-008-1-TS 10064-34-1-0500-010-1-TS
ORANGE
VIOLET
10064-34-1-0500-012-1-TS
GRAY
10064-34-1-0500-002-1-TS 价格&库存
很抱歉,暂时无法提供与“10064-34-1-0500-002-1-TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+188.831311+24.46026
- 3+176.213403+22.82580
- 5+168.482665+21.82440
- 10+159.7631910+20.69492
- 25+150.0816425+19.44082
- 50+142.3364050+18.43755
- 100+135.55729100+17.55941
- 500+125.87471500+16.30518
- 国内价格 香港价格
- 1+137.837041+17.85472
- 2+131.256102+17.00226
- 3+127.519443+16.51823
- 5+123.004875+15.93344
- 7+120.085737+15.55530
- 国内价格 香港价格
- 500+1.46990500+0.19041
- 1000+1.398671000+0.18118
- 1500+1.358391500+0.17596
- 2500+1.309042500+0.16957
- 3500+1.277363500+0.16547
- 5000+1.244465000+0.16120
- 国内价格 香港价格
- 1+6.269831+0.81217
- 5+5.650325+0.73192
- 10+5.3790210+0.69677
- 25+5.0444925+0.65344
- 50+4.8045950+0.62237
- 100+4.57473100+0.59259
