10064-34-1-0500-005-1-TS
    CNC
    FEPWIREBL500'
10064-34-1-0500-005-1-TS 数据手册
P/N 10064-34-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL10064 - FEP Insulated Hook-Up Wire 105°C 30V (34 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.060 mm strands. Overall Diameter = 0.50 mm ± 0.05 mm Insulation Thickness: 0.15mm (small AWG's = >Flexibility) UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 10064 105℃ 30V E108485 34AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 105℃ ~ -80℃ Rated Voltage: 30V Insulation Potential Strength: 500 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 728.5 Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in microelectronic appliances that require a more durable wire, when shock or movement within portable devices are a “wear and tear” factor. Resistant to frigid environments 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 10064-34-1-0500-001-1-TS 10064-34-1-0500-002-1-TS BLACK WHITE 10064-34-1-0500-006-1-TS 10064-34-1-0500-007-1-TS BROWN GREEN 10064-34-1-0500-003-1-TS 10064-34-1-0500-004-1-TS 10064-34-1-0500-005-1-TS YELLOW RED BLUE 10064-34-1-0500-008-1-TS 10064-34-1-0500-010-1-TS ORANGE VIOLET 10064-34-1-0500-012-1-TS GRAY
10064-34-1-0500-005-1-TS 价格&库存
很抱歉,暂时无法提供与“10064-34-1-0500-005-1-TS”相匹配的价格&库存,您可以联系我们找货
  • 1+751.656681+96.41508
  • 2+715.400912+91.76455
  • 3+694.880863+89.13244
  • 5+669.735715+85.90707
  • 7+653.592447+83.83637
  • 10+636.8442610+81.68808
  • 1+55.076781+7.06471
  • 2+52.490892+6.73302
  • 3+51.024663+6.54494
  • 5+49.214015+6.31269
库存:4
  • 1+96.632281+12.39504
  • 2+92.094982+11.81304
  • 3+89.494883+11.47952
  • 5+86.307925+11.07073
库存:4
  • 1+188.817901+24.21969
  • 3+176.206583+22.60204
  • 5+168.476285+21.61047
  • 10+159.7578410+20.49216
  • 25+150.0762725+19.25030
  • 50+142.3309750+18.25681
  • 100+135.55221100+17.38730
  • 500+125.87004500+16.14537
库存:4
