10064-28-1-0500-007-1-TS
    CNC
    FEPWIRE28AWGGN500'
10064-28-1-0500-007-1-TS 数据手册
P/N 10064-28-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL10064 - FEP Insulated Hook-Up Wire 105°C 30V (28 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.127 mm strands. Overall Diameter = 0.70 mm ± 0.05 mm Insulation Thickness: 0.15mm (small AWG's = > Flexibility) UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 10064 105℃ 30V E108485 28AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: Rated Temperature: 105℃ ~ -80℃ Rated Voltage: 30V Insulation Potential Strength: 500 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 248.0 Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in microelectronic appliances that require a more durable wire, when shock or movement within portable devices are a “wear and tear” factor. Resistant to frigid environments 500ft per reel. Conforms to all current RoHS directives as laid out in EU ENVIRONMENTAL APPROVALS: Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 10064-28-1-0500-001-1-TS 10064-28-1-0500-002-1-TS BLACK WHITE 10064-28-1-0500-006-1-TS 10064-28-1-0500-007-1-TS BROWN GREEN 10064-28-1-0500-003-1-TS 10064-28-1-0500-004-1-TS 10064-28-1-0500-005-1-TS YELLOW RED BLUE 10064-28-1-0500-008-1-TS 10064-28-1-0500-010-1-TS ORANGE VIOLET 10064-28-1-0500-012-1-TS GRAY
10064-28-1-0500-007-1-TS 价格&库存
很抱歉,暂时无法提供与“10064-28-1-0500-007-1-TS”相匹配的价格&库存,您可以联系我们找货
