10064-30-1-0500-001-1-TS 数据手册
P/N 10064-30-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: FEP Material)
UL10064 - FEP Insulated Hook-Up Wire 105°C 30V (30 AWG)
CONSTRUCTION:
CERTIFICATION & APPROVALS:
Tinned Strands, copper conductor, 7/0.100 mm strands.
Overall Diameter = 0.60 mm ± 0.05 mm
Insulation Thickness: 0.15mm (small AWG's = >Flexibility)
UL RATED AWM: Can be used in the USA.
UL Subject 758 UL FILE NO:E108485
Printed Markings:
“AWM 10064 105℃ 30V E108485 30AWG REIHSING VW-1 ”
Passes UL VW-1 Vertical Flame Test.
PHYSICAL
ELECTRICAL PROPERTIES:
APPLICATIONS:
PACKAGING:
ENVIRONMENTAL APPROVALS:
Rated Temperature: 105℃ ~ -80℃
Rated Voltage: 30V
Insulation Potential Strength: 500 VAC/min
Flexibility: hard FEP material, is slightly more rigid than
PVC insulation material.
Maximum Conductor Resistance: 397.0 Ω/km
Resistant to: Chemical solvents, abrasion, cutting,
extremes of hot & cold, flexing, shock, compression.
FEP wire, has good resistance to extremes of temp.,
compression and repeat flexing. Suitable for use in microelectronic appliances that require a more durable wire,
when shock or movement within portable devices are a
“wear and tear” factor. Resistant to frigid environments
500ft per reel.
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC. Current SGS reports for this wire
are available upon request.
P/N's & COLORS
10064-30-1-0500-001-1-TS 10064-30-1-0500-002-1-TS
BLACK
WHITE
10064-30-1-0500-006-1-TS
10064-30-1-0500-007-1-TS
BROWN
GREEN
10064-30-1-0500-003-1-TS
10064-30-1-0500-004-1-TS
10064-30-1-0500-005-1-TS
YELLOW
RED
BLUE
10064-30-1-0500-008-1-TS 10064-30-1-0500-010-1-TS
ORANGE
VIOLET
10064-30-1-0500-012-1-TS
GRAY
10064-30-1-0500-001-1-TS 价格&库存
很抱歉,暂时无法提供与“10064-30-1-0500-001-1-TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+163.669361+21.24695
- 国内价格 香港价格
- 1+56.865091+7.38202
- 2+54.145832+7.02901
- 3+52.636313+6.83305
- 5+50.775225+6.59145
- 7+49.591427+6.43778
- 10+48.3497010+6.27658
