Effective October 2017
Supersedes June 2017
Technical Data 4401
PTR060V
HALOGEN
HF
FREE
60 Volt DC radial leaded, PolyTron™ PTC devices
Pb
Applications
Medical equipment
White goods
Industrial power transmission
Telecommunications
Computers and peripherals
Consumer and automotive electronics
Rechargeable battery packs
Agency information
Product features
cURus: Recognized Card: File E343021 (Ihold 0.1-3.75 A)
TUV File: J 50194729
Ordering information/
part number system
PolyTron™ radial leaded thru-hole PTC device
Maximum 60 V
Current ratings from 0.10 A to 3.75 A
Fast time-to-trip
Low resistance
Halogen free, Lead free, RoHS compliant
PT
R 060V 0160
TR & TR1 On Reels
0.10, 0.20-0.40 A - 3000 devices
0.17 - 2,500 A devices
0.50-0090 A - 2000 devices
1.10-1.85 A - 1200 devices
2.50-3.75 A - 1000 devices
BK & BK1 In Poly Bags
• 0.10-0.25 A - 1000 devices
• 0.30-1.85 A - 500 devices
• 2.50-3.75 A - 250 devices
Specifications
Catalog
Number
PTR060V0010
PTR060V0017
PTR060V0020
PTR060V0025
PTR060V0030
PTR060V0040
PTR060V0050
PTR060V0065
PTR060V0075
PTR060V0090
PTR060V0110
PTR060V0135
PTR060V0160
PTR060V0185
PTR060V0250
PTR060V0300
PTR060V0375
Notes:
Vmax
(Vdc)
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
60
Imax
(A)
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
Ihold
Itrip
@+23 °C @+23 °C
(A)
(A)
0.10
0.20
0.17
0.34
0.20
0.40
0.25
0.50
0.30
0.60
0.40
0.80
0.50
1.00
0.65
1.30
0.75
1.50
0.90
1.80
1.10
2.20
1.35
2.70
1.60
3.20
1.85
3.70
2.50
5.00
3.00
6.00
3.75
7.50
-TR
PolyTron™ PTC Device Series
Radial Leaded
Maximum Voltage
Current Holding (Ihold)
Tape and Reel Packaging and Lead Type Code
Lead Codes: TR & BK - Straight Leads, TR1 & BK1 - Kinked Leads
Pd
Typ.
(W)
0.38
0.48
0.41
0.45
0.49
0.56
0.77
0.88
0.92
0.99
1.50
1.70
1.90
2.10
2.50
2.80
3.20
Time to
Trip (Max.)
(A)
(sec)
0.50
4.0
0.85
3.0
1.00
2.2
1.25
2.5
1.50
3.0
2.00
3.8
2.50
4.0
3.25
5.3
3.75
6.3
4.50
7.2
5.50
8.2
6.75
9.6
8.00
11.4
9.25
12.6
12.50
15.6
15.00
19.8
18.75
24.0
Resistance (Ω)
Agency
Initial (Ri)
Post Trip (R1)
Information
Min.
Max.
Max.
cURus
TUV
2.500
4.500
7.50
X
X
3.300
5.210
8.00
X
X
1.830
2.750
4.40
X
X
1.250
1.950
3.00
X
X
0.880
1.330
2.10
X
X
0.550
0.860
1.29
X
X
0.500
0.770
1.17
X
X
0.310
0.480
0.72
X
X
0.250
0.400
0.60
X
X
0.200
0.310
0.47
X
X
0.150
0.250
0.38
X
X
0.120
0.190
0.30
X
X
0.090
0.140
0.22
X
X
0.080
0.120
0.19
X
X
0.050
0.080
0.13
X
X
0.040
0.060
0.10
X
X
0.030
0.050
0.08
X
X
Ihold – Hold current: Maximum current device will pass without interruption in +23 °C still air.
Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in +23 °C still air.
Vmax: Maximum continuous voltage device can withstand without damage at rated current.
Imax: Maximum fault current device can withstand without damage at rated voltage.
Pd: Power dissipated from device when in the tripped state in +23 °C still air.
Ri (min.): Minimum resistance of device as supplied at +23 °C unless otherwise specified.
Ri (max.): Maximum resistance of device as supplied at +23 °C unless otherwise specified.
R1(max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at +23 °C unless otherwise specified.
Technical Data 4401
Dimensions - mm
Part
Number
PTR060V0010
PTR060V0017
PTR060V0020
PTR060V0025
PTR060V0030
PTR060V0040
PTR060V0050
PTR060V0065
PTR060V0075
PTR060V0090
PTR060V0110
PTR060V0135
PTR060V0160
PTR060V0185
PTR060V0250
PTR060V0300
PTR060V0375
A
Max.
7.4
7.4
7.4
7.4
7.4
7.6
7.6
9.7
10.4
11.7
13.0
14.5
16.3
17.8
21.3
24.9
28.4
B Max
Lead Type
Straight Kink
(-TR) (-TR1)
C
12.7 12.7 5.0±0.8
12.7 12.7 5.0±0.8
12.2 12.2 5.0±0.8
12.7 12.7 5.0±0.8
13.0 13.0 5.0±0.8
13.5 13.5 5.0±0.8
13.7 13.7 5.0±0.8
14.5 14.5 5.0±0.8
15.2 15.2 5.0±0.8
15.7 15.7 5.0±0.8
18.0 18.0 5.0±0.8
19.6 19.6 5.0±0.8
21.3 21.3 5.0±0.8
22.9 22.9 5.0±0.8
26.4 26.4 10.0±0.8
30.0 30.0 10.0±0.8
33.5 33.5 10.0±0.8
D
Min.
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
E
Max.
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
F
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
2
www.eaton.com/electronics
Style 1
Style 2
Figure 1 - PTR060V0010-PTR060V0185
Packaging/Taping Specifications
Description
Sprocket hole pitch P0 12.7 0.3
Ordinate to adjacent component lead
PTR060V0010~PTR060V0090
PTR060V0110~PTR060V0185
PTR060V0250~PTR060V0300
Device pitch PTR060V0010~PTR060V0090
Device pitch PTR060V0110~PTR060V0300
Device pitch PTR060V0375
Lead spacing
Carrier tape width
Top distance between tape edges
Hold-down tape width
Sprocket hole position
Abscissa to top PTR060V0010~PTR060V0090
Abscissa to top PTR060V0110~PTR060V0300
Abscissa to plane (straight lead)
Abscissa to plane (kinked lead)
Sprocket hole diameter
Lead protrusion
Tape thickness
Body lateral deviation
Body tape plane deviation
Reel width
Reel diameter
Arbor hole diameter
Core diameter
* See Dimensions table.
Figure/
Lead Style
Straight Kink
TR
TR1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
IEC
Mark
Dimension Tolerance
(mm)
(mm)
P1
3.6
±1.0
P1
3.45
±1.0
P1
P
P
P
C
W
W0
W1
W2
H1
H1
H
H0
D0
L1
t
Δh
Δp
W3
7.3
12.7
25.4
38.1
18
3.0
12
9.0
32.2
47.5
18.0
16.0
4
1
0.9
340
31
80
±1.0
±1.0
±1.0
±1.0
-±1.0
Max.
±1.0
+0.75/-0.5
Max.
Max.
+2/-0
±0.5
±0.2
Max.
Max.
±1.0
±1.3
Max.
±10
±1
Min.
n0
n
Figure 2 - PTR060V0250-PTR060V0375
Reel specification
PTR060V
Technical Data 4401
Time-to-Trip Curves at +23 °C
A
B
C D
E
F
G
H
I
J
K
L M N
O
P Q
1000
100
A:PTR060V0010
B:PTR060V0017
C :PTR060V0020
D :PTR060V0025
E:PTR060V0030
F :PTR060V0040
10
G :PTR060V0050
H :PTR060V0065
TIM E IN S E C O N D S
I:PTR060V0075
J :PTR060V0090
K:PTR060V0110
1
L:PTR060V0135
M :PTR060V0160
N :PTR060V0185
O :PTR060V0250
P:PTR060V0300
Q :PTR060V0375
0. 1
0. 01
0. 001
0. 1
1
10
100
Fa u lt Cu rre n t (A )
P erc entage of D erated C urrent
Thermal Derating Curve
180.0
160.0
140.0
120.0
100.0
80.0
60.0
40.0
20.0
0.0
-40
-20
Tem perature (°C)
60
80
3
PTR060V
Technical Data 4401
Recommended Wave Solder Profile.
P re h e a tin g
So ld e rin g
Environmental Specifications
Characteristic
Operating Temperature Range
Surface Temperature Trip State
Thermal Shock
Co o lin g
260°C max
T e m p e ra ture
No te 2
Solvent Resistance
Humidity Age Test
No te 3
130 ± 200°C
No te 1
T am b
t
3 0 ~9 0 se c
Notes:
1. (1-3) °C/sec
2. Approximately 200 °C/sec
3. 5 °C/sec Maximum
很抱歉,暂时无法提供与“PTR060V0135-BK”相匹配的价格&库存,您可以联系我们找货
