Effective October 2017
Supersedes June 2017
Technical Data 4400
PTR030V
HALOGEN
HF
FREE
30 Volt DC radial leaded, PolyTron™ PTC devices
Pb
Applications
Medical equipment
White goods
Industrial power transmission
Telecommunications
Computers and peripherals
Consumer and automotive electronics
Rechargeable battery packs
Agency information
Product features
cURus: Recognized Card: File E343021 (Ihold 0.9-9 A)
TUV File: J 50194729
Ordering information/
part number system
PolyTron™ radial leaded thru-hole PTC device
Maximum 30 V
Current ratings from 0.90 A to 9.00 A
Fast time-to-trip
Low resistance
Halogen free, Lead free, RoHS compliant
PT
R 030V 0160
TR & TR1 On Reels
• 0.90-1.60 A - 3000 devices
• 1.85-3.00 A - 2000 devices
• 4.00-9.00 A - 1000 devices
BK & BK1 In Poly Bags
• 0.90-1.35 A - 1,000 devices
• 1.60-6.00 A - 500 devices
• 7.00-9.00 A - 250 devices
Specifications
Catalog
Number
PTR030V0090
PTR030V0110
PTR030V0135
PTR030V0160
PTR030V0185
PTR030V0250
PTR030V0300
PTR030V0400
PTR030V0500
PTR030V0600
PTR030V0700
PTR030V0800
PTR030V0900
Notes:
Vmax
(Vdc)
30
30
30
30
30
30
30
30
30
30
30
30
30
Imax
(A)
40
40
40
40
40
40
40
40
40
100
100
100
100
Ihold
Itrip
@+23 °C @+23 °C
(A)
(A)
0.90
1.80
1.10
2.20
1.35
2.70
1.60
3.20
1.85
3.70
2.50
5.00
3.00
6.00
4.00
8.00
5.00
10.00
6.00
12.00
7.00
14.00
8.00
16.00
9.00
18.00
-TR
PolyTron™ PTC Device Series
Radial Leaded
Maximum Voltage
Current Holding (Ihold)
Tape and Reel Packaging and Lead Type Code
Lead Codes: TR & BK - Straight Leads, TR1 & BK1 - Kinked Leads
Pd
Typ.
(W)
0.6
0.7
0.8
0.9
1.0
1.2
2.0
2.5
3.0
3.5
3.8
4.0
4.2
Time to
Trip (Max.)
(A)
(sec)
4.50
5.90
5.50
6.60
6.75
7.30
8.00
8.00
9.25
8.70
12.50
10.30
15.00
10.80
20.00
12.70
25.00
14.50
30.00
16.00
35.00
17.50
40.00
18.80
45.00
20.00
Resistance (Ω)
Agency
Initial (Ri)
Post Trip (R1)
Information
Min.
Max.
Max.
cURus
TUV
0.070
0.120
0.22
X
X
0.050
0.100
0.17
X
X
0.040
0.080
0.13
X
X
0.030
0.070
0.11
X
X
0.030
0.060
0.09
X
X
0.020
0.040
0.07
X
X
0.020
0.050
0.08
X
X
0.010
0.030
0.05
X
X
0.010
0.030
0.05
X
X
0.005
0.020
0.04
X
X
0.005
0.020
0.03
X
X
0.005
0.013
0.02
X
X
0.005
0.010
0.02
X
X
Ihold – Hold current: Maximum current device will pass without interruption in +23 °C still air.
Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in +23 °C still air.
Vmax: Maximum continuous voltage device can withstand without damage at rated current.
Imax: Maximum fault current device can withstand without damage at rated voltage.
Pd: Power dissipated from device when in the tripped state in +23 °C still air.
Ri (min.): Minimum resistance of device as supplied at +23 °C unless otherwise specified.
Ri (max.): Maximum resistance of device as supplied at +23 °C unless otherwise specified.
R1 (max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at +23 °C unless otherwise specified.
Technical Data 4400
Dimensions - mm
Part
Number
PTR030V0090
PTR030V0110
PTR030V0135
PTR030V0160
PTR030V0185
PTR030V0250
PTR030V0300
PTR030V0400
PTR030V0500
PTR030V0600
PTR030V0700
PTR030V0800
PTR030V0900
A
Max.
7.4
7.4
8.9
8.9
10.2
11.4
11.4
14.0
14.0
16.5
19.1
21.6
24.1
B Max
Lead Type
Straight Kink
(-TR) (-TR1)
12.2 12.2
14.2 14.2
13.5 13.5
15.2 15.2
15.7 15.7
18.3 20.5
17.3 21.8
20.1 24.6
24.9 26.6
24.9 29.4
26.7 31.2
29.2 33.7
29.7 34.2
C
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
D
Min.
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
E
Max.
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
F
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
Packaging/Taping Specifications
Description
Sprocket hole pitch
Ordinate to adjacent component lead
PTR030V0090~PTR030V0300
PTR030V0400
PTR030V0500~PTR030V0900
Device pitch PTR030V0090~PTR030V0300
Device pitch PTR030V0400~PTR030V0900
Lead spacing
Carrier tape width
Top distance between tape edges
Hold-down tape width
Sprocket hole position
Abscissa to top PTR030V0090~PTR030V0300
Abscissa to top PTR030V0400~PTR030V0900
Abscissa to plane (straight lead)
Abscissa to plane (kinked lead)
Sprocket hole diameter
Lead protrusion
Tape thickness
Body lateral deviation
Body tape plane deviation
Reel width
Reel diameter
Arbor hole diameter
Core diameter
* See Dimensions table.
2
www.eaton.com/electronics
Figure/
Lead Style
Straight Kink
TR
TR1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
Style 1
Style 2
Figure 1 - PTR030V0090-PTR030V0400
IEC
Mark
P0
Dimension Tolerance
(mm)
(mm)
12.7
0.3
P1
3.6
1.0
P1
3.45
1.0
P1
P
P
C
W
W0
W1
W2
H1
H1
H
H0
D0
L1
t
Δh
Δp
W3
7.3
12.7
25.4
18
3.0
12
9.0
32.2
47.5
18.0
16.0
4
1
0.9
340
31
80
1.0
1.0
1.0
-1.0
Max.
1.0
+0.75/-0.5
Max.
Max.
+2/-0
±0.5
±0.2
Max.
Max.
±1.0
±0 1.3
Max.
±10
±1
Min.
n0
n
Figure 2 - PTR030V0500-PTR030V0900
Reel specification
PTR030V
Technical Data 4400
Time-to-Trip Curves at +23 °C
A
1000
B
C D
E
F
H
I
G
K
L
MN
A:PTR030V0090
B:PTR030V0110
C :PTR030V0135
D :PTR030V0160
100
E:PTR030V0185
H :PTR030V0300
I:PTR030V0400
J :PTR030V0500
10
K:PTR030V0600
L:PTR030V0700
M :PTR030V0800
N :PTR030V0900
1
0 .1
0 .0 1
0 .1
1
F au lt Cu rre n t (A)
10
100
Thermal Derating Curve
P erc entage of D erated C urrent
T IM E IN SEC O N D S
F :PTR030V0250
180.0
160.0
140.0
120.0
100.0
80.0
60.0
40.0
20.0
0.0
-40
-20
Tem perature (°C)
60
80
3
PTR030V
Technical Data 4400
Recommended Wave Solder Profile.
P re h e a tin g
So ld e rin g
Environmental Specifications
Characteristic
Operating Temperature Range
Surface Temperature Trip State
Thermal Shock
Co o lin g
260°C max
T e m p e ra ture
No te 2
Solvent Resistance
Humidity Age Test
No te 3
130 ± 200°C
No te 1
T am b
t
3 0 ~9 0 se c
Notes:
1. (1-3) °C/sec
2. Approximately 200 °C/sec
3. 5 °C/sec Maximum
很抱歉,暂时无法提供与“PTR030V0300-TR1”相匹配的价格&库存,您可以联系我们找货
