ATC-1
ATC-1
    EATON(伊顿)
    FUSE AUTO 1A 32VDC BLADE
ATC-1 数据手册
Technical Data 2009 Effective December 2015 Supersedes October 2014 BUSSMANN SERIES ATC Blade fuses Features and benefits: Product description: A range of UL® Recognized fast-acting ATC blade fuses for automotive and low-voltage control circuits. Featuring the same form, fit, and electrical and performance characteristics, ATC fuses are available in a variety of housing materials specific to orderable catalog numbers to meet application needs. • Industry standard color coding for quick identification of amp rating • Tin-plated zinc terminals for corrosion resistance and enhanced conductivity • UL Recognized for use in low voltage control circuits • Wide -40°C to +100°C operating temperature range meets the needs of extreme environments • Lead free, halogen free and RoHS complaint • Test points on specific part/package numbers may speed up circuit troubleshooting ATC blade fuses Technical Data 2009 Effective December 2015 Catalog symbol: ATC Electrical characteristics @23°C* for all available catalog numbers Applications: Automotive and low-voltage control circuits. • % of fuse amp rating Min 110 135 160 200 350 600 Ratings: • Volts • Amps • Interrupting rating • • • 32V 1-40A * Fuse derating with change in ambient temperature = -0.15% / 1°C 1kA ** 135% Operating time of less than 4 amps. Recommended fuse panels, holders and fuseclips Agency information: • UL Recognized File E56412, Guide JFHR2, UL 248-1 (1-40A). • ISO 8820-3 / SAE J1284 / JASO 612 (1-40A). • SAE J1171 (Ignition protection) see catalog number tables for specific orderable product. RoHS compliant • HHG Tin-plated zinc Element • • HHR Tin-plated zinc • Housing (see catalog number tables for specific housing materials) • Housing flammability rating • HHC HHF Terminals • Part no. 15600-_-20 HHD Materials: • Operating time (sec) Max 100 Hrs — 0.75 120 (240**) 0.25 50 0.15 5 0.04 0.5 0.02 0.1 UL 94 Environmental: BP/HHS-RP BP/HHA-RP ATC-FHID 1A5600* 1A5780* Description ATC Fuse panel in 4- to 20-poles Yellow, water resistant in-line fuse holder Black, heavy-duty in-line fuse holder Black, in-line fuse holder w/ cover Black, heavy-duty in-line fuse holder w/cover Heavy-duty, water resistant inline fuse holder Self-stripping in-line fuse holder Add-A-Fuse Illuminating in-line fuse holder PCB Fuseclip PCB Fuseclip Max Lead wire amps length/size 20A — 20A 2x4”/#16 30A 2x4”/#12 20A 2x4”/#14 30A 2x4”/#12 30A 2x5”/#12 20A 10A 20A 20A 15A #18 to #14 N/A 2x6”/#16 — — * See Data Sheet No. 2131 for details. • Operating temperature range -40°C to 100°C, 95% RH non-condensing. • Storage temperature range -5°C to 35°C or lower, 85% RH non-condensing. Dimensions - mm Basic part numbers* 19.10 Part number (amp) ATC-1 ATC-2 ATC-3 ATC-4 ATC-5 ATC-7½ ATC-10 Color code Black Gray Violet Pink Tan Brown Red Part number (amp) ATC-15 ATC-20 ATC-25 ATC-30 ATC-35 ATC-40 Color code Blue Yellow Clear Green Blue/Green Orange Test points on select constructions. See catalog number tables for details. 5.10 4.0 2.29 * See catalog number tables on page four for specific construction, housing material and package availability. 18.70 6.42 0.65 4.0 3.65 14.5 Dimensions shown are basic for all ampacities, constructions and housing materials. 2 Eaton.com/bussmannseries ATC blade fuses Technical Data 2009 Effective October 2015 Time in seconds Time-current characteristic curves — average melt - for all fuse constructions/housing materials Current in amps Eaton.com/bussmannseries 3 ATC blade fuses Technical Data 2009 Effective December 2015 ATC fuse construction and housing material availability by catalog number Table 1. ATC fuse catalog number availability for open body housing without test points* Reload ATC-5RLD ATC-7½RLD ATC-10RLD ATC-15RLD ATC-20RLD ATC-25RLD ATC-30RLD — Bulk packs BK/ATC-5 BK/ATC-7½ BK/ATC-10 BK/ATC-15 BK/ATC-20 BK/ATC-25 BK/ATC-30 — Blister packs BP/ATC-5-RP BP/ATC-7½-RP BP/ATC-10-RP BP/ATC-15-RP BP/ATC-20-RP BP/ATC-25-RP BP/ATC-30-RP — Assortments/kits/trays BP/ATC-A5-RP (fuse assortment) BP/ATC-AH8-RPP (fuse emergency kit) BP/ATC-AL8-RP (low amp assortment) DIA-1 (diagnostic kit) NO.44 (fuse emergancy kit) NO.80 (bulk assortment) NO.95BK (ATC/ATM bulk assortment) NO.53 (ATC/MAX fuse emergency kit) NO.160BK (bulk assortment) NO.225 (tilt bin assortment) Housing material Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon Nylon * For specific quantities and amp ratings, see consumer aftermarket product catalog No. 5084. Table 2. ATC fuse catalog number availability for closed body housing with test points and SAE J1171 ignition protected Reload — — ATC-3RLD ATC-4RLD — — — — — — — — — — Bulk packs* BK/ATC-1 BK/ATC-2 BK/ATC-3 BK/ATC-4 BK/ATC-5M BK/ATC-71/2M BK/ATC-10M BK/ATC-15M BK-ATC-20M BK-ATC-25M BK-ATC-30M BK-ATC-35 BK-ATC-40 — Blister packs BP/ATC-1-RP BP/ATC-2-RP BP/ATC-3-RP BP/ATC-4-RP — — — — — — — — BP/ATC-40-RP — 5-in tins** ATC-1 ATC-2 ATC-3 ATC-4 ATC-5 ATC-71/2 ATC-10 ATC-15 ATC-20 ATC-25 ATC-30 ATC-35 ATC-40 — Value packs — — — — VP/ATC-5-RP VP/ATC-7-1/2-RP VP/ATC-10-RP VP/ATC-15-RP VP/ATC-20-RP VP/ATC-25-RP VP/ATC-30-RP — — — — — — — — Assortments — — — — — — — — — — — — — CDY10TRY-ATC (fuse tray)*** NO.290† Housing material Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polysulfone Polyethersulfone — — * 2000 fuses per pack. ** 5 fuses per tin. *** Contains (5 each) – ATC 3, 4, 5,and 7-1/2. (10 each) – ATC 10, 15, 20, 25, 30, 35 and 40A. † Contains one 5-in tin each of ATC 3, 4, 5, 7 1/2, 10, 15, 20, 25, 30, 35 and 40A. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2009 – BU-SB13997 December 2015 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
ATC-1 价格&库存
很抱歉,暂时无法提供与“ATC-1”相匹配的价格&库存,您可以联系我们找货
ATC-1
    库存:584
