1332-26-1-0500-012-1-TS 数据手册
P/N 1332-26-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: FEP Material)
UL1332 - FEP Insulated Hook-Up Wire 200°C 300V (26 AWG)
CONSTRUCTION:
CERTIFICATION & APPROVALS:
Tinned Strands, copper conductor, 7/0.16 mm strands.
Overall Diameter = 1.15 mm ± 0.10 mm
Insulation Thickness: 0.33 mm
UL RATED AWM: Can be used in the USA.
UL Subject 758 UL FILE NO:E108485
Printed Markings:
“AWM 1332 200℃ 300V E108485 26AWG REIHSING VW-1 ”
Passes UL VW-1 Vertical Flame Test.
PHYSICAL
ELECTRICAL PROPERTIES:
APPLICATIONS:
PACKAGING:
ENVIRONMENTAL APPROVALS:
Rated Temperature: 200℃ ~ -80℃
Rated Voltage: 300V
Insulation Potential Strength: 2000 VAC/min
Flexibility: hard FEP material, is slightly more rigid than
PVC insulation material.
Maximum Conductor Resistance: 152 Ω/km
Resistant to: Chemical solvents, abrasion, cutting,
extremes of hot & cold, flexing, shock, compression.
FEP wire, has good resistance to extremes of temp.,
compression and repeat flexing. Suitable for use in whole
sealed cooking appliances, auto headlamps, internal
combustion engine and mercury switches, when shock or
sharp casing edges are a “wear and tear” factor.
500ft per reel.
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC. Current SGS reports for this wire
are available upon request.
P/N's & COLORS
1332-26-1-0500-001-1-TS
1332-26-1-0500-002-1-TS
1332-26-1-0500-003-1-TS
1332-26-1-0500-004-1-TS
1332-26-1-0500-005-1-TS
BLACK
WHITE
YELLOW
RED
BLUE
1332-26-1-0500-007-1-TS
1332-26-1-0500-008-1-TS
1332-26-1-0500-010-1-TS
GREEN
ORANGE
VIOLET
GRAY
1332-26-1-0500-006-1-TS
BROWN
1332-26-1-0500-012-1-TS 价格&库存
很抱歉,暂时无法提供与“1332-26-1-0500-012-1-TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+3.565854000+0.45740
