1332-24-1-0500-008-1-TS
    CNC
    FEPTEFWIREOR500'
1332-24-1-0500-008-1-TS 数据手册
P/N 1332-24-1-0500-0XX-1-TS (Conductor: Tinned strands) (Insulation: FEP Material) UL1332 - FEP Insulated Hook-Up Wire 200°C 300V (24 AWG) CONSTRUCTION: CERTIFICATION & APPROVALS: Tinned Strands, copper conductor, 7/0.20 mm strands. Overall Diameter = 1.30 mm ± 0.10 mm Insulation Thickness: 0.33 mm UL RATED AWM: Can be used in the USA. UL Subject 758 UL FILE NO:E108485 Printed Markings: “AWM 1332 200℃ 300V E108485 24AWG REIHSING VW-1 ” Passes UL VW-1 Vertical Flame Test. PHYSICAL & ELECTRICAL PROPERTIES: APPLICATIONS: PACKAGING: ENVIRONMENTAL APPROVALS: Rated Temperature: 200℃ ~ -80℃ Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min Flexibility: hard FEP material, is slightly more rigid than PVC insulation material. Maximum Conductor Resistance: 88.6Ω/km Resistant to: Chemical solvents, abrasion, cutting, extremes of hot & cold, flexing, shock, compression. FEP wire, has good resistance to extremes of temp., compression and repeat flexing. Suitable for use in whole sealed cooking appliances, auto headlamps, internal combustion engine and mercury switches, when shock or sharp casing edges are a “wear and tear” factor. 500ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 1332-24-1-0500-001-1-TS 1332-24-1-0500-002-1-TS 1332-24-1-0500-003-1-TS 1332-24-1-0500-004-1-TS 1332-24-1-0500-005-1-TS BLACK WHITE YELLOW RED BLUE 1332-24-1-0500-007-1-TS 1332-24-1-0500-008-1-TS 1332-24-1-0500-010-1-TS 1332-24-1-0500-012-1-TS GREEN ORANGE VIOLET GRAY 1332-24-1-0500-006-1-TS BROWN
1332-24-1-0500-008-1-TS 价格&库存
很抱歉,暂时无法提供与“1332-24-1-0500-008-1-TS”相匹配的价格&库存,您可以联系我们找货
