2200/22SBL-1000
2200/22SBL-1000
    DABURNELECTRONICS
    HOOK-UP STRND 600V 22AWG BLU
2200/22SBL-1000 数据手册
#2200 Irradiated PVC Hook-Up Wire UL Style 1429 · VW-1 XLPVC MIL-W-16878 · TYPE B · 600V Description: One conductor, tinned copper with .010" irradiated PVC insulation (XLPVC). Daburn's irradiated PVC Hook-up wire is made from extruded polyvinyl chloride insulation which has been exposed to controlled radiation. This exposure causes the insulation to become far superior to ordinary PVC in temperature, abrasion and cut-through resistance. It can withstand direct contact with a soldering iron and it will not shrink back, melt or deform. Ideal for hi-density wiring. Temperature Rating: -55°C to +105°C (UL 1429: 80°C.) Voltage Rating: Type B, 600V, (UL 1429: 150V). This series is RoHS compliant. DABURN Cat. No. Size AWG Strand Nom. O.D. IN. MM. Standard Packaging 2200/28 28 7/36 0.035 0.89 100', 1000' 2200/26 26 7/34 0.040 1.02 100', 1000' 2200/24 24 7/32 0.045 1.14 100', 1000' 2201/24 24 19/36 0.046 1.17 100', 1000' 2200/24S* 24 SOLID 0.041 1.04 100', 1000' 2201/22 22 19/34 0.052 1.32 100', 1000' 2200/22 22 7/30 0.051 1.30 100', 1000' 2200/22S* 22 SOLID 0.046 1.17 100', 1000' 2201/20 20 19/32 0.059 1.50 100', 1000' 2200/20 20 7/28 0.060 1.52 100', 1000' 2200/20S* 20 SOLID 0.054 1.37 100', 1000' 2201/18 18 19/30 0.070 1.78 100', 1000' 2200/18 18 7/26 0.070 1.78 100', 1000' 2200/16 16 19/29 0.078 1.98 100', 1000' Standard Colors: White, Black, Red, Green, Yellow, Blue, Brown, Orange, Gray, Violet. Additional colors, sizes and constructions to order. Additional mil spec constructions are available to MIL-W-16878/14, MIL-W-16878/15 and MIL-W-16878/16. * Not Mil Spec Approved.
2200/22SBL-1000
1. 物料型号:DABURN #2200 2. 器件简介:这是一种单根导体的锡铜线,外层包裹着辐照PVC(XLPVC)绝缘材料。辐照PVC绝缘材料在温度、耐磨性和抗切割性方面优于普通PVC,能够承受直接接触烙铁而不收缩、熔化或变形,适合高密度布线。 3. 引脚分配:文档中未明确提供引脚分配信息,因为它是关于导线而非集成电路或电子元件。 4. 参数特性: - 温度等级:-55°C至+105°C(UL 1429:80°C) - 电压等级:B型,600V(UL 1429:150V) - 符合RoHS标准 5. 功能详解:文档中未提供具体的功能详解,但提到辐照PVC绝缘导线适合高密度布线,并且具有优异的耐温和耐磨损特性。 6. 应用信息:适用于需要高耐温和耐磨损特性的高密度布线环境。 7. 封装信息:提供了不同尺寸AWG的导线规格,包括股线结构、标称外径、标准包装尺寸(100英尺和1000英尺)。
2200/22SBL-1000 价格&库存
很抱歉,暂时无法提供与“2200/22SBL-1000”相匹配的价格&库存,您可以联系我们找货
