PTR030V0900-BK
PTR030V0900-BK
    EATON(伊顿)
    插件
PTR030V0900-BK 数据手册
Effective October 2017 Supersedes June 2017 Technical Data 4400 PTR030V HALOGEN HF FREE 30 Volt DC radial leaded, PolyTron™ PTC devices Pb Applications • • • • • • • Medical equipment White goods Industrial power transmission Telecommunications Computers and peripherals Consumer and automotive electronics Rechargeable battery packs Agency information • • Product features • • • • • • cURus: Recognized Card: File E343021 (Ihold 0.9-9 A) TUV File: J 50194729 Ordering information/ part number system PolyTron™ radial leaded thru-hole PTC device Maximum 30 V Current ratings from 0.90 A to 9.00 A Fast time-to-trip Low resistance Halogen free, Lead free, RoHS compliant PT R 030V 0160 TR & TR1 On Reels • 0.90-1.60 A - 3000 devices • 1.85-3.00 A - 2000 devices • 4.00-9.00 A - 1000 devices BK & BK1 In Poly Bags • 0.90-1.35 A - 1,000 devices • 1.60-6.00 A - 500 devices • 7.00-9.00 A - 250 devices Specifications Catalog Number PTR030V0090 PTR030V0110 PTR030V0135 PTR030V0160 PTR030V0185 PTR030V0250 PTR030V0300 PTR030V0400 PTR030V0500 PTR030V0600 PTR030V0700 PTR030V0800 PTR030V0900 Notes: Vmax (Vdc) 30 30 30 30 30 30 30 30 30 30 30 30 30 Imax (A) 40 40 40 40 40 40 40 40 40 100 100 100 100 Ihold Itrip @+23 °C @+23 °C (A) (A) 0.90 1.80 1.10 2.20 1.35 2.70 1.60 3.20 1.85 3.70 2.50 5.00 3.00 6.00 4.00 8.00 5.00 10.00 6.00 12.00 7.00 14.00 8.00 16.00 9.00 18.00 -TR PolyTron™ PTC Device Series Radial Leaded Maximum Voltage Current Holding (Ihold) Tape and Reel Packaging and Lead Type Code Lead Codes: TR & BK - Straight Leads, TR1 & BK1 - Kinked Leads Pd Typ. (W) 0.6 0.7 0.8 0.9 1.0 1.2 2.0 2.5 3.0 3.5 3.8 4.0 4.2 Time to Trip (Max.) (A) (sec) 4.50 5.90 5.50 6.60 6.75 7.30 8.00 8.00 9.25 8.70 12.50 10.30 15.00 10.80 20.00 12.70 25.00 14.50 30.00 16.00 35.00 17.50 40.00 18.80 45.00 20.00 Resistance (Ω) Agency Initial (Ri) Post Trip (R1) Information Min. Max. Max. cURus TUV 0.070 0.120 0.22 X X 0.050 0.100 0.17 X X 0.040 0.080 0.13 X X 0.030 0.070 0.11 X X 0.030 0.060 0.09 X X 0.020 0.040 0.07 X X 0.020 0.050 0.08 X X 0.010 0.030 0.05 X X 0.010 0.030 0.05 X X 0.005 0.020 0.04 X X 0.005 0.020 0.03 X X 0.005 0.013 0.02 X X 0.005 0.010 0.02 X X Ihold – Hold current: Maximum current device will pass without interruption in +23 °C still air. Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in +23 °C still air. Vmax: Maximum continuous voltage device can withstand without damage at rated current. Imax: Maximum fault current device can withstand without damage at rated voltage. Pd: Power dissipated from device when in the tripped state in +23 °C still air. Ri (min.): Minimum resistance of device as supplied at +23 °C unless otherwise specified. Ri (max.): Maximum resistance of device as supplied at +23 °C unless otherwise specified. R1 (max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at +23 °C unless otherwise specified.  Technical Data 4400 Effective October 2017 Dimensions - mm Part Number PTR030V0090 PTR030V0110 PTR030V0135 PTR030V0160 PTR030V0185 PTR030V0250 PTR030V0300 PTR030V0400 PTR030V0500 PTR030V0600 PTR030V0700 PTR030V0800 PTR030V0900 A Max. 7.4 7.4 8.9 8.9 10.2 11.4 11.4 14.0 14.0 16.5 19.1 21.6 24.1 B Max Lead Type Straight Kink (-TR) (-TR1) 12.2 12.2 14.2 14.2 13.5 13.5 15.2 15.2 15.7 15.7 18.3 20.5 17.3 21.8 20.1 24.6 24.9 26.6 24.9 29.4 26.7 31.2 29.2 33.7 29.7 34.2 C 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 5.0±0.8 10.0±0.8 10.0±0.8 10.0±0.8 10.0±0.8 10.0±0.8 D Min. 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 E Max. 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 F 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.5±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 0.8±0.02 Packaging/Taping Specifications Description Sprocket hole pitch Ordinate to adjacent component lead PTR030V0090~PTR030V0300 Ordinate to adjacent component lead PTR030V0400 Ordinate to adjacent component lead PTR030V0500~PTR030V0900 Device pitch PTR030V0090~PTR030V0300 Device pitch PTR030V0400~PTR030V0900 Lead spacing Carrier tape width Top distance between tape edges Hold-down tape width Sprocket hole position Abscissa to top PTR030V0090~PTR030V0300 Abscissa to top PTR030V0400~PTR030V0900 Abscissa to plane (straight lead) Abscissa to plane (kinked lead) Sprocket hole diameter Lead protrusion Tape thickness Body lateral deviation Body tape plane deviation Reel width Reel diameter Arbor hole diameter Core diameter * See Dimensions table. 2 www.eaton.com/electronics Figure/ Lead Style Straight Kink TR TR1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 Style 1 Style 2 Figure 1 - PTR030V0090-PTR030V0400 IEC Mark P0 Dimension Tolerance (mm) (mm) 12.7 0.3 P1 3.6 1.0 P1 3.45 1.0 P1 P P C W W0 W1 W2 H1 H1 H H0 D0 L1 t Δh Δp W3 7.3 12.7 25.4 * 18 3.0 12 9.0 32.2 47.5 18.0 16.0 4 1 0.9 0 0 56 340 31 80 1.0 1.0 1.0 -1.0 Max. 1.0 +0.75/-0.5 Max. Max. +2/-0 ±0.5 ±0.2 Max. Max. ±1.0 ±0 1.3 Max. ±10 ±1 Min. n0 n Figure 2 - PTR030V0500-PTR030V0900 Reel specification PTR030V 30 Volt DC radial leaded, PolyTron™ PTC devices Technical Data 4400 Effective October 2017 Time-to-Trip Curves at +23 °C A 1000 B C D E F H I G K L MN A:PTR030V0090 B:PTR030V0110 C :PTR030V0135 D :PTR030V0160 100 E:PTR030V0185 H :PTR030V0300 I:PTR030V0400 J :PTR030V0500 10 K:PTR030V0600 L:PTR030V0700 M :PTR030V0800 N :PTR030V0900 1 0 .1 0 .0 1 0 .1 1 F au lt Cu rre n t (A) 10 100 Thermal Derating Curve P erc entage of D erated C urrent T IM E IN SEC O N D S F :PTR030V0250 180.0 160.0 140.0 120.0 100.0 80.0 60.0 40.0 20.0 0.0 -40 -20 0 20 40 Tem perature (°C) 60 80 www.eaton.com/electronics 3 PTR030V 30 Volt DC radial leaded, PolyTron™ PTC devices Technical Data 4400 Effective October 2017 Recommended Wave Solder Profile. P re h e a tin g So ld e rin g Environmental Specifications Characteristic Operating Temperature Range Surface Temperature Trip State Thermal Shock Co o lin g 260°C max T e m p e ra ture No te 2 Solvent Resistance Humidity Age Test No te 3 130 ± 200°C No te 1 T am b t 3 0 ~9 0 se c Notes: 1. (1-3) °C/sec 2. Approximately 200 °C/sec 3. 5 °C/sec Maximum
PTR030V0900-BK 价格&库存
很抱歉,暂时无法提供与“PTR030V0900-BK”相匹配的价格&库存,您可以联系我们找货
PTR030V0900-BK
    • 80+7.15765
    • 250+5.24870
    PTR030V0900-BK
    • 1+8.423161+1.09045
    • 5+6.965475+0.90174
    • 10+6.4242910+0.83168
    • 50+5.3681350+0.69495
    • 80+5.0888180+0.65879
    • 100+4.96661100+0.64297
    • 250+4.49526250+0.58195
    • 500+4.16357500+0.53901
    • 1000+3.936631000+0.50963
    • 5000+3.718415000+0.48138
    库存:33
    PTR030V0900-BK
    • 80+6.16642
    • 250+4.64295
    库存:750
