2615/24-RD-1000
2615/24-RD-1000
    DABURNELECTRONICS
    2615/24-RD-1000
2615/24-RD-1000 数据手册
Ultra-Flexible Silicone Rubber Wire UL 3132 150°C 300V Daburn Ultra-Flexible Silicone Rubber Wire, has high temperature resistance and high flexibility due to silicone rubber insulation and high strand count conductors. Applications include whole sealed cooking appliances, lighting equipment, computers, electronic equipment, internal combustion engines and mercury switch leads. This wire meets UL Style 3132. Description: Single conductor stranded tinned copper insulated with .016” silicone rubber insulation. This construction allows for a uniform, flexible, concentric, quality construction. Operating Temperature: -40°C to +150°C Voltage Rating: 300 Volts UL (Spark voltage 3,000V) FT2 Flame Rating. This series is RoHS compliant. Catalog Nom. Wall Number AWG Strand Nom. O.D. Inches mm Inches mm Resistance dc at 20°C Ohm/mft Nom. Wt. lbs./mft 2615/16 16 26/30 .016 0.40 091 2.30 4.45 10.15 2615/18 18 41/34 .016 0.40 078 1.98 7.06 6.80 2615/20 20 21/33 .016 0.40 069 1.75 11.2 4.79 2615/22 22 17/34 .016 0.40 .061 1.56 18.1 3.40 2615/24 24 7/32 .016 0.40 056 1.41 28.7 2.49 2615/26 26 7/34 .016 0.40 050 1.28 45.8 1.89 2615/28 28 7/36 .016 0.40 .046 1.18 72.8 1.45 2615/30 30 7/38 .016 0.40 .043 1.10 116.0 1.06 Standard Put-Ups: 100 feet, 500 feet, 1,000 feet Colors Available: Black, Red, White, Green, Yellow, Blue, Brown, Grey, Violet, Orange
2615/24-RD-1000
1. 物料型号:DABURN Ultra-Flexible Silicone Rubber Wire UL 3132。 2. 器件简介:这种电线具有高温耐受性和高灵活性,由于硅橡胶绝缘和高股数导体。 3. 引脚分配:文档中未提供引脚分配信息,因为它是关于电线的。 4. 参数特性: - 工作温度范围:-40°C 至 +150°C。 - 电压等级:300伏特UL(火花电压3000V),FT2火焰等级。 - 符合RoHS标准。 5. 功能详解:电线适用于全封闭烹饪设备、照明设备、计算机、电子设备、内燃机和水银开关引线。 6. 应用信息:适用于高温和需要高灵活性的应用环境。 7. 封装信息:电线的详细规格包括AWG(美国线规)、股数、绝缘厚度、标称外径、20°C时的直流电阻、每英尺重量等。
2615/24-RD-1000 价格&库存
很抱歉,暂时无法提供与“2615/24-RD-1000”相匹配的价格&库存,您可以联系我们找货
