Effective August 2021
Supersedes October 2020
Technical Data 4399
PTR016V
HALOGEN
HF
FREE
16 Volt DC radial leaded, PolyTron™ PTC devices
Pb
Applications
Medical equipment
Telecommunications
White goods
Computers and peripherals
Agency information
Ordering information/
part number system
Product features
cURus: Recognized Card: File E343021 (Ihold 3A-15 A)
TUV File: J 50194729
PolyTron™ radial leaded thru-hole PTC device
Maximum 16 V
Current ratings from 0.9 A to 15 A
Fast time-to-trip
Low resistance
Halogen free, lead free, RoHS compliant
PT
Catalog
Number
PTR016V0090
PTR016V0110
PTR016V0135
PTR016V0160
PTR016V0185
PTR016V0250
PTR016V0300
PTR016V0400
PTR016V0500
PTR016V0600
PTR016V0700
PTR016V0800
PTR016V0900
PTR016V1000
PTR016V1100
PTR016V1200
PTR016V1300
PTR016V1400
PTR016V1500
Notes:
Vmax
(Vdc)
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
Imax
(A)
40
40
40
40
40
40
100
100
100
100
100
100
100
100
100
100
100
100
100
Ihold
@ +23 °C
(A)
0.90
1.10
1.35
1.60
1.85
2.50
3.00
4.00
5.00
6.00
7.00
8.00
9.00
10.00
11.00
12.00
13.00
14.00
15.00
Itrip
@ +23 °C
(A)
1.80
2.20
2.70
3.20
3.70
5.00
5.10
6.80
8.50
10.20
11.90
13.60
15.30
17.00
18.70
20.40
22.10
23.80
25.50
Pd
Typ.
(W)
0.60
0.70
0.80
0.90
1.00
1.20
2.30
2.40
2.60
2.80
3.00
3.00
3.30
3.60
3.70
4.20
4.60
4.60
4.60
R 016V 0090
-TR
PolyTron™ PTC Device Series
Radial Leaded
Maximum Voltage
Current Holding (Ihold)
Packaging and Lead Type Code
Lead Codes: TR & BK - Straight Leads, TR1 & BK1 - Kinked Leads
Time to
Trip (Max.)
(sec)
(A)
8.00
1.20
8.00
2.30
8.00
4.50
8.00
9.00
8.00
10.00
8.00
40.00
15.00
1.00
20.00
1.70
25.00
2.00
30.00
3.30
35.00
3.50
40.00
5.00
45.00
5.50
50.00
6.00
55.00
7.00
60.00
7.50
65.00
8.50
70.00
9.00
75.00
10.00
TR & TR1 On Reels
0.9-1.85 A - 3000 devices
2.5-4 A - 2500 devices
5-7 A - 1500 devices
8-15 A - 1000 devices
BK & BK1 In Poly Bags
• 0.9-1.60 A - 1000 devices
• 1.85-9.00 A - 1000 devices
• 10.00-15.00 A - 250 devices
Resistance (Ω)
Agency
Initial (Ri)
Post Trip (R1)
Information
Min.
Max.
Max.
cURus TUV
0.070
0.120
0.180
X
0.050
0.095
0.140
X
0.040
0.074
0.120
X
0.030
0.061
0.110
X
0.030
0.051
0.090
X
0.020
0.036
0.070
X
0.038
0.065
0.098
X
X
0.021
0.038
0.060
X
X
0.010
0.023
0.034
X
X
0.006
0.018
0.028
X
X
0.006
0.013
0.020
X
X
0.005
0.011
0.018
X
X
0.005
0.009
0.014
X
X
0.004
0.007
0.010
X
X
0.003
0.006
0.009
X
X
0.003
0.006
0.009
X
X
0.002
0.006
0.008
X
X
0.002
0.005
0.007
X
X
0.002
0.005
0.007
X
X
I hold – Hold current: Maximum current device will pass without interruption in +23 °C still air.
Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in +23 °C still air.
Vmax: Maximum continuous voltage device can withstand without damage at rated current.
Imax: Maximum fault current device can withstand without damage at rated voltage.
Pd: Power dissipated from device when in the tripped state in +23 °C still air.
Ri (min.): Minimum resistance of device as supplied at +23 °C unless otherwise specified.
R1(max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at +23 °C unless otherwise specified.
Technical Data 4399
Dimensions - mm
Part
Number
PTR016V0090
PTR016V0110
PTR016V0135
PTR016V0160
PTR016V0185
PTR016V0250
PTR016V0300
PTR016V0400
PTR016V0500
PTR016V0600
PTR016V0700
PTR016V0800
PTR016V0900
PTR016V1000
PTR016V1100
PTR016V1200
PTR016V1300
PTR016V1400
PTR016V1500
A
Max.
7.4
7.4
8.9
8.9
10.2
11.4
7.1
8.9
10.4
10.7
11.2
12.7
14.0
16.5
17.5
17.5
21.6
23.5
25.1
B Max
Lead Type
Straight Kink
(-TR) (-TR1)
12.2 12.2
14.2 14.2
13.5 13.5
15.2 15.2
15.7 15.7
18.3 20.5
11.0 14.0
12.8 14.8
14.3 16.0
17.1 19.0
19.7 22.0
20.9 23.0
21.9 24.0
25.2 28.0
26.0 29.0
28.0 31.0
29.2 32.0
27.9 30.0
29.0 32.0
C
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
D
Min.
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
E
Max.
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
3.5
F
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
1.0±0.02
1.0±0.02
1.0±0.02
1.0±0.02
Packaging/Taping Specifications
Description
Sprocket hole pitch
Ordinate to adjacent component lead:
PTR016V0090~PTR016V0250
PTR016V0300~PTR016V1100
PTR016V1200~PTR016V1500
Device pitch:
PTR016V0090~PTR016V0600
PTR016V0700~PTR016V1400
PTR016V1500
Lead spacing
Carrier tape width
Top distance between tape edges
Hold-down tape width
Sprocket hole position
Abscissa to top:
PTR016V0700~PTR016V1500
Abscissa to plane
(straight lead)
(kinked lead)
Sprocket hole diameter
Lead protrusion
Tape thickness
Body lateral deviation
Body tape plane deviation
Reel width
Reel diameter
Arbor hole diameter
Core diameter
* See Dimensions table.
2
www.eaton.com/electronics
IEC
Mark
P0
Dimension Tolerance
(mm)
(mm)
12.7
±0.3
P1
P1
P1
3.6
4.5
7.2
±1.0
±1.0
±1.0
P
P
P
C
W
W0
W1
W2
12.7
25.4
38.1
18
3.0
12
9.0
±1.0
±1.0
±1.0
-±1.0
Max.
±1.0
+0.75/-0.5
H1
H1
32.2
47.5
Max.
Max.
H
H0
D0
L1
t
Δh
Δp
W3
18.0
16.0
4
1
0.9
340
31
80
+2/-0
±0.5
±0.2
Max.
Max.
±1.0
±1.3
Max.
±10
±1
Min.
n0
n
Figure/
Lead Style
Straight Kink
TR
TR1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
Style 1
Style 2
Style 1 - PTR016V0090, PTR016V0110, PTR016V0135,
PTR016V0160-PTR016V1000
Style 2 - PTR016V1200-PTR016V1500
Reel Specifications
PTR016V
Technical Data 4399
Time-to-Trip Curves at +23 °C - 0.9-2.5 A
A
1000
C
D
E
F
A:PTR016V0090
B:PTR016V0110
100
C:PTR016V0135
B
D:PTR016V0160
10
TIM E IN S E C O N D S
E:PTR016V0185
F:PTR016V0250
1
0.1
0.01
0.001
1
10
100
Fa u lt Cu rre n t (A )
Time-to-Trip Curves at +23 °C - 3.0-15 A
G
H
I
J
K
L
M
N O P Q
R S
1000
G:PTR016V0300
H:PTR016V0400
100
I:PTR016V0500
J:PTR016V0600
K:PTR016V0700
10
TIM E IN S E CO N D S
L:PTR016V0800
M:PTR016V0900
N:PTR016V1000
1
O:PTR016V1100
P:PTR016V1200
0 .1
Q:PTR016V1300
R:PTR016V1400
S:PTR016V1500
0 .0 1
0 .0 0 1
1
10
100
F ault Current (A )
3
PTR016V
Technical Data 4399
P erc entage of D erated C urrent
Thermal Derating Curve
200.0
180.0
160.0
140.0
120.0
100.0
80.0
60.0
40.0
20.0
0.0
-40
-20
Tem perature (°C)
Recommended Wave Solder Profile
P re h e a tin g
So ld e rin g
Co o lin g
T e m p e ra ture
No te 2
Solvent Resistance
Humidity Age Test
No te 3
130 ± 200°C
No te 1
T am b
Notes:
t
很抱歉,暂时无法提供与“PTR016V1400-BK1”相匹配的价格&库存,您可以联系我们找货
