2215/22OR-1000
2215/22OR-1000
    DABURNELECTRONICS
    2215/22OR-1000
2215/22OR-1000 数据手册
#2215 Irradiated PVC Hook-Up Wire UL Style 1430 · VW-1 · CSA REW XLPVC MIL-W-16878 · TYPE C · 1000V Description: One conductor, stranded tinned copper with .016" irradiated PVC insulation (XLPVC). Daburn's irradiated PVC Hook-up wire is made from extruded polyvinyl chloride insulation which has been exposed to controlled radiation. This exposure causes the insulation to become far superior to ordinary PVC in temperature, abrasion and cut-through resistance. It can withstand direct contact with a soldering iron and it will not shrink back, melt or deform. Ideal for hi-density wiring. Temperature Rating: -55°C to +105°C (UL 1430: 105°C.) Voltage Rating: 1,000V, (UL 1430: 300V; CSA; XLPVC). This series is RoHS compliant. DABURN Cat. No. Size AWG Strand 2215/28 28 2215/26 Nom. O.D. IN. MM. Standard Packaging 7/36 0.047 1.19 100', 1000' 26 7/34 0.050 1.27 100', 1000' 2215/24 24 7/32 0.056 1.42 100', 1000' 2215/22 22 7/30 0.062 1.57 100', 1000' 2215/20 20 7/28 0.070 1.78 100', 1000' 2215/18 18 7/26 0.082 2.08 100', 1000' 2215/16 16 19/29 0.093 2.36 100', 1000' Standard Colors: White, Black, Red, Green, Yellow, Blue, Brown, Orange, Gray, Violet. Additional colors, sizes and constructions to order. Additional mil spec constructions are available to MIL-W-16878/14, MIL-W-16878/15 and MIL-W-16878/16.
2215/22OR-1000
1. 物料型号:DABURN #2215 2. 器件简介:该线缆由一根导体组成,采用镀锡铜线束,外层为0.016英寸的辐射交联聚氯乙烯(XLPVC)绝缘材料。这种绝缘材料经过控制辐射处理,使其在温度、耐磨性和抗切割性方面远优于普通PVC。它能够承受直接接触烙铁而不收缩、熔化或变形,非常适合高密度布线。 3. 引脚分配:文档中未提供引脚分配信息,因为它是关于线缆的,而不是集成电路或其他有引脚的电子元件。 4. 参数特性: - 温度等级:-55°C至+105°C(UL 1430: 105°C) - 电压等级:1,000V(UL 1430: 300V; CSA; XLPVC) - 符合RoHS标准 5. 功能详解:文档中未提供详细的功能解释,但强调了线缆的耐高温、耐磨和抗切割特性,以及其适合高密度布线的应用。 6. 应用信息:适用于高密度布线,能够承受烙铁直接接触而不损坏。 7. 封装信息:提供了不同AWG尺寸的线缆规格,包括线束结构、标称外径,以及标准包装长度(100英尺和1000英尺)。 8. 标准颜色:白色、黑色、红色、绿色、黄色、蓝色、棕色、橙色、灰色、紫罗兰色。可按订单提供额外的颜色、尺寸和结构。还提供符合MIL-W-16878/14、MIL-W-16878/15和MIL-W-16878/16的额外军规结构。
2215/22OR-1000 价格&库存
很抱歉,暂时无法提供与“2215/22OR-1000”相匹配的价格&库存,您可以联系我们找货
