FP10A12HP
FP10A12HP
    VECTOR
    PANEL FILLER 6UX12HP W/EMC GASK
FP10A12HP 数据手册
7 8 6 4 5 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VECTOR ELECTRONICS & TECH., INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VECTOR ELECTRONICS & TECH., INC. IS PROHIBITED. 2 3 1 REVISIONS 0.230 THRU ZONE REV ALL A B 0.130 THRU 3X 0.233 REDRAWN ADDED FP52A5HP, FP10A5HP, AND FP15A5HP APPROVED DETAIL A SCALE 4 : 1 N PLACES EMC GASKET SIDE D 0.098 DATE 05/04/12 02/23/15 0.081 0.042 W DESCRIPTION D +0.000 - 0.012 RETAINER SLEEVE, POLYMAIDE, BLACK, P/N 94300008 M2.5 X 0.45 X 11mm CAPTIVE SCREW, STEEL, P/N 95000002B (N PLACES) 0.012 A A 0.630 0.630 0.008 A EMC GASKET, BeCu WITH BRIGHT NICKEL, P/N 93400015B C C FILLER PANEL H 0.006 C 0.008 B PART NO DESCRIPTION HEIGHT "H" WIDTH "W" CENTER "C" MOUNTING HOLE "MHE" PLACES "N" FP52A4HP 3U X 4HP 5.060 0.788 4.823 0.294 2 FP52A5HP 3U X 5HP 5.060 0.988 4.823 0.445 2 FP52A8HP 3U X 8HP 5.060 1.588 4.823 0.294 4 FP52A12HP 3U X 12HP 5.060 2.388 4.823 0.294 4 FP10A4HP 6U X 4HP 10.310 0.788 10.073 0.294 2 FP10A5HP 6U X 5HP 10.310 0.988 10.073 0.445 2 FP10A8HP 6U X 8HP 10.310 1.588 10.073 0.294 4 FP10A12HP 6U X 12HP 10.310 2.388 10.073 0.294 4 FP15A4HP 9U X 4HP 15.560 0.788 15.323 0.294 2 FP15A5HP 9U X 5HP 15.560 0.988 15.323 0.445 2 FP15A8HP 9U X 8HP 15.560 1.588 15.323 0.294 4 FP15A12HP 9U X 12HP 15.560 2.388 15.323 0.294 4 B A 0.630 0.630 0.119±0.004 SHOWN FILLER PANEL ASSEMBLY 2X MHE±0.004 2X MHE±0.004 5 FILLER PANEL DETAIL A 5. FURNISHED UNASSEMBLED 4. FINISH: CLEAR CHEM FILM, IAW MIL-C-5541, CLASS 3 3. LIGHT GRAIN FRONT SURFACE IN DIRECTION OF MATERIAL GRAIN (AS SHOWN) USING 180 GRIT 2. MATERIAL: ALUMINUM EXTRUSION, 6063-T5 MAKE FROM P/N # M4211-XX 1. REMOVE ALL BURRS, SHARP EDGES & SURFACE SCRATCHES UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES TOLERANCES: 0.1 DEC X.X 0.03 DEC X.XX DEC X.XXX 0.010 0.050 FRACTIONS ANGLES 1 GD & T : ASME Y14.5-2009 3 NOTES : UNLESS OTHERWISE SPECIFIED 8 7 6 5 4 MATERIAL 2 FINISH 4 APPROVALS NAME DATE DRAWN TRUSHAR 05/04/12 CHECKED ENGINEER QA 11115 VANOWEN ST., NORTH HOLLYWOOD, CA 91605 www.vectorelect.com 3U, 6U, 9U EMC FILLER PANEL SIZE THIRD ANGLE PROJECTION DWG. NO. D SCALE: 2:1 3 2 REV FPXXAXHP B CAGE CODE: 82893 SHEET 1 OF 1 1 A
FP10A12HP 价格&库存
很抱歉,暂时无法提供与“FP10A12HP”相匹配的价格&库存,您可以联系我们找货
