5261304-07
5261304-07
    VECTOR
    PANEL FILLER 6UX4HP ASSEMBLY
5261304-07 数据手册
7 8 6 4 5 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VECTOR ELECTRONICS & TECH., INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VECTOR ELECTRONICS & TECH., INC. IS PROHIBITED. 2 3 1 REVISIONS ZONE REV ALL A 0.230 THRU W +0.000 /-0.012 DESCRIPTION REDRAWN DATE 05/04/12 APPROVED 0.130 THRU DETAIL A SCALE 4 : 1 N PLACES D D 0.100 A 0.012 A 0.008 A RETAINER SLEEVE, POLYAMIDE, BLACK, 94300008 M2.5 X 0.45 X 11mm CAPTIVE SCREW, STEEL, 95000002B (NX) C C FILLER PANEL H 0.006 C 0.008 B A PART NO DESCRIPTION HEIGHT "H" WIDTH "W" CENTER "C" MOUNTING HOLE "MHE" PLACES "N" 5231304-07 3U X 4HP 5.060 0.788 4.823 0.294 2 5231308-07 3U X 8HP 5.060 1.588 4.823 0.294 4 5231312-07 3U X 12HP 5.060 2.388 4.823 0.294 4 5231342-07 3U X 42HP 5.060 8.388 4.823 0.294 4 5261304-07 6U X 4HP 10.310 0.788 10.073 0.294 2 5261308-07 6U X 8HP 10.310 1.588 10.073 0.294 4 5261312-07 6U X 12HP 10.310 2.388 10.073 0.294 4 5261324-07 6U X 24HP 10.310 4.788 10.073 0.294 4 5291304-07 9U X 4HP 15.560 0.788 15.323 0.294 2 5291308-07 9U X 8HP 15.560 1.588 15.323 0.294 4 5291312-07 9U X 12HP 15.560 2.388 15.323 0.294 4 SHOWN FILLER PANEL ASSEMBLY 0.119±0.004 2X MHE±0.004 (ONLY APPLIES TO PANELS 8HP AND LARGER) 2X MHE ±0.004 MHE±0.004 FILLER PANEL DETAIL UNLESS OTHERWISE SPECIFIED A 4. FINISH: CLEAR CHEM FILM, IAW MIL-C-5541, CLASS 3 3. LIGHT GRAIN FRONT & BACK SURFACE IN DIRECTION SHOWN USING 180 GRIT 2. MATERIAL: ALUMINUM ALLOY 6061-T6, 0.100 THICK MAKE FROM P/N # 0030-55-48B 1. REMOVE ALL BURRS, SHARP EDGES & SURFACE SCRATCHES DIMENSIONS ARE IN INCHES TOLERANCES: DEC .X .1 DEC .XX .03 .010 DEC .XXX .050 FRACTIONS ANGLES 1 3 NOTES : UNLESS OTHERWISE SPECIFIED 8 7 B 6 5 4 MATERIAL 2 FINISH 4 APPROVALS NAME DATE DRAWN TRUSHAR 05/04/12 11115 VANOWEN ST., NORTH HOLLYWOOD, CA 91605 www.vectorelect.com 3U, 6U, 9U NON EMC FILLER PANEL CHECKED ENGINEER QA SIZE THIRD ANGLE PROJECTION DWG. NO. D SCALE: 2:1 3 2 REV 52RU304-HP A CAGE CODE: 82893 SHEET 1 OF 1 1 A
5261304-07 价格&库存
很抱歉,暂时无法提供与“5261304-07”相匹配的价格&库存,您可以联系我们找货
