CCK13F/90
CCK13F/90
    VECTOR
    CARD RACK KIT 3UX19X9 FRAME ONLY
CCK13F/90 数据手册
EIA - Based Subracks Vector-Pak® System CCA13S/90 shown with piece parts CMA13-20/90 - Module Subrack with 8 EFP modules, 2" wide EIA-Based Subracks Designed in accordance with EIA standard RS-310, Vector subracks and modules offer versatility within a 19" rackmount format. All racks are adjustable in both height and depth, offering standard product solutions for standard and custom requirements. All Subrack sizes are compatible with Vector prototyping boards (see Vectorbord® section,), and can accommodate other sizes as well. Several card guide types (metal or plastic, snap-in, rivet, or screw-down) are available. Subrack & Module Rack Types by Part Number Stem 1. CCK Card cage frame kit-easy assembly kits. Available with and without guides. Accepts Snap-in plastic, rivet or screw-down guides, plastic or metal. Guide spacing is .25". 2. CCA Same as CCK version, but assembled with guides. 3. CMA Assembled module rack for EFP modules. Modules available separately. 4. CCM Assembled rack for card mount modules (CM type); Modules available separately. Model Type H X W X D Versions CCA,K 12/90 CCA,K 13/90 CCA,K 14/90 CCA,K 15/90 CCA,K 17/90 CCK 18/90 CCK 100S/90 CCM 13/90 3U 3U 3U 4U 5U 6U 7U 3U Assembled or kit Assembled or kit Assembled or kit Assembled or kit Assembled or kit Frame kit only Kit Assembled or kit X X X X X X X X 19" 19" 19" 19" 19" 19" 19" 19" X 9" X 9" X 12" X 12" X 12" X 15.75" X 9" X 9" Max. Card Size 4.5" X 6.5" 4.5" X 6.5" 4.5" X 9.6" 7" X 9.6" 8.75" X 12.0" 9.75" X 13.5" Model Type H X W X D Versions CCM CCM CMA CMA CMA CMA CMA 3U 4U 3U 3U 3U 3U 3U Assembled Assembled Assembled Assembled Assembled Assembled Assembled 14/90 15/90 13-16/90 13-20/90 14-16/90 14-20/90 14-30/90 X X X X X X X 19" 19" 19" 19" 19" 19" 19" X X X X X X X 12" 12" 9" 12" 12" 12" 12" only only only only only only only Max. Card Size 4.5" X 9.6" 4.5" X 9.6" 4.5" X 6.5" 4.5" X 6.5" 4.5" X 9.6" 4.5" X 9.6" 4.5" X 9.6" 4.5" X 6.5" CCK Model 13 - S or - XX - H /90 Type Note: /90 denotes side walls with .200" slot width CCK - Kit only with snap-in card guides CCA - Factory assembled version of CCK with snap-in card guides CCM - Factory assembled card mount cage with snap-in card guides CMA - Assembled module cage with module guides Additional Qualifiers CMA13 or 14 - XX /90 16 - Designed for 1.6" wide modules 20 - Designed for 2.0" wide modules 30 - Designed for 3.0" wide modules Series Number 12 13 14 15 17 18 100 - 3U (5.25") X 19" X 9" - 3U (5.25") X 19" X 9" - 3U (5.25") X 19" X 12" - 4U (7.00") X 19" X 12" - 5U (8.75") X 19 X 12" - 6U (10.50") X 19" X 15.75" - 7U (12.25") X 19" X 9" H - Half size CCK Type F - Frame only; snap-in plastic, metal or plastic screw down card guides available separately S - Snap-in guides included 11115 Vanowen ST., N.Hollywood, CA 91605 Phone(818)985-8208 Fax(818)985-7708 Toll-Free (800) 423-5659 Products EIA- Based Subrack Ordering Information EIA - Based Vector-Pak® System Subracks, Card Mount Modules & Card-Mount • • • • • • Racks System Guide positions at .25" increments Adjustable slots Construction: .080" thick aluminum, clear anodized finish Sidewall slots provide adjustability to 1" For 4.5" X 6.5" cards Rear struts for mounting connectors CCA13S/90 - Assembled Subrack with 21 pairs of Snap-In Guides Subrack with continuous groove guide plates allows maximum flexibility in card placement. Guide Plate Detail CCA13C/90 - Assembled Subrack with continuous guide plate General Proto Products CCK13F is a subrack frame kit. It will accept cardmount modules and snap-in (CG2-65S) or screw-mount card guides (CG2-65M, CG2-65P). CCK13F - Subrack Frame only Part No. Description Dimensions (H x W x D) Version CCK12S/90 CCK13F/90 CCA13S/90 CCA13C/90 CCK13S-H/90 CCK13S-HT/90 CCK14F/90 CCA14S/90 CCA15S/90 CCA17S/90 CCK18F/90 CCK 100S/90 Card cage kit Card cage frame kit Card cage assembly Card cage assembly Card cage kit Card cage kit Card cage frame kit Card cage assembly Card cage assembly Card cage assembly Card cage frame kit Card cage kit 3U (5.25") X 19" X 9" 3U (5.25") X 19" X 9" 3U (5.25") X 19" X 9" 3U (5.25") X 10" X 9" 3U (5.25") X 10.25" X 9" 3U (5.25") X 8.24" X 8.12" 3U (5.25") X 19" X 12" 3U (5.25") X 19" X 12" 4U (7.00") X 9" X 12" 5U (8.75") X 19" X 12" 6U (10.50") X 19" X 15.75" 7U (12.25") X 19" X 9" Kit with 21 pairs of snap-in guides Frame only Assembled with 21 pairs of snap-in guides Assembled with continuous guide plate (see above) Half-size kit with 11 pairs of snap-in guides Modified, half-size kit with 11 pairs of snap-in guides Frame only Assembled with 21 pairs of snap-in guides Assembled with 21 pairs of snap-in guides Assembled with 21 pairs of snap-in guides Frame only Kit with 21 pairs of snap-in guides Specifications subject to change without notice. EIA - Based Subracks, Card Mount Modules & Vector-Pak® System Racks Universal Card-Mount System • Accepts CM45A65 Card Mount Modules • Card guide positions are variable at .25" increments • Assembled module rack with plastic snap-in guides installed on 1" centers • Different width modules may be inserted interchangeably without guide changes • Card mount modules (CM Series) with 1" to 4" widths • For 3U and 4U applications • Adjustable rear struts for connection of backplanes (struts available separately) • .062" thick aluminum plates are inserted into guide; PC Card is attached firmly to plate • Front panels on card mount may be removed for custom punching, plating and printing • Modules may be secured by thumb screws (SC10-3A, 10-32 included) CCM 13S/90 - Card Module Rack with assorted cardmount modules L H2 B H1 1.55" C CCM 15S/90 - Assembled Subrack (shown with optional Dress Panels and Handles) W Card Mount Module Dimensions # Of Card Guides Versions Card Size CCM13S/90 CCM14S/90 CCM15S/90 3U X 19" X 9" 3U X 19" X 12" 4U X 19" X 12" 16 pairs on 1" Ctrs. 16 pairs on 1" Ctrs. 16 pairs on 1" Ctrs. Assembled Assembled Assembled 4.5" X 6.5" 4.5" X 9.6" 6.25" X 9.6" Height Part No. H1 H2 Width Length W L B C Products Part No. Module Card Rack Guide CM45A65-1 5.25" 4.5" 1.0" 6.57" 3.8" 3.6" CCM13S CG2-65 CM45B95-1 5.25" 4.5" 1.0" 9.57" 3.8" 6.6" CCM14S CG2-95 CM45A65-2 5.25" 4.5" 2.0" 6.57" 3.8" 3.6" CCM13S CG2-65 CM45B95-2 5.25" 4.5" 2.0" 9.57" 3.8" 6.6" CCM14S CG2-95 CM62F95-2 7.0" 6.25" 2.0" 9.57" 5.5" 6.6" CCM15S CG2-95 CM45A65-4 5.25" 4.5" 4.0" 6.57" 3.8" 3.6" CCM13S CG2-65 CM45B95-4 5.25" 4.5" 4.0" 9.57" 3.8" 6.6" CCM14S CG2-95 Includes hardware, order cages and modules separately 11115 Vanowen ST., N.Hollywood, CA 91605 Phone(818)985-8208 Fax(818)985-7708 Toll-Free (800) 423-5659
CCK13F/90 价格&库存
很抱歉,暂时无法提供与“CCK13F/90”相匹配的价格&库存,您可以联系我们找货
