EIA - Based
Subracks
Vector-Pak® System
CCA13S/90 shown with piece parts
CMA13-20/90 - Module Subrack with 8 EFP
modules, 2" wide
EIA-Based
Subracks
Designed in accordance with EIA standard RS-310, Vector subracks and modules offer versatility within a 19" rackmount format. All
racks are adjustable in both height and depth, offering standard product solutions for standard and custom requirements.
All Subrack sizes are compatible with Vector prototyping boards (see Vectorbord® section,), and can accommodate other sizes as well.
Several card guide types (metal or plastic, snap-in, rivet, or screw-down) are available.
Subrack & Module Rack Types by Part Number Stem
1. CCK Card cage frame kit-easy assembly kits. Available with and without guides. Accepts Snap-in plastic, rivet
or screw-down guides, plastic or metal. Guide spacing is .25".
2. CCA Same as CCK version, but assembled with guides.
3. CMA Assembled module rack for EFP modules. Modules available separately.
4. CCM Assembled rack for card mount modules (CM type); Modules available separately.
Model
Type
H X W X D
Versions
CCA,K 12/90
CCA,K 13/90
CCA,K 14/90
CCA,K 15/90
CCA,K 17/90
CCK 18/90
CCK 100S/90
CCM 13/90
3U
3U
3U
4U
5U
6U
7U
3U
Assembled or kit
Assembled or kit
Assembled or kit
Assembled or kit
Assembled or kit
Frame kit only
Kit
Assembled or kit
X
X
X
X
X
X
X
X
19"
19"
19"
19"
19"
19"
19"
19"
X 9"
X 9"
X 12"
X 12"
X 12"
X 15.75"
X 9"
X 9"
Max. Card Size
4.5" X 6.5"
4.5" X 6.5"
4.5" X 9.6"
7" X 9.6"
8.75" X 12.0"
9.75" X 13.5"
Model
Type
H X W X D
Versions
CCM
CCM
CMA
CMA
CMA
CMA
CMA
3U
4U
3U
3U
3U
3U
3U
Assembled
Assembled
Assembled
Assembled
Assembled
Assembled
Assembled
14/90
15/90
13-16/90
13-20/90
14-16/90
14-20/90
14-30/90
X
X
X
X
X
X
X
19"
19"
19"
19"
19"
19"
19"
X
X
X
X
X
X
X
12"
12"
9"
12"
12"
12"
12"
only
only
only
only
only
only
only
Max. Card Size
4.5" X 9.6"
4.5" X 9.6"
4.5" X 6.5"
4.5" X 6.5"
4.5" X 9.6"
4.5" X 9.6"
4.5" X 9.6"
4.5" X 6.5"
CCK
Model
13
- S or - XX - H
/90
Type
Note: /90 denotes side walls
with .200" slot width
CCK - Kit only with snap-in card guides
CCA - Factory assembled version of CCK with
snap-in card guides
CCM - Factory assembled card mount cage with
snap-in card guides
CMA - Assembled module cage with module guides
Additional
Qualifiers
CMA13 or 14 - XX /90
16 - Designed for 1.6" wide modules
20 - Designed for 2.0" wide modules
30 - Designed for 3.0" wide modules
Series Number
12
13
14
15
17
18
100
- 3U (5.25") X 19" X 9"
- 3U (5.25") X 19" X 12"
- 4U (7.00") X 19" X 12"
- 5U (8.75") X 19 X 12"
- 6U (10.50") X 19" X 15.75"
- 7U (12.25") X 19" X 9"
H - Half size
CCK
Type
F - Frame only; snap-in plastic, metal or plastic screw
down card guides available separately
S - Snap-in guides included
11115 Vanowen ST., N.Hollywood, CA 91605 Phone(818)985-8208 Fax(818)985-7708
Toll-Free (800) 423-5659
Products
EIA- Based Subrack Ordering Information
EIA - Based
Vector-Pak® System
Subracks, Card Mount Modules &
Card-Mount
Racks
System
Guide positions at .25" increments
Adjustable slots
Construction: .080" thick aluminum, clear anodized finish
Sidewall slots provide adjustability to 1"
For 4.5" X 6.5" cards
Rear struts for mounting connectors
CCA13S/90 - Assembled Subrack with 21
pairs of Snap-In Guides
Subrack with continuous groove guide plates allows maximum
flexibility in card placement.
Guide Plate Detail
CCA13C/90 - Assembled Subrack with continuous guide plate
General Proto
Products
CCK13F is a subrack frame kit. It will accept cardmount modules
and snap-in (CG2-65S) or screw-mount card guides (CG2-65M,
CG2-65P).
CCK13F - Subrack Frame only
Part No.
Description
Dimensions (H x W x D)
Version
CCK12S/90
CCK13F/90
CCA13S/90
CCA13C/90
CCK13S-H/90
CCK13S-HT/90
CCK14F/90
CCA14S/90
CCA15S/90
CCA17S/90
CCK18F/90
CCK 100S/90
Card cage kit
Card cage frame kit
Card cage assembly
Card cage assembly
Card cage kit
Card cage kit
Card cage frame kit
Card cage assembly
Card cage assembly
Card cage assembly
Card cage frame kit
Card cage kit
3U (5.25") X 10" X 9"
3U (5.25") X 10.25" X 9"
3U (5.25") X 8.24" X 8.12"
4U (7.00") X 9" X 12"
5U (8.75") X 19" X 12"
Kit with 21 pairs of snap-in guides
Frame only
Assembled with 21 pairs of snap-in guides
Assembled with continuous guide plate (see above)
Half-size kit with 11 pairs of snap-in guides
Modified, half-size kit with 11 pairs of snap-in guides
Frame only
Frame only
Specifications subject to change without notice.
EIA - Based
Vector-Pak® System
Racks
Universal Card-Mount System
• Accepts CM45A65 Card Mount Modules
• Card guide positions are variable at .25" increments
• Assembled module rack with plastic snap-in guides installed on
1" centers
• Different width modules may be inserted interchangeably
without guide changes
• Card mount modules (CM Series) with 1" to 4" widths
• For 3U and 4U applications
• Adjustable rear struts for connection of backplanes (struts
available separately)
• .062" thick aluminum plates are inserted into guide; PC Card is
attached firmly to plate
• Front panels on card mount may be removed for custom
punching, plating and printing
• Modules may be secured by thumb screws (SC10-3A, 10-32
included)
CCM 13S/90 - Card Module
Rack with assorted cardmount modules
L
H2
B
H1
1.55"
C
CCM 15S/90 - Assembled Subrack
(shown with optional Dress Panels and
Handles)
W
Card Mount Module
Dimensions
# Of Card Guides
Versions
Card Size
CCM13S/90
CCM14S/90
CCM15S/90
3U X 19" X 9"
3U X 19" X 12"
4U X 19" X 12"
16 pairs on 1" Ctrs.
Assembled
Assembled
Assembled
4.5" X 6.5"
4.5" X 9.6"
6.25" X 9.6"
Height
Part No.
H1
H2
Width
Length
W
L
B
C
Products
Part No.
Module
Card
Rack
Guide
CM45A65-1
5.25"
4.5"
1.0"
6.57" 3.8" 3.6"
CCM13S
CG2-65
CM45B95-1
5.25"
4.5"
1.0"
9.57" 3.8" 6.6"
CCM14S
CG2-95
CM45A65-2
5.25"
4.5"
2.0"
6.57" 3.8" 3.6"
CCM13S
CG2-65
CM45B95-2
5.25"
4.5"
2.0"
9.57" 3.8" 6.6"
CCM14S
CG2-95
CM62F95-2
7.0"
6.25"
2.0"
9.57" 5.5" 6.6"
CCM15S
CG2-95
CM45A65-4
5.25"
4.5"
4.0"
6.57" 3.8" 3.6"
CCM13S
CG2-65
CM45B95-4
5.25"
4.5"
4.0"
9.57" 3.8" 6.6"
CCM14S
CG2-95
Includes hardware, order cages and modules separately
很抱歉,暂时无法提供与“CCK19F/90”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2092.244601+271.19474
