2671/27BK-1000
2671/27BK-1000
    DABURNELECTRONICS
    2671/27BK-1000
2671/27BK-1000 数据手册
Daburn Electronics & Cable 44 Richboynton Road Dover, NJ 07801 #2671 Ultra Flexible Sub-Miniature Wire - U/L STYLE 1568, 1692 Description: Daflex ultra flexible sub-miniature hook-up wire series using fine, soft bare stranding and thin PVC walls, is designed for continuous flexing applications such as data processing, mercury thermostats, magnetic memory drums, rotation servo platforms and robotics. The insulation offers superior limpness and flexing characteristics from -40°C to +105°C. It is specially formulated to minimize kinking and fatigue, and it resists acids, alkalis, oils, solvents. This series is RoHS compliant. Description: Operating Temperature: UL Voltage Ratings: Stranded soft bare copper conductor insulated with a thin wall of specially formulated PVC. -40°C to +105°C. (Must be down-rated for some UL styles) U/L 1007/1569 - 300V, U/L 1692 - 30V, U/L 1568 - 150V Nom. Wall Daburn Cat. No. AWG 2671/36** 36 2671/32 Nom. O.D. IN MM IN MM Coml. Volt 7/44 .005" .127 .018" .457 150 32 18/44 .007" .178 .023" .584 300 2671/30* 30 28/44 .010" .254 .030" .762 600 2671/29* 29 51/46 .009" .229 .030" 762 600 2671/28* 28 42/44 .010" .254 .035" .889 600 2671/27* 27 48/44 .010" .254 .037" .940 600 2671/26* 26 66/44 .010" .254 .040" 1.016 600 2671/24* 24 105/44 .010" .254 .046" 1.168 600 2671/22* 22 168/44 .010" .254 .053" 1.346 600 2671/20* 20 266/44 .010" .254 .063" 1.600 600 2671/18* 18 420/44 .010" .254 .072" 1.829 600 2671/16¹ 16 665/44 .015" .381 .096" 2.438 300 Stranding * To U/L style 1568 (150V). ** Tinned Copper. ¹ UL 1007/1569 (300V, 105°C) Standard Put-Ups: 100 FT or 1000 FT Stock Colors: Black, White, Red, Green. Additional colors to order. Tel: 973-328-3200 Fax: 973-328-3130 www.daburn.com Revision E
2671/27BK-1000
1. 物料型号:文档列出了不同型号的电线,包括2671/36至2671/161,每个型号都有其特定的美国线规(AWG)、线股构成、标称壁厚、标称外径、额定电压等。
2. 器件简介:这些电线设计用于需要连续弯曲的应用,如数据处理、水银温度计、磁性记忆鼓、旋转伺服平台和机器人技术。绝缘材料具有优越的柔软性和弯曲特性,能在-40°C至+105°C的温度范围内工作,并且特别配制以最小化扭结和疲劳,同时抵抗酸、碱、油和溶剂。
3. 引脚分配:文档没有明确提供引脚分配信息,因为它主要描述的是电线而非电子元件。
4. 参数特性:电线的参数特性包括操作温度范围、UL电压等级,以及不同型号电线的物理尺寸和额定电压。
5. 功能详解:文档强调了电线的超柔韧性、抗扭结和疲劳的特性,以及其在极端温度下的可靠性。
6. 应用信息:电线适用于需要连续弯曲的应用场合,如上述的数据处理设备、水银温度计等。
7. 封装信息:提供了电线的标准包装方式,包括100英尺或1000英尺的卷装,以及可订购的标准颜色。
2671/27BK-1000 价格&库存
很抱歉,暂时无法提供与“2671/27BK-1000”相匹配的价格&库存,您可以联系我们找货
