C3579.41.02
C3579.41.02
    GENERALCABLE
    CABLE COAXIAL RG58 20AWG 1000'
C3579.41.02 数据手册
Product SKU: Product Description: Product Category: C3579.41.02 C3579, Coaxial Cable, RG58/U Type, Plenum, 20 AWG (19X32) Tinned Copper, 100% Flexfoil® +95% Tinned Copper Braid, Flexguard® PVC Jacket - White- 1000 Ft. Reel Electronics - Coaxial Cable - Other Coaxial Cables - White Product Construction: Conductor: 20 AWG fully-annealed, stranded tinned copper per ASTM B-33 Insulation/Core: Cellular FEP design Shield: Bare or tinned copper braid with or without a polyester supported aluminum shield Jacket: Flexguard® flame retardant PVC Temperature Range: 0ºC to +60ºC Product Specification: No. of Conductors: 1 Conductor Size (AWG): 20 Jacket Color: White Shield Coverage Nominal Shield DCR: 100% Flexfoil® +95% Tinned Copper Braid 3.1 Ohm/M Nominal Outside Diameter (in): 0.165 Nominal Outside Diameter (mm): 4.19 Nominal Capacitance (pF/ft): 26.00 Nominal Capacitance (pF/m): 85.31 Velocity of Propagation %: 78 Nominal Impedance Ohm: 50 Core Outside Diameter (in): 0.100 Core Outside Diameter (mm): 2.54 Nominal Attenuation MHz/dB per 100 ft: 50/2.90 100/4.20 10/1.30 1/0.60 500/10.00 200/6.10 1000/14.80 Standard Packaging: 1000' Non-returnable Wood Reels Standard Package Quantity: 1 UPC #: 079407750085 Put-up: 1000 SCC-14: 50079407750088 Cube: 1224 Weight Per Unit of Measure: .02 ColorOption: White Product Information: Applications: CCTV and MATV Local Area Networks (LANs) Programmable Logic Controllers (PLCs) RF signal transmission Suggested voltage rating: 150 Volts Video Display Terminals (VDT) Compliances: Designed to Meet UL 910 Flame Test NEC Article 444 (UL: 60ºC, 300V) NEC Article 725 (UL: 60ºC, 150V) NEC CL2P, CMP; CEC CMP Packaging: 1000' (305 m) Reels Other put-ups available- consult Customer Service Technical Specifications Unit Conversion Factors Cable Design Equations - Balanced Pair Insulation and Jacket Properties Temperature Conversion Chart Decimal and Unit Conversion Factors Cable Design Equations - Braid Shield AWG Conductor Chart Conduit Capacity Chart Cable Design Equations - Coaxial Cable Engineering Prefixes Coax Connector Cross Reference Glossary
C3579.41.02 价格&库存
很抱歉,暂时无法提供与“C3579.41.02”相匹配的价格&库存,您可以联系我们找货
