REVISION BW
HSEC8-1XXX-XX-XX-DV-X-XX
DESIGNED & DIMENSIONED
IN MILLIMETERS
(INCHES FOR REFERENCE ONLY)
DO NOT
SCALE FROM
THIS PRINT
No OF POSITIONS (PER ROW)
-10, -20, -30 (SEE FIG 1)
■-09, -13, -25, -37, -49, -40, -50, -60, -70,
-80, -90, -100 (SEE FIG 2, SHT 2)
(No OF POS x 0.800 [.0315]) + 4.600 [.1811] 1.126
CARD THICKNESS
(SEE TABLE 9, SHT 3)
-01: 1.57 [.062] CARD
-03: 2.36 [.093] CARD
(10-100 POS, MULTIPLES OF 10 ONLY)
(-K & -TR ONLY FOR OPTION 2)
(USE RHSEC8-XXX-03-DV-XX)
(SEE NOTE 7 & 10)
(No OF POS x 0.800 [.0315]) + 1.400[.0551] REF
C
2.70 .106
REF
(No OF POS -1 ) x 0.800 [.0315]±0.100
C
02
0.800±0.100 .0315±.0039
(TOL NON ACCUM)
CL
60
"A"
P" REF
"Q" REF
"A"
01
POSITION #1
INDICATOR
CL
OPTION 2
**-PE: PASS THROUGH (SHT 7, FIG 7)
(10, 13, & 20 POS ONLY)
(-A OPTION ONLY)
(NOT AVAILABLE WITH ANY OTHER OPTION
2, EXCEPT -K AND/OR -TR & -FR)
**-BL: BOARD LOCK (SHT 5, FIG 5) (SEE NOTE 11)
(-A OPTION ONLY)
**-GR: GUIDE RAILS (SHT 6, FIG 6)
(10-60 POS, MULTIPLES OF 10 ONLY)
(SEE NOTE 11)(-TR & -FR PACKAGING ONLY)
-WT: WELD TAB (SHT 7, FIG 8)
(-A OPTION ONLY)
**-L: LATCHING (SHT 4, FIG 4)
(13, 25, 37, & 49 POS ONLY) (SEE NOTE 11)
(-A OPTION ONLY)
**-L2: ECDP LATCHING (SHT 8, FIG 9)
(09, 13, 25, & 49 POS ONLY) (SEE NOTE 11)
(-A OPTION ONLY)
-K: POLYIMIDE FILM PAD (SEE SHT 2, FIG 3)
-TR: TAPE & REEL (SEE NOTE 16)
(09 THRU 70 POS ONLY)
-FR: FULL REEL QTY. TAPE & REEL (SEE NOTE 15)
(LEAVE BLANK FOR TRAY)
59
XHSEC8X-XXX-XX-DV-XX
7.80 .307
REF
PLATING SPECIFICATION
-SM: 30µ" SELECTIVE GOLD IN CONTACT
AREA, MATTE TIN ON TAIL
"T"' REF -H: 30µ" HEAVY GOLD IN CONTACT
AREA, 3µ" GOLD TAIL)
-S: 30µ" SELECTIVE GOLD IN CONTACT
-L: 10µ" LIGHT SELECTIVE GOLD IN
CONTACT AREA, MATTE TIN ON TAIL
OPTION 1
(LEAVE BLANK FOR NO ALIGNMENT PIN,
USE XHSEC8-XXX-01-DV-LC, NOT
AVAILABLE FOR CARD THICKNESS -02 & -03
SEE FIG 10, SHT 3)
-A: ALIGNMENT PIN
(USE XHSEC8X-XXX-XX-DV-A)
ROW SPECIFICATION
-DV: DOUBLE VERTICAL
1.32 .052 REF
(2 PLCS)
** = AVAILABLE ONLY WITH -01 CARD THICKNESS
■ = AVAILABLE ONLY WITH END OPTIONS -BL, -WT, & -L2
SEE NOTE 12
(SOME FEATURES NOT
SHOWN FOR CLARITY)
C
3.60 .142
REF
1.12 .044 REF (TYP)
+.004
"V"+-0.09
0.26 "V" - .010
C-188-XX-XX
"W" REF
(No OF POS x 0.800[.0315]) + 2.200[.0866] REF
1.50 .059
REF
2.92 .115
REF
CL
3.03 .119
REF
C
7.98±0.15 .314±.006 (TYP)
SEE TABLE 1
C
NOTES:
C
(TOL NON ACCUM)
C
CL
"Y"±0.20 "Y"±.008
SECTION "A"-"A"
FIG 1
((No OF POS -1 ) x 0.800 [.0315])±0.08
FOR POSITIONS -10, -20 & -30
1. C REPRESENTS A CRITICAL DIMENSION.
HSEC8-130-01-XX-DV-A SHOWN
2. BURR ALLOWANCE: 0.04[.0015] MAX.
(SOME FEATURES NOT SHOWN FOR CLARITY)
3. MINIMUM PUSHOUT FORCE: 2.2 NEWTONS.
4. ALL TAIL TO TAIL DIMENSIONS MEASURED TIP TO TIP.
(SEE NOTE 12)
5. ASSEMBLIES TO BE PACKAGED IN TRAYS, UNLESS -TR IS SPECIFIED.
F:\DWG\MISC\MKTG\HSEC8-1XXX-XX-XX-DV-X-XX-MKT.SLDDRW
6. NOTE DELETED.
PROPRIETARY NOTE
UNLESS OTHERWISE SPECIFIED,
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
7. MATING EDGE CARD THICKNESS TOLERANCE TO BE ±0.15 [.006] OF NOMINAL.
DIMENSIONS ARE IN MILLIMETERS.
PROPRIETARY INFORMATION AND ALL DESIGN,
8. NOTE DELETED.
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
TOLERANCES ARE:
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
9. NOTE DELETED.
DECIMALS
ANGLES
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
10. MATING CARD MUST HAVE LEAD-IN. SEE SAMTEC FOOTPRINT FOR SPECIFICATIONS.
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
.X: .3 [.01]
2
520 PARK EAST BLVD, NEW ALBANY, IN 47150
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
11. L, L2, & BL IS NOT APPLICABLE FOR GUIDE RAIL TYPE USE. GR NOT APPLICABLE FOR L,
.XX: .13 [.005]
PHONE: 812-944-6733
FAX: 812-948-5047
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
L2, OR BL TYPE USE.
.XXX: .051 [.0020]
WRITTEN CONSENT OF SAMTEC, INC.
e-Mail: info@SAMTEC.com
code: 55322
12. CORNER VOIDS AT VENDOR DISCRETION, AND MAY OR MAY NOT BE PRESENT.
SHEET SCALE: 2.5:1
MATERIAL:
DO NOT SCALE DRAWING
DESCRIPTION:
13. MEASURE DIMENSION WITH LATCH IN LOCKED, PERPENDICULAR POSITION.
0.8mm HIGH SPEED EDGE CARD ASSEMBLY
INSULATOR: LCP,
14. VOID WIDTH, LOCATION, AND FREQUENCY TO BE AT VENDORS DISCRETION.
COLOR: -01 CARD THICKNESS BLACK,
DWG. NO.
15. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL,
-02 & -03 CARD THICKNESS NATURAL
BASED ON OPTIONS SELECTED.
CONTACT: BeCu
16. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO
THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM
SHEET 1 OF 8
BY: BRATCHER 01/24/03
FIG 3
REVISION BW
-K OPTION
"R"
(No OF POS x 0.800[.0315]) + 7.800[.3071] REF
2.70 .106
REF
C
"D" REF
02
8.11 .319
"S"
"G" REF
"A" REF
120
"H" 0.51 .020
K-DOT-.XXX-.XXX-.XXX
"K"
01
119
4.00 .157
C
"B" SPACES @ .800 = "C"±0.100
C
C
(No OF POS + 3) x 0.800[.0315]±0.100
((No OF POS + 6) x 0.800[.0315]) + 0.600[.0236] REF
13.83±0.15 .545±.006
CL
C
[(No OF POS + 3) x 0.800[.0315] 0.100
"U" 0.13
FIG 2
IN-PROCESS
FOR POSITIONS ■ **-09, **-13, **-25, **-37,
-40, **-49, -50, -60, -70, -80, -90, -100
HSEC8-160-01-XX-DV-A SHOWN
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
PROPRIETARY NOTE
(** = AVAILABLE ONLY WITH
-01 CARD THICKNESS)
SHEET SCALE: 2.25:1
■ = AVAILABLE ONLY WITH END OPTIONS -BL, -WT & -L2
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 2 OF 8
REVISION BW
0.635 .025 MAX
C
CL
3 MAX SWAY
(TYP)
7.80 .307
REF
C-188-XXX-X IN-PROCESS VIEW
FIG 10
**NON-ALIGNMENT PIN OPTION
HSEC8-130-01-XX-DV SHOWN
(** = AVAILABLE ONLY WITH -01 CARD THICKNESS)
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
SHEET SCALE: 2:1
DWG. NO.
SHEET 3 OF 8
REVISION BW
(No OF POS x 0.80[.0315]) + 18.40[.724] REF
"D"
"C"
RHSEC8-XXX-01-DV-XX-L
"C"
"D"
WT-25-02-T
C
C-188-02-X
C
2 MAX SWAY
(EITHER DIRECTION)
(No OF POS x 0.80[.0315]) + 14.90[.587]
1.59 .063
0.64 .025 REF
0.25 .010 REF
SECTION "D"-"D"
SECTION "C"-"C"
FIG 4
**-L: LATCHING OPTION
HSEC8-137-01-XX-DV-A-L SHOWN
AVAILABLE IN -13, -25, -37 & -49 POSITIONS ONLY
(NOT AVAILABLE FOR -GR TYPE USE)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 4 OF 8
REVISION BW
"E" REF
"F"
"H"
"E"
"E"
"H"
"F"
C
2.1±0.40 .083±.016
1.325 .0522
RHSEC8-XXX-01-DV-XX-BL
WT-25-02-T
LTC-04
12.20 .480
REF
1.48 .058
0.25 .010
REF (TYP)
C-188-02-X
C
2 MAX SWAY
(EITHER DIRECTION)
"F"
0.64 .025
REF
SECTION "E"-"E"
SECTION "H"-"H"
SECTION "F"-"F"
FIG 5
**-BL: BOARD LOCK OPTION
HSEC8-160-01-XX-DV-A-BL SHOWN
(FOR -09, -13, -25, 37, -40, -49, -50, -60, -70, -80, -90 & -100
POSITIONS DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2)
(FOR -10, -20 & -30 POSITIONS DIFFERENT AS SHOWN,
(AVAILABLE IN ALL POSITIONS)
PROPRIETARY NOTE
SHEET SCALE: 2.5:1
C
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 5 OF 8
REVISION BW
0.70 .027 REF
2.30 .090 REF
4.40 .173
REF
"J"
RHSEC8-XXX-01-DV-XX-GR
1.75 .069 REF
11.75 .463
REF
C-188-02-X
"J"
SECTION "J"-"J"
FIG 6
**-GR: GUIDE RAILS OPTION
HSEC8-160-01-XX-DV-A-GR SHOWN
AVAILABLE IN -10, -20, -30, -40, -50, & -60 POSITIONS ONLY
(NOT AVAILABLE FOR -L; -BL TYPE USE)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SHEET 6 OF 8
REVISION BW
+ 7.000 [.2756] REF
CL
"G"
+.004
0.56+-0.09
0.30 .022 - .012
HSEC8-XX-01-DV-A-PE
C
C-188-01-X
"G"
(No OF POS X 0.80[.032])
+ 4.60[.18] REF
SECTION "G"-"G"
FIG 7
**-PE: PASS THROUGH OPTION
HSEC8-120-01-XX-DV-A-PE SHOWN
AVAILABLE IN -10, *-13 & -20 POSITIONS ONLY
*-13 IS A ONE BANK PART
"J" REF
"L"
RHSEC8-XXX-XX-DV-A-WT
WT-25-02-T
"L"
C
1.48 .058
0.64 .025 REF
SECTION "L"-"L"
0.25 .010 REF (TYP)
C-188-02-X
C
"F"
(SEE TABLE 4, SHT 5)
FIG 8
-WT: WELD TAB OPTION
HSEC8-160-01-XX-DV-A-WT SHOWN
(-A OPTION REQUIRED)
2 MAX SWAY
(EITHER DIRECTION)
PROPRIETARY NOTE
SHEET SCALE: 2.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 7 OF 8
REVISION BW
BOTH WT'S LANCE SHOULD
FACE TO OUTSIDE
(No OF POS X 0.80[.031]) + 13.66 [.538] REF
'N'
RHSEC8-XXX-01-DV-XX-L2
"M"
WT-25-09-X
1.48 .058
C-188-02-X
2 MAX SWAY
(EITHER DIRECTION)
"M"
0.25 .010
REF (TYP)
0.64 .025
REF
C
(No OF POS X 0.80[.031]) + 8.59 [.338]
C
SECTION "M"-"M"
(No OF POS X 0.800[.031]) + 11.090 [.4366] REF
1.50 .059
REF
FIG 9
**-L2: ECDP LATCHING OPTION
HSEC8-125-01-XX-DV-A-L2 SHOWN
(AVAILABLE IN 9, 13, 25, & 49 POS ONLY)
DETAIL 'N'
SCALE 10 : 1
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 8 OF 8
