MEC8-150-02-L-D-EM2
MEC8-150-02-L-D-EM2
    SAMTEC(申泰)
    P=0.8mm
    特性:高达56Gbps PAM4。PCI Express 4.0。适用于(1.60mm) 0.062英寸和(2.36mm) 0.093英寸厚的卡。可选间距:0.50mm、0.635mm、0.80mm、...
MEC8-150-02-L-D-EM2 数据手册
DESIGNED & DIMENSIONED IN MILLIMETERS (INCHES FOR REFERENCE ONLY) REVISION Q DO NOT SCALE FROM THIS PRINT MEC8-1XX-XX-XX-D-EMX No OF POSITIONS (PER ROW) -10, -20, -30, -35, -40, -45, -50, -60, -70 C (No OF POS x 0.800 [.0315]) + 1.40[.0551] REF "F" REF CL 02 "A" CARD THICKNESS -01: 1mm (.039) THICK CARD -02: 1.57mm (.062) THICK CARD 60 4.40 .173 REF "A" 01 POSITION #1 INDICATOR 7.00 .276 REF 59 (No OF POS x 0.800 [.0315]) + 4.60 [.1811] REF TAIL OPTION -EM2: .062 THICK PCB (USE MEC8-XX-XX-D-EM2 AND C-183-XX-02-X) MEC8-XX-01-D-EM2 "E" "G" REF CL ROW SPECIFICATION -D: DOUBLE (USE MEC8-XX-XX-D-EM2) PLATING SPECIFICATION -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL .05 .20 [ .002 .008 ] C 1.13 x 60 REF C-183-XX-02-XX 3.60 .142 REF 8.50 .335 REF 3.60 .142 REF 3.40 .134 5.00 .197 REF C 3.05 .120 0.80±0.10 .031±.004 (TOL NON ACCUM) 2 MAX SWAY (EITHER DIRECTION) 1.40 .055 REF CL C +0.12 4.95 .195 REF (TYP) +.005 1.48 - 0.08 .058 - .003 C SECTION "A"-"A" (No OF POS -1 ) x 0.800 [.0315] SECTION "B"-"B" (No OF POS x 0.80[.0315]) + 15.20[.598] REF FIG 1 (NO OF POS x 0.80[.0315] + 11.70[.461] REF FOR POSITIONS -10, -20, -30 & -35 (SHOWN: MEC8-130-01-X-D-EM2) CL 1.57 .062 REF "B" "B" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. BURR ALLOWANCE: 0.04[.0015] MAX. 3. MINIMUM PUSHOUT FORCE: .5 LB. 4. ALL TAIL TO TAIL DIMENSIONS TO BE MEASURED FROM TIP TO TIP. ANGLES .X: .3 [.01] 2 .XX: .13 [.005] .XXX: .051 [.0020] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: -01: L.C.P., COLOR: NATURAL -02: L.C.P., COLOR: BLACK CONTACT: PHOS BRONZE F:\DWG\MISC\MKTG\MEC8-1XX-XX-XX-D-EMX-MKT.SLDDRW SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 0.8mm DUAL EDGE MOUNT MINI-EDGE CARD ASSEMBLY DWG. NO. MEC8-1XX-XX-XX-D-EMX BY: CHAD F 04/09/2002 SHEET 1 OF 2 PACKAGING VIEW REVISION Q (PARTS TO HAVE POSITION #1 LOADED IN SAME DIRECTION AS ARROW ON TUBE) "D" REF "A" REF 02 80 01 79 (NO OF POS x 0.80)+18.40 (No OF POS x 0.800 [.0315]) + 7.80 [.307] REF 3.05 .120 0.80±0.10 .031±.004 (TOL NON-ACCUM) 4.00 .157 REF C "B" SPACES @ .800 = "C" C (No OF POS + 3) x 0.800[.0315] ((No OF POS + 4) x 0.80[.0315]) + 11.70[.461] REF TUBE: PT-1-24-02-125 PLUG: TP-03 CL FIG 2 FOR POSITIONS -40 THRU 70 (SAME AS FIG 1, UNLESS OTHERWISE STATED) (SHOWN: MEC8-140-01-X-D-EM2-A) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 0.8mm DUAL EDGE MOUNT MINI-EDGE CARD ASSEMBLY DWG. NO. MEC8-1XX-XX-XX-D-EMX BY: CHAD F 04/09/2002 F:\DWG\MISC\MKTG\MEC8-1XX-XX-XX-D-EMX-MKT.SLDDRW SHEET 2 OF 2
MEC8-150-02-L-D-EM2
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一个晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入侧的发光二极管引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过光电效应实现电信号隔离,适用于数字信号传输。
6. 应用信息:常用于数字电路的电隔离、信号传输等领域。
7. 封装信息:EL817采用DIP-6封装形式。
MEC8-150-02-L-D-EM2 价格&库存
很抱歉,暂时无法提供与“MEC8-150-02-L-D-EM2”相匹配的价格&库存,您可以联系我们找货
