HSEC8-130-01-S-D-EM2
    SAMTEC(申泰)
    P=0.8mm
    特性:最大设计灵活性。高达64 Gbps PAM4性能。PCI Express 3.0、4.0、5.0和6.0。Edge Rate触点针对信号完整性性能和高循环寿命进行了优化。最多200个位置可选。垂...
HSEC8-130-01-S-D-EM2 数据手册
DESIGNED & DIMENSIONED IN MILLIMETERS HSEC8-1XX-XX-X-D-EMXX (INCHES FOR REFERENCE ONLY) REVISION M C (No OF POS -1 ) x 0.800 [.0315] 0.80±0.05 .031±.002 (TOL NON-ACCUM) 1.75 .069 REF C "B" C L 02 No OF POSITIONS -10, -20, & -30 (SEE FIG. 1) -13, -25, -37, -40, -49, -50, & -60 (SEE FIG. 2) (PER ROW) "A" 60 TAIL OPTION -EM2: 1.57mm [.062] THICK PCB -EM2L: 1.57mm [.062] THICK PCB WITH WELD TAB LATCH (SHT. 3, FIG. 3)(AVAILABLE ONLY IN 13, 25, 37 & 49 POSITIONS) CARD THICKNESS -01: 1.57mm [.062] THICK CARD 5.60 .220 REF 01 59 "A" "B" C (No OF POS x 0.80[.0315]) + 15.20[.598] REF (No OF POS x 0.800 [.0315]) + 4.60 [.181] REF -D: DOUBLE (USE HSEC8-XX-01-D-EM2X) PLATING SPECIFICATION -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (No OF POS x 0.800 [.0315]) + 1.400 [.055] REF POSITION #1 INDICATOR ROW SPECIFICATION 7.00 .276 REF +0.08 +.003 0.52 - 0.14 .020 - .006 4.60 .181 REF 0.30[.012] MAX HSEC8-XX-01-D-EM2 C L C-189-01-S 2.90 .114 REF WT-17-01-T 3.05 .120 0.00 0.13 [.000 .005] 7.80 .307 REF 3.60 .142 REF 5.00 .197 REF 2.31 .091 C 0.80±0.08 .031±.003 (TOL NON ACCUM) C C ((No OF POS -1 ) x 0.800 [.0315]) 0.25 .010 REF (2 PLCS) 0.08[.003] (NO OF POS x 0.80[.0315] + 11.70[.461] (SEE NOTE 4) C 3.50 .138 REF C L CL 1.60±0.08 .063±.003 1.47 .058 REF C SECTION "B"-"B" SCALE 4 : 1 SECTION "A"-"A" SCALE 4 : 1 C L FIG 1 FOR POSITIONS -10, -20 & -30 (SHOWN: HSEC8-130-01-S-D-EM2) "C" "C" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. BURR ALLOWANCE: 0.04[.0015] MAX. 3. MINIMUM PUSHOUT FORCE: 2.22 NEWTONS. 4. ALL TAIL TO TAIL DIMENSIONS TO BE MEASURED FROM TIP TO TIP. PROPRIETARY NOTE * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * THIS DOCUMENT CONTAINS CONFIDENTIAL AND AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: BeCu WELD TAB: PHOS BRONZE F:\dwg\misc\mktg\HSEC8-1XX-XX-X-D-EMXX-MKT.SLDDRW SHEET SCALE: 1:0.4 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8mm HIGH SPEED, DUAL EDGE MOUNT, MINI-EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-D-EMXX BY: BRATCHER 01/27/03 SHEET 1 OF 3 REVISION M PACKAGING VIEW ((No OF POS + 3) x 0.80 [.031]) + 16.00 [.629] REF FOR EM2 (PARTS TO HAVE POSITION #1 LOADED IN SAME DIRECTION AS ARROW ON TUBE) "D" REF "A" REF 02 120 01 119 (No OF POS x 0.800[.0315]) + 7.80[.307] REF TUBE: PT-1-24-02-125 PLUG: TP-03 4.00 .157 C C 3.02 .119 REF "B" SPACES @ .800[.0315] = "C" 0.80±0.08 .031±.003 (TOL NON-ACCUM) C C (No OF POS + 3) x 0.800[.0315] ((No OF POS + 4) x 0.80[.0315]) + 11.70[.461] (SEE NOTE 4) C 3.02 .119 1.47 .058 REF SECTION "C"-"C" C L * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND FIG 2 PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS FOR POSITIONS -13, -25, -37, -40, -49, -50, -60 (SAME AS FIG 1, UNLESS OTHERWISE STATED) (SHOWN: HSEC8-160-01-S-D-EM2) AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.4 F:\dwg\misc\mktg\HSEC8-1XX-XX-X-D-EMXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8mm HIGH SPEED, DUAL EDGE MOUNT, MINI-EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-D-EMXX BY: BRATCHER 01/27/03 SHEET 2 OF 3 REVISION M "D" "E" TUBE: PT-1-24-01-108 PLUG: TP-13 "E" PACKAGING VIEW "D" FOR EM2L HSEC8-XX-01-D-EM2L WT-25-01-T 9.65 .380 C REF 6.98 .275 C-189-01-S 1.47 .058 REF SECTION "E"-"E" SECTION "D"-"D" FIG 3 * (SAME AS FIG 2, UNLESS OTHERWISE STATED) (SHOWN: HSEC8-137-01-S-D-EM2L) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.333333 F:\dwg\misc\mktg\HSEC8-1XX-XX-X-D-EMXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8mm HIGH SPEED, DUAL EDGE MOUNT, MINI-EDGE CARD ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-D-EMXX BY: BRATCHER 01/27/03 SHEET 3 OF 3
