HSEC8-140-01-S-D-EM2 数据手册
DESIGNED & DIMENSIONED
IN MILLIMETERS
HSEC8-1XX-XX-X-D-EMXX
(INCHES FOR REFERENCE ONLY)
REVISION M
C
(No OF POS -1 ) x 0.800 [.0315]
0.80±0.05 .031±.002
(TOL NON-ACCUM)
1.75 .069
REF
C
"B"
C
L
02
No OF POSITIONS
-10, -20, & -30 (SEE FIG. 1)
-13, -25, -37, -40, -49,
-50, & -60 (SEE FIG. 2)
(PER ROW)
"A"
60
TAIL OPTION
-EM2: 1.57mm [.062] THICK PCB
-EM2L: 1.57mm [.062] THICK PCB
WITH WELD TAB LATCH
(SHT. 3, FIG. 3)(AVAILABLE
ONLY IN 13, 25, 37 & 49
POSITIONS)
CARD THICKNESS
-01: 1.57mm [.062] THICK CARD
5.60 .220
REF
01
59
"A"
"B"
C
(No OF POS x 0.80[.0315]) + 15.20[.598] REF
(No OF POS x 0.800 [.0315]) + 4.60 [.181] REF
-D: DOUBLE
(USE HSEC8-XX-01-D-EM2X)
PLATING SPECIFICATION
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
(No OF POS x 0.800 [.0315]) + 1.400 [.055] REF
POSITION #1
INDICATOR
ROW SPECIFICATION
7.00 .276
REF
+0.08
+.003
0.52 - 0.14 .020 - .006
4.60 .181 REF
0.30[.012] MAX
HSEC8-XX-01-D-EM2
C
L
C-189-01-S
2.90 .114
REF
WT-17-01-T
3.05 .120
0.00 0.13
[.000 .005]
7.80 .307
REF
3.60 .142
REF
5.00 .197
REF
2.31 .091
C
0.80±0.08 .031±.003
(TOL NON ACCUM)
C
C
((No OF POS -1 ) x 0.800 [.0315])
0.25 .010
REF (2 PLCS)
0.08[.003]
(NO OF POS x 0.80[.0315] + 11.70[.461]
(SEE NOTE 4)
C
3.50 .138 REF
C
L
CL
1.60±0.08 .063±.003
1.47 .058 REF
C
SECTION "B"-"B"
SCALE 4 : 1
SECTION "A"-"A"
SCALE 4 : 1
C
L
FIG 1
FOR POSITIONS -10, -20 & -30
(SHOWN: HSEC8-130-01-S-D-EM2)
"C"
"C"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. BURR ALLOWANCE: 0.04[.0015] MAX.
3. MINIMUM PUSHOUT FORCE: 2.22 NEWTONS.
4. ALL TAIL TO TAIL DIMENSIONS TO BE MEASURED
FROM TIP TO TIP.
PROPRIETARY NOTE
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
ANGLES
.X: 0.3 [.01]
2
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: BeCu
WELD TAB: PHOS BRONZE
F:\dwg\misc\mktg\HSEC8-1XX-XX-X-D-EMXX-MKT.SLDDRW
SHEET SCALE: 1:0.4
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
0.8mm HIGH SPEED, DUAL EDGE MOUNT, MINI-EDGE CARD ASSEMBLY
DWG. NO.
BY:
BRATCHER 01/27/03
SHEET 1 OF 3
REVISION M
PACKAGING VIEW
((No OF POS + 3) x 0.80 [.031]) + 16.00 [.629] REF
FOR EM2
(PARTS TO HAVE POSITION #1 LOADED IN
SAME DIRECTION AS ARROW ON TUBE)
"D" REF
"A" REF
02
120
01
119
(No OF POS x 0.800[.0315]) + 7.80[.307] REF
TUBE: PT-1-24-02-125
PLUG: TP-03
4.00 .157
C
C
3.02 .119 REF
"B" SPACES @ .800[.0315] = "C"
0.80±0.08 .031±.003
(TOL NON-ACCUM)
C
C
(No OF POS + 3) x 0.800[.0315]
((No OF POS + 4) x 0.80[.0315]) + 11.70[.461]
(SEE NOTE 4)
C
3.02 .119
1.47 .058 REF
SECTION "C"-"C"
C
L
PROPRIETARY NOTE
FIG 2
FOR POSITIONS -13, -25, -37, -40, -49, -50, -60
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
(SHOWN: HSEC8-160-01-S-D-EM2)
SHEET SCALE: 1:0.4
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
BRATCHER 01/27/03
SHEET 2 OF 3
REVISION M
"D"
"E"
TUBE: PT-1-24-01-108
PLUG: TP-13
"E"
PACKAGING VIEW
"D"
FOR EM2L
HSEC8-XX-01-D-EM2L
WT-25-01-T
9.65 .380
C
REF
6.98 .275
C-189-01-S
1.47 .058 REF
SECTION "E"-"E"
SECTION "D"-"D"
FIG 3
(SAME AS FIG 2, UNLESS OTHERWISE STATED)
(SHOWN: HSEC8-137-01-S-D-EM2L)
PROPRIETARY NOTE
SHEET SCALE: 1:0.333333
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
BRATCHER 01/27/03
SHEET 3 OF 3
