PCIE-164-02-S-D-RA
PCIE-164-02-S-D-RA
    SAMTEC(申泰)
    弯插,P=1mm
    特性:间距为1.00mm。支持1、4、8和16条PCI Express链路。具备PCIE 3.0解决方案。具备低外形设计的PCIE 4.0解决方案,节省空间。具备薄体设计的PCIE 4.0解决方案。具...
PCIE-164-02-S-D-RA 数据手册
REVISION C DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] NOTES: DO NOT SCALE FROM THIS PRINT PCIE-XXX-02-X-D-RA 1. REPRESENTS A CRITICAL DIMENSION. 2. PARTS TO BE PACKAGED IN TUBE. 3. SPECIAL GAGE AT-2019-049 TO BE USED FOR DIMENSIONS C1, C2, C4, C5 C6, C7 CHECK. C No OF POSITIONS -036, -064, -098, -164 (DOUBLE ROW) PLATING SPECIFICATION (VALUES GIVEN ARE IN MICRO INCHES) -S: 30u" MIN Au/50u" Ni IN CONTACT, MATING TIN ON TAIL -F: 3u" MIN Au/50u" Ni IN CONTACT, MATING TIN ON TAIL "A" REF "B" REF OPTION -RA: RIGHT ANGLE LEAD STYLE -02: 1.57[.062"] THICK CARD 1.80 .071 REF 11.65 .459 REF ROW SPECIFICATION -D: DOUBLE ROW "A" B 32 11.05 .435 REF 7.65 .301 REF B 01 "B" 1.80 .071 REF 9.45 .372 REF PCIE-XXX-RA 3.25 .128 REF C-267-06-X 0.80±0.12 .031±.005 A 01 A 32 0.38 .015 REF (TYP) C "C"±0.15 5.80 .228 REF POSITION 1 INDICATOR "B" "A" CL C C C 0.30 .012 REF 10.00±0.15 .394±.006 1.000 .0394 (TYP) (TOL NON ACCUM.) C-267-05-X 4.50 .177 2.00 .079 7.55 .297 REF SECTION "A"-"A" C 4.40 .173 REF "D" REF C-267-06-X PCIE-XXX-RA-C 2.00 .079 REF C-267-05-X 18.85 .742 REF 6.50 .2559 0.25 .010 REF (TYP) C 4.50 .1772 C 2.30±0.15 .091±.006 FIG. 1 C (PCIE-064-02-X-D-RA SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS[INCHES]. TOLERANCES ARE: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DECIMALS ANGLES MATERIAL: DO NOT SCALE DRAWING X.X: 0.3 [.01] 2 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] SECTION "B"-"B" (SAME AS SECTION "A"-"A", EXCEPT AS SHOWN) SHEET SCALE: 2:1 INSULATOR: LCP, COLOR: BLACK CONTACT : PHOS BRONZE c:\enterprisevault\DWG\MISC\MKTG\PCIE-XXX-02-X-D-RA-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: PCI EXPRESS RIGHT ANGLE ASSEMBLY DWG. NO. PCIE-XXX-02-X-D-RA BY: ROY LUO 10/21/2009 SHEET 1 OF 3 REVISION C C 17.40±0.20 .685±.008 0.25 .010 C 1.80±0.10 .071±.004 PCIE-XXX-RA-C R0.20 .008 12.82 .505 REF C +3° 90° - 4° 2.000 .0787 REF SECTION "A"-"A" SECTION "B"-"B" IN-PROCESS 3 (FILL PCIE-XXX-RA-C) IN-PROCESS 1 (FORM CONTACT C-267-05-X) C 2.95 .116 MIN C 10.00±0.15 .394±.006 SECTION "B"-"B" "C"±0.15 C 4.40 .173 REF IN-PROCESS 4 (CUTOFF OF CARRIER) C 13.18±0.20 .519±.008 C 2.00 .079 4.50 .177 SECTION "A"-"A" 9.40 .370 * C-267-05-X 4.50 .177 SECTION "B"-"B" IN-PROCESS 2 (FILL BOTTOM ROW) SECTION "A"-"A" PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 c:\enterprisevault\DWG\MISC\MKTG\PCIE-XXX-02-X-D-RA-MKT.SLDDRW C 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: PCI EXPRESS RIGHT ANGLE ASSEMBLY DWG. NO. PCIE-XXX-02-X-D-RA BY: ROY LUO 10/21/2009 SHEET 2 OF 3 REVISION C C 6.30±0.10 .248±.004 C 2.95 .116 MIN R1.00 .039 11.02 .434 REF +3° C 90° - 4° 2.000 .0787 REF 10.00±0.15 .394±.006 2.00 .079 C "C"±0.15 C C 9.00 .354 C IN-PROCESS 8 (CUT OFF TOP CONTACT CARRIER) IN-PROCESS 5 (FORM CONTACT C-267-06-X) C 17.68 .696 C 0.80±0.12 .031±.005 C 2.30±0.15 .091±.006 SECTION "B"-"B" IN-PROCESS 6 (FILL TOP ROW) C-267-06-X IN-PROCESS 9 (SHEAR TAIL) 9.00 .354 HEAT STAKE TOP ROW TAILS PT-PCIE001-RA TP-28 c:\enterprisevault\DWG\MISC\MKTG\PCIE-XXX-02-X-D-RA-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. IN-PROCESS 7 (HEAT STAKE TOP ROW CONTACTS) DO NOT SCALE DRAWING PACKAGING VIEW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: PCI EXPRESS RIGHT ANGLE ASSEMBLY DWG. NO. PCIE-XXX-02-X-D-RA BY: ROY LUO 10/21/2009 SHEET 3 OF 3
