HSEC8-125-01-S-RA-L2
    SAMTEC(申泰)
    SMD,P=0.8mm,卧贴
    0.8MM P数:50P
HSEC8-125-01-S-RA-L2 数据手册
REVISION AL "D" REF "C" REF HSEC8-1XX-XX-X-RA-XX-XX "B" REF C DO NOT SCALE FROM THIS PRINT "A"±0.100[.0039] (SEE NOTE 12) 1.100 .0433 REF 02 C 0.800±0.100 .0315±.0039 (TYP) (TOL NON ACCUM) "A" (SEE NOTE 12) 1.75 .069 REF POSITION #1 INDICATOR "G" REF C "J"±0.100[.0039] ("H" SPACES @ 0.800) (SEE NOTE 12) C 4.00 .158 (SEE NOTE 12) "A" 2.00 .079 REF 0.25 .010 REF (TYP) "K"±0.10 C 5.20 .205 REF PLATING SPECIFICATION -L: 10µ" SELECTIVE GOLD ON CONTACT AREA, TIN TAIL -S: 30µ" SELECTIVE GOLD ON CONTACT AREA, TIN TAIL (* = NOT TOOLED) 49 2 MAX SWAY (EITHER DIRECTION) SOME CENTER FEATURES NOT SHOWN FOR CLARITY SOME CENTER FEATURES NOT SHOWN FOR CLARITY FIG 1 1.32 .052 REF 12.05 .474 REF C 3.100±0.100[.0039] (SEE NOTE 12) 50 HSEC8-125-01-X-RA SHOWN (SOME CENTER FEATURES NOT SHOWN FOR CLARITY) 9.30 .366 REF 1.32 .052 REF CARD THICKNESS -01: 1.57mm [.062] THICK CARD 3.00 .118 REF 01 PACKAGING (SEE NOTES 17 & 18) BLANK: (TRAY SEE NOTE 16) -TR: TAPE & REEL -FR: FULL REEL QTY TAPE & REEL OPTION -BL: BOARD LOCK OPTION (USE HSEC8-XXX-01-RA-BL) (AVAILABLE IN -09, -13, -25, -40, -49, -50, -60 POS ONLY, SEE FIG 2, SHT 3) -L2: ECDP LATCHING OPTION (USE HSEC8-XXX-01-RA-L2) (AVAILABLE IN -09, -13, -25, -49 POS ONLY, SEE FIG 3, SHT 3) ROW SPECIFICATION -RA: RIGHT ANGLE (USE HSEC8-XXX-01-RA-XX) No OF POSITIONS -10, -20, -30 (ONE BANK OPTIONS) -09, -13, -25, -40, -49, -50, -60 (TWO BANK OPTIONS) C 0.800±0.100 .0315±.0039 (TYP) (TOL NON ACCUM) (SEE NOTE 12) 1.10 .043 REF C "E"±0.100[.0039] NOTES: (SEE NOTE 12) 1. C REPRESENTS A CRITICAL DIMENSION. "F" REF 2. MAXIMUM BURR ALLOWANCE: 0.05[.002]. 3. MINIMUM RETENTION FORCE: 2.22N[.500 LB] FOR PINS AND WELD TAB. 4. MEASURE AT BEND TANGENCY. 5. NOTE DELETED. 6. NOTE DELETED. 7. NOTE DELETED. 8. DIMENSIONS MUST BE MEASURED ON 4 CONSECUTIVE PINS ON EACH END OF THE CONNECTOR. 9. NOTE DELETED. 10. NOTE DELETED. 11. LTC-XX TO BE IN CLOSED POSITION AS SHOWN. 12. MEASURE BOTH TOP AND BOTTOM ROWS. 13. NOTE DELETED. 14. SEE CO-AU-WI-3163-M DOCUMENT FOR CRITICAL MEASUREMENT SPECIAL INSTRUCTIONS (NOT NEEDED FOR OMM). 15. SEE SUB-C-272-XX-X FOR PROCESS DESCRIPTION AND REQUIREMENTS. 16. TRAY ARE STANDARD PACKAGING. 17.ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM 18.ATTACH LABEL TO EACH REEL UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 2 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP UL94V-0, COLOR: BLACK CONTACT : BeCu WELD TAB: BRASS F:\DWG\MISC\MKTG\HSEC8-1XX-XX-X-RA-XX-XX-MKT.SLDDRW SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8MM HIGH SPEED ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-RA-XX-XX BY: ROY LUO 11/05/2008 SHEET 1 OF 4 REVISION AL C-272-02-X 2.74 .108 REF 3.21 .126 REF C-272-01-X +0.10 HSEC8-SPACER-XXX +.004 C 0.60 - 0.15 .024 - .006 3.00 .118 REF 1.54 .061 REF -F- C 0.10[.004] (INCLUDES PINS & BODY) 1.00 .039 REF F1 0.50 .020 REF WELD TAB SEE TABLE 5 BACK VIEW SCALE 6:1 C 0.90±0.08 .035±.003 (TYP) (SEE NOTE 8) F2 C 7.00±0.08 .276±.003 C 8.70±0.10 .343±.004 (SEE NOTE 8) C 10.55±0.10 .415±.004 (SEE NOTE 8) SECTION "A"-"A" * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 7:1 F:\DWG\MISC\MKTG\HSEC8-1XX-XX-X-RA-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8MM HIGH SPEED ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-RA-XX-XX BY: ROY LUO 11/05/2008 SHEET 2 OF 4 REVISION AL LTC-18 (SEE NOTE 11) "U" REF LTC-19 (SEE NOTE 11) HSEC8-XXX-01-RA-BL 15.65 .616 REF SECTION "C"-"C" "T" REF HSEC8-XXX-01-RA-L2 C 5.575±0.100 .2195±.0039 "P" REF "S"±0.10 C C 5.95 .234 (TYP) 'D' "C" FIG 3 -L2: ECDP LATCHING OPTION AVAILABLE ONLY IN -09, -13, -25 & -49 POSITIONS SAME AS FIG 1, UNLESS OTHERWISE STATED HSEC8-125-01-X-RA-L2 SHOWN "C" "R" REF FIG 2 -BL: BOARD LOCK OPTION ONLY AVAILABLE FOR -09, -13, -25, -40, -49, -50, -60 POSITIONS (SAME AS FIG 1, UNLESS OTHERWISE STATED) HSEC8-125-01-X-RA-BL SHOWN (SOME CENTER FEATURES NOT SHOWN FOR CLARITY) THIS FEATURE IS OPTIONAL AND CAN BE ADDED OR REMOVED AT SAMTEC'S DISCRETION * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DETAIL 'D' SCALE 4 : 1 LTC-XX REMOVED FOR CLARITY DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\HSEC8-1XX-XX-X-RA-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8MM HIGH SPEED ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-RA-XX-XX BY: ROY LUO 11/05/2008 SHEET 3 OF 4 REVISION AL HSEC8-SPACER-XXX 0.00±0.10 .000±.004 C-272-01-X SHEAR CARRIER 0.10[.004] 'J' 7.80±0.13 .307±.005 (TO PIN) (SEE NOTE 8) +.005 0.34+-0.13 0.04 .013 - .002 (TO -F-) (SEE NOTE 4) CL IN-PROCESS VIEW 2 FILL SPACER 0.59 .023 (SEE NOTE 8) IN-PROCESS VIEW 1 FILL FIRST ROW C-272-02-X HEAT STAKE TOP ROW TAILS (NOT NEEDED FOR OMM) 0.10[.004] 0.10 .004 0.02 .001 (SEE NOTES 4 & 8) 9.65±0.15 .380±.006 (TO PIN) (SEE NOTE 8) IN-PROCESS VIEW 3 FILL SECOND ROW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\HSEC8-1XX-XX-X-RA-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 0.8MM HIGH SPEED ASSEMBLY DWG. NO. HSEC8-1XX-XX-X-RA-XX-XX BY: ROY LUO 11/05/2008 SHEET 4 OF 4
HSEC8-125-01-S-RA-L2 价格&库存
很抱歉,暂时无法提供与“HSEC8-125-01-S-RA-L2”相匹配的价格&库存,您可以联系我们找货
  • 1+109.296881+14.14735
