Through-hole resistors
High Power &
Flame-Proof Type
Metal Film Resistors
Ultra Miniature Style [ FMP Series ]
FEATURES
Power Rating
1/2W, 1W, 2W, 3W
Resistance Tolerance
±1%, ±5%
T.C.R.
±100ppm/°C
Flameproof Multi-layer Coating Meets
UL-94V-0
Flameproof Feature Meets Overload Test
UL-1412
INTRODUCTION
DERATING CURVE
The FMP Series Metal Film High Power
Resistors are manufactured using a vacuum
sputtering system to deposit multiple layers of
mixed metal alloys and passivative materials
onto a carefully treated high grade ceramic
substrate. After a helical groove has been cut
in the resistive layer, tinned connecting leads of
electrolytic copper are welded to the end-caps.
The resistors are coated with layers of pink
color lacquer.
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
70
Rated Load (%)
155 °C
100
80
60
40
60
80
Ambient Temperature (°C)
100 120 140 160
DIMENSIONS
Unit: mm
ød
H
L
øD
STYLE
DIMENSION
Ultra Miniature
L
øD
H
ød
FMP-50
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
FMP100
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
FMP200
9.0±0.5
3.9±0.3
26±2.0
0.55±0.05
FMP3WS
11.5±1.0
4.5±0.5
35±2.0
0.8±0.05
FMP300
15.5±1.0
5.0±0.5
33±2.0
0.8±0.05
15
Note:
ELECTRICAL CHARACTERISTICS
STYLE
FMP-50
FMP100
FMP200
FMP3WS
FMP300
Power Rating at 70°C
1/2W
1W
2W
3W
Maximum Working Voltage
200V
350V
500V
750V
Maximum Overload Voltage
400V
600V
700V
1,000V
Voltage Proof on Insulation
300V
500V
Resistance Range
1Ω - 4M7Ω & for E24 & E96 series value
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
±100ppm/°C , ±50ppm/°C (FMP-50 & FMP100 types, R ≥ 10RΩ)
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±1.0%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -55°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>1,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±1.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±2.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±2.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±1.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±0.25%+0.05Ω
Accidental Overload Test
IEC 60115-1 4.26
4 times RCWV for 1 Min.
No evidence of flaming
or arcing
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“FMP200JR-52-390R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.761251+0.22798
- 10+1.1037210+0.14287
- 25+0.9286625+0.12021
- 50+0.8174350+0.10581
- 100+0.72382100+0.09369
- 250+0.62146250+0.08044
- 500+0.55701500+0.07210
- 1000+0.502191000+0.06501
- 国内价格
- 5000+0.37483
- 7500+0.36273
- 27500+0.34581
- 国内价格 香港价格
- 2500+0.442152500+0.05724
- 5000+0.404565000+0.05237
- 7500+0.385257500+0.04987
- 12500+0.3634112500+0.04704
- 17500+0.3503817500+0.04536
- 25000+0.3376625000+0.04371
