RNV Series
Stackpole Electronics, Inc.
High Voltage Anti-moisture Metal Film Resistor
Resistive Product Solutions
Features:
High voltage surge handling per IEC 60065.14.1, up to 7KV
High tolerance to prolonged exposure to temperature and humidity stress
Ideal for applications requiring high stability, reliability and voltage handling;
including power inverters, AC adapters and switching power supplies
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type / Code
Power Rating (W)
@ 70ºC
Maximum
Working Voltage (V)(1)
1600 (DC), 1150
(RMS)
Note: (1) Lesser of √ P*R or maximum working voltage
RNV14
0.25
Maximum
Overload Voltage (V)
TCR (ppm/ºC)
3200 (DC), 2300
(RMS)
± 100
± 200
Ohmic Range (Ω) and Tolerance
1% and 5%
100K - 6.8M
100K - 15M
Mechanical Specifications
Type / Code
L
D
d
H
Unit
RNV14
0.236 ± 0.012
6.00 ± 0.30
0.094 ± 0.008
2.40 ± 0.20
0.022 ± 0.002
0.55 ± 0.05
1.102 ± 0.079
28.00 ± 2.00
inches
mm
Performance Characteristics
Item
Solvent Resistance
Temperature
Coefficient
Resistance (TCR)
Performance
No serious scratches on the insulating surface
Overload
(short time)
Resistance variation within ±(1% + 0.05 Ω)
Voltage Proof
Resistance variation within ±(0.5% + 0.05 Ω)
Vibration
Insulation
Resistance
104MΩ or more
Robustness
of Terminations
and no mechanical damage
Resistance to
Soldering Heat
No mechanical and electrical deterioration
Solderability
More than 95% of the lead surface was covered by
new solder after the leads were dipped in the solder
±100 ppm/ºC (100K - 6.8M)
±200 ppm/ºC (100K - 15M)
Rev Date: 10/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
Test Method
Resistor was dipped into solvent for 5 ± 0.5 minutes
Measured resistance (R0 ohm) at room temperature (tºC) then
measured again at 100ºC higher than room temperature
ppm/ºC = (R - R0)/R0 X 106/{(T + 100) -t}
Applied DC voltage 2.5 times rated voltage or max. overload voltage
whichever is lower for 5 seconds ON, 45 seconds OFF.
Repeated cycle 10 times. Maximum Overload voltage is not more
than 2 x Max Working Voltage.
Resistor was clamped in the through of a 90ºC metallic V-block
and was tested at provided AC potential voltage for 1 minute.
Test voltage: max overload voltage. Test voltage: 500V (AC)
Applied 1.5 mm amplitude vibration to two directions, perpendicular
to each other, for 6 hours each. Total 12 hours.
Vibrating frequency is 10HZ - 2000HZ - 10HZ cycle in 20 minutes.
Repeat cycle.
at DC 100V for 1 minute.
Tensile test: The body of the part is fixed. The tensile force was
applied gradually up to 10 N. Twist test: Terminal lead was
rotated 360º of the original axis of the bent terminal,
alternating direction for 3 rotations.
Resistance to wave soldering condition:
Temperature/Time-Profile in accordance to the CECC00802.
Max Temperature/Time: 260ºC, 10 seconds
Dipped the lead into a solder bath (temperature 245ºC ± 5ºC) up
to 4 ± 0.8 mm from the resistor body and held for 5 ± 0.5 seconds.
www.seielect.com
marketing@seielect.com
RNV Series
Performance Characteristics (cont.)
Item
Performance
Rapid Change
of Temperature
Resistance variation within ±(0.5% + 0.05Ω)
Damp Heat
Resistance variation within ±(1.5% + 0.05Ω)
Endurance at 70ºC
Cold Resistance
Heat Resistance
Test Method
Test: -55ºC for 30 minutes, 25ºC for 30 seconds, 155ºC for 30
minutes, 25ºC for 30 seconds. Resistance changed after
continuous 5 cycles.
Temperature 40ºC ± 2ºC, relative humidity 90 ~ 95%, inside bath for
1.5 hour and shut voltage 0.5 hour. Repeated cycle for 1,000 hours.
Room temperature for 1 hour after test, then measured
In constant temperature chamber 70ºC ± 2ºC, applied rated DC
voltage for 1.5 hour and shut voltage for 0.5 hour.
Cycle repeated for 1000 hours.
Resistor was put into a bath at fixed temp of -55ºC ± 3ºC for 2 hours.
After measured, left at room temp for 1 hour,
then measured again.
Resistor was put into a bath at fixed temp of 155ºC ± 3ºC for 16
hours. After measured, left at room temp for 1 hour,
In accordance with IEC60065.14.1, 50 discharges from a 1nF
capacitor charged to Vmax; Figure 2. 12 discharges/minute
10
High Voltage
Surge Test
Vmax (kV)
9
Resistance variation within ±(1% + 0.05Ω)
8
7
6
5
4
0.01
0.1
1
Rx (MΩ)
10
100
Operating temperature range is -55ºC to +155ºC
Power Derating Curve:
2
www.seielect.com
RNV Series
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
3
www.seielect.com
RNV Series
Packaging Specifications
A max. (1)
2.756 ± 0.118
70.00 ± 3.00
Type / Code
RNV14
B max.
11.811 ± 0.197
300.00 ± 5.00
C
0.197 ± 0.020
5.00 ± 0.50
D (2)
2.047 ± 0.020
52.00 ± 0.50
Tape
0.250
6.35
Unit
inches
mm
Dimension "E":
This is a non-critical dimension that does not have a tolerance in the standard.
Range of diameters is from 0.547" (13.9 mm) to 1.5" (38.1 mm)
(1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component.
The distance between flanges shall be 0.59" (1.5 mm) to 0.315" (8 mm) greater than the overall component.
(2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as
option "N" packaging code.
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
RNV
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
High Voltage Anti-Moisture
Metal Film Resistor
Axial
YES
100% Matte Sn over Ni
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
4
www.seielect.com
RNV Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
R
N
V
1
4
F
T
L
1
K
Product Series
Code Description
High Voltage
RNV
Metal Film
Power Rating
Size
W
14
0.25
Tolerance
Code
Tol
F
1%
J
5%
Code
A
T
Packaging
Description
Size Quantity
Tape Box (52mm)
2000
14
Tape and Reel
5000
TCR
Code ppm
D
100
L
200
Resistance Value
Four characters with
the multiplier used as
the decimal holder.
100 Kohm = 100K
1 Mohm = 1M00
15 Mohm = 15M0
5
www.seielect.com
很抱歉,暂时无法提供与“RNV14FAL10M0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.804631+0.21575
- 10+0.9780310+0.11693
- 25+0.7786925+0.09310
- 50+0.6604550+0.07896
- 100+0.56265100+0.06727
- 250+0.45904250+0.05488
- 500+0.39573500+0.04731
- 1000+0.342821000+0.04099
- 国内价格 香港价格
- 2000+0.298702000+0.03571
- 4000+0.261834000+0.03131
- 6000+0.243126000+0.02907
- 10000+0.2221410000+0.02656
- 14000+0.2097314000+0.02508
- 20000+0.1977020000+0.02364
- 50000+0.1929850000+0.02307
- 国内价格
- 10+0.42609
- 25+0.39325
- 100+0.34087
- 250+0.29738
- 500+0.29205
- 1000+0.28584
