MFP-25BRD52-470R
MFP-25BRD52-470R
    YAGEO(国巨)
    插件,D2.4xL6.3mm
    插件电阻 - 470Ω ±0.1% 1/4W ±25ppm/℃
MFP-25BRD52-470R 数据手册
Through-hole resistors Precision Type Metal Film Resistors Normal & Miniature Style [ MFP Series ] FEATURES Power Rating 1/6W, 1/4W, 0.4W, 1/2W, 0.6W, 1W, 2W, 3W Resistance Tolerance ±0.1%, ±0.25%, (±0.02%, ±0.05% on request) T.C.R. ±15ppm/°C, ±25ppm/°C, (±5ppm/°C, ±10ppm/°C on request) DERATING CURVE For resistors operated in ambient temperatures above 70°C, power rating must be derated in accordance with the curve below. INTRODUCTION The MFP Series Metal Film Precision Resistors are manufactured using a vacuum sputtering system to deposit multiple layers of mixed metal alloys and passivative materials onto a carefully treated high grade ceramic substrate. After a helical groove has been cut in the resistive layer, tinned connecting leads of electrolytic copper are welded to the end-caps. The resistors are coated with layers of blue color lacquer. Ultra high precision resistors, ultra high stability, ultra low temperature coefficient. 70 Rated Load (%) 155 °C 100 80 60 40 20 20 40 60 80 100 120 140 160 Ambient Temperature (°C) DIMENSIONS Unit: mm STYLE ød H L øD DIMENSION Normal Miniature L øD H ød MFP-12 MFP25S 3.4±0.3 1.9±0.2 28±2.0 0.45±0.05 MFP204 - 3.4±0.3 1.9±0.2 28±2.0 0.45±0.05 MFP-25 MFP50S 6.3±0.5 2.4±0.2 28±2.0 0.55±0.05 MFP207 - 6.3±0.5 2.4±0.2 28±2.0 0.55±0.05 MFP-50 MFP1WS 9.0±0.5 3.3±0.3 26±2.0 0.55±0.05 MFP100 MFP2WS 11.5±1.0 4.5±0.5 35±2.0 0.8±0.05 MFP200 MFP3WS 15.5±1.0 5.0±0.5 33±2.0 0.8±0.05 7 Note: ELECTRICAL CHARACTERISTICS STYLE MFP-12 MFP25S MFP204 MFP-25 MFP50S MFP207 MFP-50 MFP1WS Power Rating at 70°C 1/6W 1/4W 0.6W 1/2W 1W Maximum Working Voltage 150V 200V 250V 350V 400V 500V Maximum Overload Voltage 300V 400V 500V 700V 800V 1,000V Voltage Proof on Insulation 300V 700V 1,000V Resistance Range 10Ω - 1 MΩ for E192 series value Operating Temp. Range -55°C to +155°C Temperature Coefficient ±15ppm/°C, ±25ppm/°C 0.4W 1/4W 1/2W 600V 500V MFP100 MFP2WS MFP200 MFP3WS 2W 3W Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage) ±0.25%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±1.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±1.5%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±0.75%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±0.25%+0.05Ω Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
MFP-25BRD52-470R 价格&库存
很抱歉,暂时无法提供与“MFP-25BRD52-470R”相匹配的价格&库存,您可以联系我们找货
MFP-25BRD52-470R
  • 1+5.379091+0.69347
  • 10+3.4601210+0.44608
  • 25+2.9444125+0.37960
  • 50+2.6178350+0.33749
  • 100+2.34076100+0.30177
  • 250+2.03714250+0.26263
  • 500+1.84685500+0.23810
  • 1000+1.684961000+0.21723
库存:28194
MFP-25BRD52-470R
  • 5000+1.369405000+0.17655
  • 10000+1.2770510000+0.16464
  • 15000+1.2296415000+0.15853
  • 25000+1.1760025000+0.15161
  • 35000+1.1460635000+0.14775
库存:28194
