SLR500JB-0R027
SLR500JB-0R027
    YAGEO(国巨)
    插件电阻 - 27mΩ ±5% 5W -
SLR500JB-0R027 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET CEMENT RESISTORS Low Ohmic, Metal Plate Vertical Mount SLR Series ±5%, ±10% 2W to 10W Product specification – August 26, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Cement Resistors Product Specification ORDERING INFORMATION Part number of the cement resistor is identified by the series, power rating, tolerance, packing, temperature coefficient, resistance value and type code. PART NUMBER APPLICATIONS  Home appliance  Consumer SLR 500 J B - 0R035 U (1) (2) (3) (4) (5) (6) (7) (1) SERIES SLR Series (2) POWER RATING FEATURES  Ultra miniature size 200 = 2W 700 = 7W 300 = 3W 10A = 10W 500 = 5W  Current detecting resistors  Flameproof cement case  RoHS compliant and halogen free (3) TOLERANCE J = ±5% K = ±10% (4) PACKAGING B = Bulk (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (6) RESISTANCE VALUE Example: 0R035 = 0.035Ω, 0R1 = 0.1Ω, 1R = 1Ω (7) TYPE CODE Optional code for different type. . Example: Null = Standard type E = SLR200 & SLR300 / ψd=0.8±0.05mm copper wire U = SLR500 & SLR700 & SLR10A / ψd=0.6±0.05mm copper wire C = SLR200 & SLR300 / ψd=0.8±0.05mm CP- wire W = SLR500 & SLR700 & SLR10A / ψd=0.6±0.05mm CP- wire www.yageo.com Aug. 26, 2021 V.0 2 8 SLR Through Hole Resistors Cement Resistors Product Specification 8 SLR DIMENSIONS Unit: mm Normal A B C D ψd RM SLR200 8±1 13±1 3.5±1 5±1 0.60±0.05 9±1 SLR300 13±1 13±1 3.5±1 5±1 0.60±0.05 9±1 SLR500 18±1 14±1 3.5±1 5±1 0.80±0.05 10±1 SLR700 18±1 26±1 3.5±1 5±1 0.80±0.05 20±1 SLR10A 20±1 26±1 3.5±1 5±1 0.80±0.05 20±1 DERATING CURVE SLR200 Rated Power (%) 100 80 60 58 40 20 70 155 275 Ambient Temperature (°C) SLR300 ~ SLR500 Rated Power (%) 100 80 60 51 40 20 40 155 275 Ambient Temperature (°C) www.yageo.com Aug. 26, 2021 V.0 3 Through Hole Resistors Cement Resistors Product Specification 8 SLR TEMPERATURE CURVE ELECTRICAL CHARACTERISTICS CHARACTERISTICS SLR200 Power Rating at 70 °C 2W Power Rating at 40 °C SLR300 SLR500 SLR700 SLR10A 3W 5W 7W 10W Voltage Proof on Insulation 500V 700V 700V 1000V 1000V Resistance Range 0.1Ω ~ 0.68Ω 0.01Ω ~ 1Ω 0.01Ω ~ 3.3Ω 0.01Ω ~ 3.3Ω 0.01Ω ~ 3.3Ω Maximum Working Voltage √(P X R) Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±250ppm/°C Note: For resistance value out of above range is by request. TABLE I MATERIALS OF LEAD WIRE TYPE Resistance Value ≤0.05Ω ˃0.05Ω Copper Wire CP Wire SLR Series www.yageo.com Aug. 26, 2021 V.0 4 Through Hole Resistors Cement Resistors Product Specification 8 SLR TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE 2.5 times RCWV for 5 sec.(Not more than APPRAISE ±2.0%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N)D the terminal leads IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, ±2.0%+0.05Ω 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±2.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Aug. 26, 2021 V.0 5 Through Hole Resistors Cement Resistors Product Specification 8 SLR MARKING Example: YAGEO = Brand 1210 = Date code 3W = Power rating 0R18 = Resistance K = Tolerance www.yageo.com Aug. 26, 2021 V.0 6 Through Hole Resistors Cement Resistors Product Specification 8 SLR REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 26, 2021 V.0 7 Through Hole Resistors Cement Resistors Product Specification 8 SLR LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 26, 2021 V.0 8
SLR500JB-0R027 价格&库存
很抱歉,暂时无法提供与“SLR500JB-0R027”相匹配的价格&库存,您可以联系我们找货
SLR500JB-0R027
  • 1+11.656231+1.50878
  • 10+7.6352610+0.98831
  • 25+6.5428625+0.84691
  • 50+5.8577950+0.75823
  • 100+5.27605100+0.68293
  • 250+4.63893250+0.60046
  • 500+4.23958500+0.54877
  • 2000+3.612312000+0.46758
  • 6000+3.241846000+0.41963
库存:377
