TSM-106-01-F-SV
TSM-106-01-F-SV
    SAMTEC(申泰)
    SMD,P=2.54mm
    1X6P 间距:2.54MM 方针 立贴
TSM-106-01-F-SV 数据手册
SURFACE MOUNT .025" SQ POST HEADER 8 G b p s (2.54 mm) .100" PITCH • TSM SERIES TSM Board Mates: SSW, SSQ, SSM, BSW, ESW, ESQ, BCS, SLW, CES, HLE Cable Mates: IDSS, IDSD - TSM 1 - NO. PINS PER ROW LEAD STYLE 02 thru 36 Specify LEAD STYLE from chart SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 495 VAC -SV/-DV mated with the BCS 475 VAC -SV/-DV mated with the SSM (2.54) .100 x No. of positions (2.54) .100 Post Height (2.54) .100 MATES TSM/SSW (2.54) .100 x No. of positions (3.05) .120 TSM/HLE 4.1 A TSM/BCS 5.0 A 2 POSITIONS POWERED –01 (5.84) .230 SSW, BCS, SSM, IDSS, IDSD –02 (8.13) .320 SSM -DH –03 (10.67) .420 Bottom Mount & Pass Through –04 (3.05) .120 SLW, CES, HLE Post Height 4.7 A 5.4 A MATES WITH (No. of positions x (2.54) .100) – (5.08) .200 CURRENT RATING (PER PIN) TSM/SSM LEAD POST STYLE HEIGHT —SV Row Option PROCESSING Lead–Free Solderable: Yes -DH/-SH/-SV Lead Coplanarity: (0.15 mm) .006" max (02-36)* -DV Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10)* (0.15 mm) .006" max (11-36)* *(.004" stencil solution may be available; contact ipg@samtec.com) (3.81) .150 (2.54) .100 –01= (4.57) .180 –02, –03, –04 = (4.82) .190 —SH Row Option (2.54) .100 x No. of positions (5.08) .200 Post Height (2.54) .100 (3.81) .150 (No. of positions -2) x (2.54) .100) Note: Some lengths, styles and options are non-standard, non-returnable. F-221 (Rev 31MAY22) —DV Row Option samtec.com?TSM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. - - PLATING OPTION - - ROW OPTION –F –SV = Gold flash on post, Matte Tin on tail = Single Row Vertical Pin –L –DV = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Double Row Vertical Pin –S = Single Row Horizontal Pin –T = Double Row Horizontal Pin (Style –01, –02 or –03 only) –SH = 30 µ" (0.76 µm) Gold on post, Matte Tin on tail –DH = Matte Tin –TM = Triple Row Vertical Mixed Technology (Style –01 only) (02 thru 30 positions only) –MT = Mixed Technology Pin (Style –01, –02 or –03 only) (2.54) .100 x No. of positions –“XXX” = Polarized Position –A = Alignment Pin metal or plastic at Samtec discretion (Not available with –TM or –MT) (02 positions minimum) (Not available with –LC) –LC = Locking Clip (Not available with –TM) (3 positions minimum) (Not available with –A) (Manual placement required) –K = (6.50 mm) .256" DIA Polyimide Film Pick & Place Pad (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–DH: 4 positions minimum without –TR) –P = Plastic Pick & Place Pad (–DV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–DH: 5 positions minimum without –TR) (–SV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (6.10) .240 (No. of positions x (2.54) .100) – (5.08) .200 –TR Post Height = Tape & Reel –SV: 02-22 positions, –DV: 02-28 positions, –SH: 02-30 positions, –DH: 02-29 positions (Not available with –MT or –TM) (2.54) .100 (3.68) .145 (7.87) .310 OTHER OPTIONS –FR (1.16) .046 = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) –SV: 02-22 positions, –DV: 02-28 positions, –SH: 02-30 positions, –DH: 02-29 positions (Not available with –MT or –TM) —DH Row Option (2.54) .100 x No. of positions (2.54) .100 x No. of positions (6.10) .240 (1.52) .060 (2.54) .100 (7.62) .300 Post Height Post Height (2.54) .100 (7.87) .310 —TM Row Option (1.16) .046 —MT Row Option samtec.com?TSM F-221 (Rev 31MAY22) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TSM-106-01-F-SV
- 物料型号:TSM系列,具有不同的引脚数量和引脚样式。 - 器件简介:该器件是一种表面贴装的方形插座,具有2.54mm的间距和不同的引脚配置。 - 引脚分配:引脚数量从2到36不等,用户可以根据图表指定引脚样式。 - 参数特性:绝缘材料为黑色液晶聚合物,端子材料为磷青铜,镀层有金或锡,操作温度范围从-55°C到+105°C(锡镀层)或-55°C到+125°C(金镀层),电压等级为495 VAC(与BCS配合使用)或475 VAC(与SSM配合使用)。 - 功能详解:提供了不同引脚样式的详细规格,如引脚高度、配合使用的型号、电流额定值等。 - 应用信息:文档中提到了与不同型号的配合使用,如SSW、SSM、HLE、BCS等。 - 封装信息:提供了不同行选项的尺寸和形状,如单行垂直引脚、双行垂直引脚、单行水平引脚、双行水平引脚等。
TSM-106-01-F-SV 价格&库存
很抱歉,暂时无法提供与“TSM-106-01-F-SV”相匹配的价格&库存,您可以联系我们找货
TSM-106-01-F-SV
    • 1+5.04360
    • 10+4.92480
    • 38+4.83840
    库存:23
    TSM-106-01-F-SV
    • 1+8.812971+1.14566
    • 50+6.8385250+0.88899
    • 100+5.52542100+0.71829
    • 500+4.70585500+0.61175
    • 1000+4.560451000+0.59285
    库存:464
