HPF-08-01-T-S
HPF-08-01-T-S
    SAMTEC(申泰)
    插件,P=5.08mm
    1X8P 间距:5.08MM 直插
HPF-08-01-T-S 数据手册
HPF-XX-XX-XX-S-XX-XX REVISION AH No OF POSITIONS -02 THRU -20 (PER ROW) DO NOT SCALE FROM THIS PRINT LEAD STYLE -01: THROUGH HOLE (SEE FIG 4) (USE C-130-03-X) -02: SURFACE MOUNT (USE C-130-04-X) C (No OF POSITIONS x .200) .010 .1000 .010 (SEE NOTE 8) C (No OF POSITIONS -1) X .200 POLARIZATION # -02 THRU -06,-08, -10, -12 (SEE SHT 3, TABLE 2 FOR AVAILABLE COMBINATIONS) (SEE SHT 3, IN-PROCESS 1 POLARIZED FILL) .003 OPTION -LC: LOCKING CLIP (USE LC-05-TM) (SEE SHT 2, FIG 2) (-02 LEAD STYLE ONLY, SEE NOTE 9) * -A: ALIGNMENT PIN (-02 LEAD STYLE ONLY) (SEE SHT 2, FIG 2) -K: POLYIMIDE FILM PAD (-02 LEAD STYLE ONLY, AVAILABLE ON -01 LEAD STYLE FOR EXISTING CUSTOMERS ONLY) (SEE SHT 2, FIG 3)(USE K-DOT-.256-.375-.005) -TR: TAPE & REEL (-02 LEAD STYLE ONLY) (14 POS MAX) PLATING SPECIFICATION -T: TIN (USE C-130-XX-T) -H: HEAVY GOLD (USE C-130-XX-H) -TM: MATTE TIN (USE C-130-XX-T) 01 .2000 REF .1000 REF .0450 REF HPFR-XX-S-X # = INTERNAL USE ONLY NOT FOR SALE * = NOT ENGINEERING APPROVED ROW SPECIFICATION -S: SINGLE (USE HPFR-XX-S-X) "A" C-130-04-X +.004 C .368 - .002 .3510 REF C SEE NOTE 2 'C' "A" 3° MAX TWIST .0180 REF DETAIL 'C' SCALE 4 : 1 DETAIL 'B' .280 SECTION "A"-"A" POSITION ONE FOR MANUFACTURING PROCESS 'B' C-130-03-X .102±.003 FIG 1 HPF-XX-02-XX-S-XX .0970±.003 3 MAX SWAY ALL LEADS TO BE IN THE SAME DIRECTION (EITHER DIRECTION) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY TO BE WITHIN : 2-10 POS: .006 11-20 POS: .008 3. BURR ALLOWANCE: .0015 MAX. 4. MAXIMUM CUT FLASH: .020. 5. MINIMUM PUSHOUT FORCE: 1.0 LB. 6. ALL PARTS TO BE TUBE PACKAGED. 7. OPEN PART OF CONTACT FILLED TOWARDS #1 PIN INDICATOR. 8. MINIMUM WALL THICKNESS TO BE .010. 9. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT, SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. 10. NOTE DELETED. F:\DWG\MISC\MKTG\HPF-XX-XX-XX-S-XX-XX-MKT.SLDDRW C 2 MAX TOE FIG 4 HPF-XX-01-XX-S (SAME AS FIG1 EXCEPT WHERE SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .XX: .01 .XXX: .005 .XXXX: .0020 MATERIAL: ANGLES 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING MATERIAL: VECTRA E130i COLOR: BLACK CONTACT: BeCu, 174HT SHEET SCALE: 1.5:1 DESCRIPTION: .200 HI POWER SOCKET ASSEMBLY DWG. NO. BY: HPF-XX-XX-XX-S-XX-XX DEAN P 01/04/1999 SHEET 1 OF 3 REVISION AH "M" .3740 9.500 "P" .0280±.020 0.711±0.51 01 NOTE: "M" = USED MEASURED DIMENSION (REF) "P" = {("M" - .256 [6.50]) / 2} .020 [.51] .256 6.500 FIG 3 -K: POLYIMIDE FILM PAD OPTION (SHOWN: HPF-10-02-X-S-K) HPFR-XX-S-A THROUGH HOLE SURFACE MOUNT .0500 TUBE: PT-1-24-02-44 PLUG: TP-07 .0460 .0100 REF .0560 REF LC-05-TM {(No OF POSITIONS x .200) -.400} .005 -LC OPTION FIG 2 SEE NOTES 6 & 7 FOR ADDITIONAL PACKAGING INSTRUCTIONS .0500 REF -A OPTION PACKAGING VIEW -LC & -A OPTIONS (-LC & -A OPTION ONLY AVAILABLE ON -02 LEAD STYLE) (SAME AS FIG 1 EXCEPT WHERE SHOWN) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\HPF-XX-XX-XX-S-XX-XX-MKT.SLDDRW DESCRIPTION: DWG. NO. BY: .200 HI POWER SOCKET ASSEMBLY HPF-XX-XX-XX-S-XX-XX DEAN P 01/04/1999 SHEET 2 OF 3 REVISION AH IN-PROCESS 1 FILL C-130-XX-X POLARIZED OPTION = DENOTES EMPTY POSITION STANDARD FILL -02 POLARIZATION (7 FINISHED GOODS) HPF-20-02-XX-S-02 SHOWN -03 POLARIZATION (5 FINISHED GOODS) HPF-20-02-XX-S-03 SHOWN -12 POLARIZATION (1 FINISHED GOODS) HPF-20-01-XX-S-12 SHOWN -04 POLARIZATION (4 FINISHED GOODS) HPF-20-02-XX-S-04 SHOWN -05 POLARIZATION (3 FINISHED GOODS) HPF-20-02-XX-S-05 SHOWN -06 POLARIZATION (3 FINISHED GOODS) HPF-20-02-XX-S-06 SHOWN -08 POLARIZATION (2 FINISHED GOODS) HPF-20-02-XX-S-08 SHOWN -10 POLARIZATION (1 FINISHED GOODS) HPF-20-02-XX-S-10 SHOWN * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 1.5:1 DESCRIPTION: DWG. NO. F:\DWG\MISC\MKTG\HPF-XX-XX-XX-S-XX-XX-MKT.SLDDRW BY: .200 HI POWER SOCKET ASSEMBLY HPF-XX-XX-XX-S-XX-XX DEAN P 01/04/1999 SHEET 3 OF 3
HPF-08-01-T-S 价格&库存
很抱歉,暂时无法提供与“HPF-08-01-T-S”相匹配的价格&库存,您可以联系我们找货
HPF-08-01-T-S
    • 1+25.12080
    • 10+24.45120
    • 28+24.00840
    • 98+23.56560
    库存:99
