SSQ-108-01-F-D
SSQ-108-01-F-D
    SAMTEC(申泰)
    插件,P=2.54mm
    2X8P 间距:2.54MM 直插
SSQ-108-01-F-D 数据手册
REVISION BH SSQ-1XX-XX-XXX-X-XX-XXX-XX-XX OPTION No OF POSITIONS -01 THRU -50 (PER ROW) DO NOT SCALE FROM THIS PRINT **-MW: METAL WASHER (SEE FIG 7, SHT 3) (N/A WITH -LL OR -RA) (N/A WITH -T) (AVAILABLE ON -01, -02, -21, & -22 STYLES ONLY) (AVAILABLE ON POS -02 THRU -30 ONLY) OPTION -LL: LOCKING LEAD (SEE FIG 6, SHT 2) (N/A WITH SINGLE ROW, 1 OR 2 POS) POLARIZATION OPTION INDICATE POS (SEE FIG 8, SHT 3) LEAD STYLE (SEE TABLE 1) -01 THRU -04: STANDARD INSERTION FORCE -21 THRU -24: LOW INSERTION FORCE (NO OF POS x .100[2.54] + .020[0.51]) ±.010[0.25] (SEE NOTE 7 & 10) PLATING SPECIFICATION -G: 20µ" GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL -T: MATTE TIN ON ENTIRE PIN (NOT AVAILABLE FOR -21 THROUGH -24 LEAD STYLES) -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -TL: TIN/LEAD (90/10±5%) ON ENTIRE PIN (AVAILABLE ONLY ON LEAD STYLE -01) -TM: MATTE TIN ON ENTIRE PIN (NOT AVAILABLE FOR -21 THROUGH -24 LEAD STYLES) -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10±5%) ON TAIL (AVAILABLE ONLY ON LEAD STYLE -01) OPTION -RA: RIGHT ANGLE (SEE FIG 2, SHT 2) (N/A ON LEAD STYLE -01) ROW SPECIFICATION -S: SINGLE, USE SSW-XX-S -D: DOUBLE, USE SSW-XX-D -T: TRIPLE, USE SSW-XX-T -Q: TRIPLE (SEE FIG 4, SHT 2) USE SSW-XX-T (-T WITH ONLY 2 OUTER ROWS FILLED) -P: POLARIZED, USE SSW-XX-P (SEE FIG 5, SHT 2) ** - MW OPTION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF 02/12/2002 .095 2.41 REF .295 7.49 REF .195 4.95 REF .335 8.51 REF C "B" (FOR MACHINE FILL, SEE NOTE 11) 'A' NOTES: .025 0.64 SQ REF (TYP) .100 2.54 -S (SEE NOTE 4) 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 1.0 LB. 3. MAXIMUM ALLOWABLE BOW: .003[.08] INCH/INCH. 4. MAXIMUM ALLOWABLE SWAY: HAND FILL 4° (TYP). MACHINE FILL 1° (TYP). 5. MAXIMUM VARIATION BETWEEN PIN ROWS: .010[0.25]. 6. END WALLS AFTER CUTTING SHOULD BE .020 .003 [0.51 .08] 7. MAXIMUM CUT FLASH: .010[0.25]. 8. SHEAR LOCATION TO BE WITHIN .001[0.03] OF THE BREAK OFF CENTER LOCATION FOR MACHINE FILL. 9. NOTCH ON -P-RA OPTION TO BE ORIENTED AS SHOWN. 10. NO FLASH IS ALLOWED BELOW LEADS OR IN HOLES OF BODY. 11. +.000[0.00]/-.005[0.13] FOR MACHINE FILL ONLY, SSQ-1XX-XX-X-S, SSQ-1XX-XX-X-D, SSQ-1XX-XX-X-T (IN-PROCESS), SSQ-1XX-XX-X-S-RA. "G" C -T -D C .100 2.54 "G" 2 MAX SWAY (EITHER DIRECTION) FIG 1 SSQ-1XX-XX-X SHOWN 25° REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS (SEE NOTE 8) .0145 0.368 REF DETAIL 'A' SCALE 16 : 1 F:\DWG\MISC\MKTG\SSQ-1XX-XX-XXX-X-XX-XXX-XX-X-MKT.SLDDRW ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .025[0.64] SQ TAIL DWG. NO. SSQ-1XX-XX-XXX-X-XX-XXX-XX-X BY: PURVIS 06/12/1987 SHEET 1 OF 3 REVISION BH C "C" REF (SEE TABLE 2, SHT 1) 90° SEE NOTE 9 .06 1.5 C "D" .100 2.54 C .200 5.08 C "F" .200 5.08 .200 5.08 C FIG 2 (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) SSQ-1XX-X-S-RA SSQ-1XX-X-D-RA SSQ-1XX-X-T-RA SSQ-1XX-X-P-RA -S-LL .040±.010 1.02±0.25 (TYP) .008±.002 0.20±0.05 (TYP) SSQ-1XX-XXX-X-RA-P SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) FIG 4 SSQ-1XX-XXX-X-Q-RA SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1, FIG 2) FIG 3 IN-PROCESS RIGHT ANGLE -D-LL -T-LL/-Q-LL .040±.010 1.02±0.25 (TYP) STRAIGHT VERSION CL FIG 5 "E" C -S-RA-LL -D-RA-LL -T-RA-LL/-Q-RA-LL .008±.002 0.20±0.05 (TYP) RIGHT ANGLE VERSION CL CL * FIG 6 -LL: LOCKING LEAD = CRIMP LOCATION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SSQ-1XX-XX-XXX-X-XX-XXX-XX-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .025[0.64] SQ TAIL DWG. NO. SSQ-1XX-XX-XXX-X-XX-XXX-XX-X BY: PURVIS 06/12/1987 SHEET 2 OF 3 REVISION BH TOOLING REEL OPERATOR TOP VIEW DETAIL 'C' SCALE 8 : 1 'B' OPERATOR 'C' REEL FRONT VIEW WASHER REEL ASSEMBLY ORIENTAION VIEW 3 MAX SWAY (EITHER DIRECTION) .005 0.13 MAX (MEASURE AT TAIL) .003 0.08 MAX (MEASURE AT TAIL) ESQ-04-MW-T DETAIL 'B' SCALE 8 : 1 FIG 7 02 01 02 03 -S FIG 8 03 04 01 POLARIZATION LOCATION INSERT PK-15-N INTO SPECIFIED POS AND BREAK OFF TAB PROPRIETARY NOTE -D * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SSQ-1XX-XX-XXX-X-XX-XXX-XX-X-MKT.SLDDRW FIG 9 FOR METAL WASHERS ONLY (ALL OTHER OPTIONS BULK PACKAGED) * 03 01 PT-1-24-02-53 PT-1-24-01-53 SSQ-1XX-XXX-X-MW SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) **-MW: METAL WASHER (ONE PER POSITION) (N/A ON -LL OR -RA OPTION OR TRIPLE ROW) (STYLE -01, -02, -21 AND -22 ONLY) (AVAILABLE ON POS -02 THRU -30 ONLY) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) ** - MW OPTION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF 02/12/2002 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .025[0.64] SQ TAIL DWG. NO. SSQ-1XX-XX-XXX-X-XX-XXX-XX-X BY: PURVIS 06/12/1987 SHEET 3 OF 3
SSQ-108-01-F-D 价格&库存
很抱歉,暂时无法提供与“SSQ-108-01-F-D”相匹配的价格&库存,您可以联系我们找货
SSQ-108-01-F-D
  • 1+20.320891+2.63033
  • 50+16.7872850+2.17294
  • 100+14.22494100+1.84127
  • 500+12.63457500+1.63542
  • 1000+11.717901000+1.51676
库存:212
SSQ-108-01-F-D
  • 11+20.49425
  • 50+16.97577
  • 100+14.31575
  • 500+12.76810
  • 1000+10.20481
  • 2000+8.65716
  • 5000+7.02488
  • 10000+5.05404
库存:11
SSQ-108-01-F-D
    • 1+15.99480
    • 10+15.46560
    • 30+15.10920
    库存:4
