ESQ-120-12-T-D
ESQ-120-12-T-D
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 2x20P 直插
ESQ-120-12-T-D 数据手册
REVISION CK ESQ-1XX-XX-X-X-XXX-XX-X-XX NOTES: 1. MINIMUM CONTACT PUSHOUT: 1.5 LBS. 2. FOR A 1 POSITION SINGLE ROW ALL SPACERS ARE TO BE TSW-XX-S. 3. NOTE DELETED. 4. MAXIMUM ALLOWABLE BOW .003[0.08] INCH/INCH AFTER ASSMBLY 5. DO NOT USE DSB SPACER BODY FOR THIS OPTION. 6. MAXIMUM CUT FLASH : .010[0.25]; MAXIMUM CUT FLASH ON TAIL SIDE: .020[0.51] NOT TO EXTEND BELOW STANDOFFS. 7. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM CONTACT STYLE SQUARE TAIL: USE C-15-X-X LOW INSERTION FORCE: C-60-X-X (SEE TABLE 1, SHT 2) METAL WASHER OPTION #* -H-MW: (SEE FIG 3, SHT 2) (N/A ON TRIPLE ROW) (.300 [7.62] MAX TAIL) (AVAILABLE ON POS -02 THRU -32 ONLY) NO. OF POSITIONS POSITIONS 01 THRU 36 (SEE FIG1) FOR A ONE POSITION SINGLE ROW SEE NOTE 2 LOCKING LEAD OPTION -LL (SEE FIG 2, SHT 2) [N/A ON 1 OR 2 POSITION SINGLE ROW] LEAD STYLE (SEE TABLE 1, SHT 2) PLATING SPECIFICATION -G: 20µ" GOLD IN CONTACT AREA, 3µ" GOLD TAIL -T: MATTE TIN CONTACT AND TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD TAIL -L: 10µ" SELECTIVE LIGHT GOLD IN CONTACT AREA, MATTE TIN TAIL DO NOT SCALE FROM THIS PRINT POLARIZATION OPTION INDICATES POSITION (SEE FIG 4, SHT 2) ROW SPECIFICATION (SEE TABLE 1, SHT 2) -S: SINGLE (USE SSW-50-S) -D: DOUBLE (USE SSW-50-D) -T: TRIPLE (USE SSW-50-T) (No OF POS x .10[2.5] + .02[0.5]) .295 7.49 REF (-T ONLY) .100 2.54 REF .195 4.95 REF (-D ONLY) .100 2.54 REF (-D & -T ONLY) SSW-XX-S .335 8.51 REF SSW-XX-D SUB-SSB-32 OR ESS-XX-S (SEE NOTE 2) "C" .010[0.25] C "D"±.010[0.25] #-MW OPTION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS 2/12/02 .200 5.08 REF (-T ONLY) .095 2.41 REF (-S ONLY) *SEE NOTE 6 SSW-XX-T DSB-XX & SUB-SSB-32 OR ESS-XX-S DSB-XX RTSW-XX-D TSW-XX-S TSW-XX-T .100 2.54 REF .100 2.54 REF "B" REF C-60-X-X .025 0.64 SQ REF (TYP) (No OF POS X .100[2.54]) REF 2° MAX SWAY (EITHER DIRECTION) FIG 1 ESQ-110-XX-X-T F:\DWG\MISC\MKTG\ESQ-1XX-XX-X-X-XXX-XX-X-XX-MKT.SLDDRW -S 2° MAX SWAY (EITHER DIRECTION) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 V0 COLOR: BLACK CONTACT : PHOS BRONZE -T -D SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ESQ STRIP ASM DWG. NO. ESQ-1XX-XX-X-X-XXX-XX-X-XX BY: JORDAN 7-16-85 SHEET 1 OF 4 #-MW OPTION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS 2/12/02 REVISION CK SSW-XX-D SSW-XX-S ESQ-110-XX-X-D-MW-T DETAIL A SCALE 4 : 1 108 6 3 .005 0.13 MAX MEASURE AT THE TAIL 4 -T 1 .003 0.08 MAX MEASURE AT THE TAIL FIG 3 -S #-H-MW: METAL WASHER ESQ-110-XX-X-X-MWT (ONE PER POSITION) (-S & -D BODY SPECS ONLY) (SEE NOTE 5) (SAME AS FIG 1 UNLESS OTHERWISE NOTED) 3° MAX SWAY ANY DIRECTION DETAIL B SCALE 6 : 1 -D 4 2 72 1 106 HTSW-XX-D HTSW-XX-S 71 3 36 2 1 -D -S .04 1.02 .0080 0.20 (TYP) CL CL CL -S FIG 4 -T -D -S -D -T CRIMP LOCATIONS XXX: POLARIZATION LOCATION INSERT PK-06-N INTO SPECIFIED POS AND BREAK OFF TAB ODD POSITIONS = CRIMP LOCATION CL CL CL -S -D CRIMP LOCATIONS -T EVEN POSITIONS = CRIMP LOCATION FIG 2 -LL: LOCKING LEAD OPTION LOCATED ON OR ABOUT CENTERLINE [N/A IN 1 OR 2 POSITION SINGLE ROW] * PROPRIETARY NOTE F:\DWG\MISC\MKTG\ESQ-1XX-XX-X-X-XXX-XX-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ESQ STRIP ASM DWG. NO. ESQ-1XX-XX-X-X-XXX-XX-X-XX BY: WHITTAKER 9-11-98 SHEET 2 OF 4 REVISION CK "D" .010[0.25] .09 2.29 .09 2.29 LOAD CONTACT PRESS ON SSW BODY PRESS ON -MW IN-PROCESS -12, -33, -37, -58 "C" .010[0.25] "D" .010[0.25] .18 4.57 "C" .010[0.25] "D" .010[0.25] .18 4.57 LOAD CONTACT "B" PRESS ON SSW BODY PRESS ON -MW REPRESS STACKER BODY AND -MW TO PROPER "C" DIM IN-PROCESS -13, -14, -23, -24, -34, -38 -39, -44, -48, -49, -59, -69 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\ESQ-1XX-XX-X-X-XXX-XX-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ESQ STRIP ASM DWG. NO. ESQ-1XX-XX-X-X-XXX-XX-X-XX BY: WITHTTAKER 9-11-98 SHEET 3 OF 4 REVISION CK SSW-50-X "B" + "E" STEP 1 1. FOR -12 & -37 LEAD STYLES TUBE PAC KAGE -04 THRU -36 POSITION ONLY. 2. FOR -13, -23, -33, -38, -48, & -58 LEAD STYLES TUBE PACKAGE -08 THRU -36 POSITIONS ONLY. 3. FOR -14, -24, -34, -44, -39, -49, -59, & -69 LEAD STYLES -05 THRU -36 POSITIONS ONLY. MACHINE FILL SSW-50-X "C" .010[0.25] "D" .010[0.25] TSW-XX-X (RTSW-XX-X) "B" -D PT-1-24-01-51 STEP 2 MULTI-CUT TSW-50-X TO POS (RTSW-50-D FOR DOUBLE ROW) AND MOUNT AS SHOWN. (IF RTSW-50-D NOT AVAILABLE, TSW-50-D MAY BE USED) (No OF POS X .100[2.54]+.020[0.51]) .010[0.25] "B" -D PT-1-24-02-47 FIG 6 ESQ-110-XX-X-D IN PROCESS "A" (LEAD STYLE -12-T, -13, -14, -23, -24, -33, -34, -44, -37-T, -38, -48, -49, -58, -59, -69) -D PT-1-24-03-44 STEP 3 * ROTO CUT TO POS F:\DWG\MISC\MKTG\ESQ-1XX-XX-X-X-XXX-XX-X-XX-MKT.SLDDRW PROPRIETARY NOTE -T PT-1-24-03-51 -S PT-ESQ001 DO NOT SCALE DRAWING SHEET SCALE: 1:1 -S PT-ESQ002 * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 5 ESQ-110-XX-X-S IN PROCESS "B" (LEAD STYLE -12 & -37) (-S & -D ONLY) -S PT-1-24-01-47 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ESQ STRIP ASM DWG. NO. ESQ-1XX-XX-X-X-XXX-XX-X-XX BY: WHITTAKER 9-11-98 SHEET 4 OF 4
ESQ-120-12-T-D
1. 物料型号:ESQ-1XX-XX-X-X-XXX-XX-X-XX,其中1XX代表具体的型号,XX代表不同的配置选项。 2. 器件简介:文档描述了一种名为ESQ STRIP ASM的连接器,它具有多种配置选项和引脚分配。 3. 引脚分配:文档提供了不同型号的引脚分配信息,例如单排、双排和三排配置。 4. 参数特性:包括接触力度、最大偏斜角度、最大允许的弓形等。 5. 功能详解:文档详细描述了连接器的不同功能,如锁定引脚选项、金属垫圈选项、极化选项等。 6. 应用信息:文档提供了关于如何使用连接器的指导,包括不同引脚配置的推荐使用场景。 7. 封装信息:提供了连接器的物理尺寸和形状信息,以及不同封装选项的详细描述。
ESQ-120-12-T-D 价格&库存
很抱歉,暂时无法提供与“ESQ-120-12-T-D”相匹配的价格&库存,您可以联系我们找货
ESQ-120-12-T-D
    • 1+30.11040
    • 10+29.43000
    • 33+28.97640
    库存:6
