PTHF-130-02-G-Q-368
PTHF-130-02-G-Q-368
    SAMTEC(申泰)
    插件,P=2mm
    排母 4x30P 直插
PTHF-130-02-G-Q-368 数据手册
REVISION S PTHF-1XX-XX-XX-Q-368 No OF POSITIONS 2 - 30 PER ROW ((No of POS x .07874[2.00]) + .0117[.297]) .010 BOARD STACK HEIGHT LEAD STYLE -02: (USE ASP-71280-XX-X) -03: (USE ASP-71716-02-X) (No of POS x .07874[2.00]) - .0789 [2.00] "B" ROW SPECIFICATION -Q: QUAD ROW (USE ASP-81021-03) PLATING SPECIFICATION -G: (USE ASP-71280-02-G) -02 LEAD STYLE ONLY -M: (USE ASP-71716-02-M) -03 LEAD STYLE ONLY -H: (USE ASP-71716-03-H) -03 LEAD STYLE ONLY -MM: (USE ASP-71716-02-MM) -03 LEAD STYLE ONLY -GF: (USE ASP-71280-07-GF) -02 LEAD STYLE ONLY "A" "A" "B" .07874 2.000 REF ASP-81021-03 'A' .315 8.000 REF .368 9.347 REF .0323 0.820 REF "A" .010[.25] (SEE TABLE 1) C .0150 0.381 REF .1020 2.590 REF (SEE NOTE 8) S SECTION "B"-"B" SCALE 1.5 : 1 .0197 0.500 SQ. REF .026 0.66 SQ REF SECTION "A"-"A" SCALE 1.5 : 1 .051 1.30 SQ REF .076 1.93 REF PACKAGING VIEWS .213 5.41 REF NOTES: 1. C REPRESENTS A CRITICAL DIMENSION.. 2. BURR ALLOWANCE: .0015[.04] MAX. 3. MAXIMUM CUT FLASH: .010[.25]. 4. MINIMUM PUSHOUT FORCE: .5 LB. 5. MAXIMUM ALLOWABLE BOW: .002[.05] INCH/INCH AFTER ASSEMBLY. 6. DELETED 7. 5 THRU 30 POSITION PARTS TO BE TUBE PACKAGED, 2 THRU 4 POSITION PARTS TO BE BULK PACKAGED. 8. SEE SAMTEC'S RECOMMENDED PCB FOOTPRINT FOR PROPER BOARD LAYOUT. S DETAIL 'A' SCALE 3 : 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] PTHF-1XX-02-G-Q TUBE: PT-1-24-02-51 PLUG: TP-26 PTHF-1XX-03-M-Q TUBE: PT-1-24-01-52 PLUG: TP-13 MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATOR: LCP; BLACK CONTACT: PHOS BRONZE c:\enterprisevault\DWG\MISC\MKTG\PTHF-1XX-XX-XX-Q-368-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 2mm PC104+ COMPLIANT PIN SOCKET DWG. NO. PTHF-1XX-XX-XX-Q-368 BY: T.WERNE 12/05/2000 SHEET 1 OF 1
