PPPC291LGBN
PPPC291LGBN
    SULLINS
    CONN FEMALE 29POS .100" R/A GOLD
PPPC291LGBN 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO G 2516 H 3120 J 3963 DESCRIPTION DATE UPDATE NOTE 10 AND ADD NOTE 11 MATING PARTS 02/14/2012 UPDATE PROCESSING TEMPERATURE FOR NYLON 6T 04/15/2015 MATERIAL UPDATE GENERAL TOL IN TITLE BOX, NOTE 8 & WARP TOL, UPGRADE NYLON MTL (FROM 6T TO 9T), 1/3/2019 UPDATE TAIL-TO-TAIL & TAIL PITCH DIM TO REF ADD REF TO INSERTION DEPTH BY LH LH F JH E E B±.014[ 0.35] A .008[ 0.20] .100 2.54 .100±.008 2.54±0.20 D D .100 2.54 A .124±.008 3.15±0.20 .102 2.58 .257 6.53 C C .335±.006 8.50±0.15 .063±.008 1.60±0.20 .024(w)X.016(t)[0.60x0.40] B A 02-15, .008[0.20] MAX. NOTES: 16-30, .012[0.30] MAX. 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 31-40, .016[0.40] MAX. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS. 5. VOLTAGE RATING: 250 VAC 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 1000 VAC. 9. OPERATING TEMPERATURE: -40° C TO +105° C. 10.PROCESSING TEMPERATURE: SEE PART NUMBER CODING. 11.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES. (.025 [0.64] SQUARE POSTS) A .004[ 0.10] .100±.002 2.54±0.05 7 6 5 .040±.002 1.02±0.05 RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 8 B 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 12/15/2008 JH TOLERANCES: ANGULAR: 5 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0039 [.100] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER FEMALE, 2.54mm CC, 1 ROW, RA PART NUMBER xPxCxx1LGBN-RC TITLE SIZE C CAGE CODE 54453 SCALE: 8:1 3 2 DWG. NO. 10493 SHEET 1 OF 1 1 REV J FILE NAME: 10493, P(N)PxCxx1LGBN-RC A
PPPC291LGBN 价格&库存
很抱歉,暂时无法提供与“PPPC291LGBN”相匹配的价格&库存,您可以联系我们找货
