REVISION S
PTHF-1XX-XX-XX-Q-368
No OF POSITIONS
2 - 30 PER ROW
((No of POS x .07874[2.00]) + .0117[.297]) .010
BOARD STACK HEIGHT
LEAD STYLE
-02: (USE ASP-71280-XX-X)
-03: (USE ASP-71716-02-X)
(No of POS x .07874[2.00]) - .0789 [2.00]
"B"
ROW SPECIFICATION
-Q: QUAD ROW
(USE ASP-81021-03)
PLATING SPECIFICATION
-G: (USE ASP-71280-02-G)
-02 LEAD STYLE ONLY
-M: (USE ASP-71716-02-M)
-03 LEAD STYLE ONLY
-H: (USE ASP-71716-03-H)
-03 LEAD STYLE ONLY
-MM: (USE ASP-71716-02-MM)
-03 LEAD STYLE ONLY
-GF: (USE ASP-71280-07-GF)
-02 LEAD STYLE ONLY
"A"
"A"
"B"
.07874 2.000 REF
ASP-81021-03
'A'
.315 8.000 REF
.368 9.347
REF
.0323 0.820 REF
"A" .010[.25]
(SEE TABLE 1)
C
.0150 0.381 REF
.1020 2.590 REF
(SEE NOTE 8)
S
SECTION "B"-"B"
SCALE 1.5 : 1
.0197 0.500 SQ. REF
.026 0.66 SQ REF
SECTION "A"-"A"
SCALE 1.5 : 1
.051 1.30 SQ REF
.076 1.93 REF
PACKAGING VIEWS
.213 5.41 REF
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION..
2. BURR ALLOWANCE: .0015[.04] MAX.
3. MAXIMUM CUT FLASH: .010[.25].
4. MINIMUM PUSHOUT FORCE: .5 LB.
5. MAXIMUM ALLOWABLE BOW: .002[.05]
INCH/INCH AFTER ASSEMBLY.
6. DELETED
7. 5 THRU 30 POSITION PARTS TO BE TUBE
PACKAGED, 2 THRU 4 POSITION PARTS
TO BE BULK PACKAGED.
8. SEE SAMTEC'S RECOMMENDED PCB
FOOTPRINT FOR PROPER BOARD LAYOUT.
S
DETAIL 'A'
SCALE 3 : 1
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
PTHF-1XX-02-G-Q
TUBE: PT-1-24-02-51
PLUG: TP-26
PTHF-1XX-03-M-Q
TUBE: PT-1-24-01-52
PLUG: TP-13
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 2:1
INSULATOR: LCP; BLACK
CONTACT: PHOS BRONZE
c:\enterprisevault\DWG\MISC\MKTG\PTHF-1XX-XX-XX-Q-368-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
2mm PC104+ COMPLIANT PIN SOCKET
DWG. NO.
BY: T.WERNE
12/05/2000
SHEET 1 OF 1
PTHF-130-03-M-Q-368 价格&库存
很抱歉,暂时无法提供与“PTHF-130-03-M-Q-368”相匹配的价格&库存,您可以联系我们找货
