PPPN192FJFN
PPPN192FJFN
    SULLINS
    CONN HEADER 2MM DUAL R/A 38POS
PPPN192FJFN 数据手册
A No. of 1 2 B C D E WI-0901 SPECIFICATIONS DIMENSIONS 14.00 Current Rating: Insulator Resistance: Dielectric Withstanding: 1 Amp 5000 Mega Ohms min. 500 VAC 16.00 Operating Temperature: -40 Degrees C to +105 Degrees C 18.00 Contact Material: Brass or Phosphor Bronze 18.00 20.00 Insulator Material: Polyester,UL 94V-0 44 20.00 22.00 48 22.00 24.00 52 24.00 26.00 56 26.00 28.00 60 28.00 30.00 64 30.00 32.00 68 32.00 34.00 72 34.00 36.00 76 36.00 38.00 80 38.00 40.00 84 40.00 42.00 88 42.00 44.00 92 44.00 46.00 Contacts A B 24 10.00 12.00 28 12.00 32 14.00 36 16.00 40 96 46.00 48.00 100 48.00 50.00 104 50.00 52.00 108 52.00 54.00 112 54.00 56.00 116 56.00 58.00 120 58.00 60.00 Standard: Contact Finish: 8.00•+-0.15 Nylon-6T Selective Plating, Gold/Tin 1 A •+-0.10 B •+-0.20 0.50X0.50•+-0.05 2.00•+-0.10 2.00•+-0.10 (CONTACT AREA) 4.40•+-0.13 1.52•+-0.15 2 2.40•+-0.20 (SOLDER AREA) 3 3 SULLINS 801 E. MISSION RD. SAN MARCOS, CA 92069 GENERAL TOLERANCE XX. •+XXX. •+X. •+- 0.20 .XXX •+.X •+- 0.10 .XX •+- 0.05 A SCALE UNIT SIZE 3:1 MM DRAWN DATE CHECK DATE APPROVE DATE DWG. NO. T0019 REV. TITLE SHEET PARTS NO. A4 B C PRPNxx4RCCN D E FM-0524
PPPN192FJFN 价格&库存
很抱歉,暂时无法提供与“PPPN192FJFN”相匹配的价格&库存,您可以联系我们找货
