NPRN154EFCN-RC
NPRN154EFCN-RC
    SULLINS
    60 位 接头 连接器 0.079"(2.00mm) 通孔 金
NPRN154EFCN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 893 INITIAL RELEASE 1/13/2006 TT B 1126 9/12/2006 MV C 1811 UPDATE SPECIFICATIONS UPDATE P/N CODING, POSITION TABLE, SPECIFICATIONS, TOLERANCE BLOCK 1/09/09 JH F E E .079 2.00 .315 8.00 .079 2.00 .079±.004 2.00±0.10 D .079±.002 2.00±0.05 .236 6.00 .031 0.80 B±.012 [ .30] D A±.004 [ .10] RECOMMENDED PCB LAYOUT .072 1.82 C C .189 4.80 .250 6.35 .094±.008 2.40±0.20 B A .020±.002 0.50±0.05 NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 2 AMPS 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX. .079±.002 2.00±0.05 7 B .236 6.00 .020±.002 0.50±0.05 A±.008 [ .20] 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. UNLESS OTHERWISE SPECIFIED: Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 .079±.004 2.00±0.10 6 DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 5 .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 1/10/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER, FEMALE 2mm CC, 4 ROWS, ST NPxNxx4EFCN-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10665 SCALE: 12:1 2 C SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10665, NPxNxx4EFCN-RC PRINT: 3/4/2009 A
NPRN154EFCN-RC 价格&库存
很抱歉,暂时无法提供与“NPRN154EFCN-RC”相匹配的价格&库存,您可以联系我们找货
