SMH-104-02-T-S
SMH-104-02-T-S
    SAMTEC(申泰)
    SMD,P=2.54mm,卧贴
    排母 1x4P 卧贴
SMH-104-02-T-S 数据手册
F-221 WEB SMH–110–02–L–D SMH–112–02–L–S SMH–120–02–G–S (2.54 mm) .100" SMH SERIES SMT HORIZONTAL SOCKET Mates With: TSW, MTSW, MTLW, EW, ZW, TSS, ZSS, TSM SMH 1 NO. PINS PER ROW PLATING OPTION 02 OTHER OPTION ROW OPTION SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SMH –S –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes –“XX” = Single Row = Polarized Position –TR –D = Tape & Reel Packaging (02-29 positions only) = Double Row –G = 20 µ" (0.51 µm) Gold on contact, Gold flash on tail –FR –T = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (02-29 positions only) = Matte Tin PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max (02-24) (0.20 mm) .008" max (25-36)* *(.004" stencil solution may be available; contact IPG@samtec.com) 02 thru 36 (2.41) .095 RECOGNITIONS (1.14) .045 01 For complete scope of recognitions see www.samtec.com/quality (3.43) .135 FILE NO. E111594 (7.24) .285 02 (4.95) .195 (2.54) .100 01 ALSO AVAILABLE (1.14) .045 (MOQ Required) • Other platings (3.43) .135 (0.71) .028 (No. of Positions x (2.54) .100) + (0.51) .020 (8.51) .335 Important Note: SMH mated to TSM–DH/–SH not coplanar, SSM–DH/–SH recommended for coplanar applications. Note: Some lengths, styles and options are non-standard, non-returnable. (0.79) x(0.41) .031 .016 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SMH-104-02-T-S 价格&库存
很抱歉,暂时无法提供与“SMH-104-02-T-S”相匹配的价格&库存,您可以联系我们找货
SMH-104-02-T-S
    • 1+7.26840
    • 10+7.08480
    • 30+6.95520
    库存:13
    SMH-104-02-T-S
    • 1+11.345811+1.46452
    • 50+8.8156650+1.13793
    • 100+7.12344100+0.91950
    • 500+6.06021500+0.78226
    • 1000+5.836511000+0.75338
    库存:124
