SQT-106-01-F-D-RA
SQT-106-01-F-D-RA
    SAMTEC(申泰)
    弯插,P=2mm
    间距:2MM 弯插
SQT-106-01-F-D-RA 数据手册
SQT-1XX-XX-XXX-X-XXX-XXX REVISION CF POLARIZATION OPTION -XXX: INDICATES POSITION (SEE NOTE 10) No OF POSITIONS -02 THRU -50 (PER ROW) -01 (SEE NOTE 3) LEAD STYLE (SEE TABLE 1) PLATING SPECIFICATION -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -G: 20µ" SELECTIVE GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL. -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -H: 50µ" SELECTIVE GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL. -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, SnPb ON TAIL. DO NOT SCALE FROM THIS PRINT C {(No OF POS x .0787[2.000]) + .0117[0.300] ± .010[0.25] (No OF POS x .0787[2.000] - .0787[2.000] REF OPTION -RA: RIGHT ANGLE (-01 LEAD STYLE, ROWS -S, -D, -T ONLY) (NOT AVAILABLE ON -Q, -5 & -6 ROWS) (SINGLE, DOUBLE, TRIPLE ROW: SEE FIG 2, SHT 2) *-SD1: SOLDER DONUT (SEE FIG 3, SHT 2) (AVAILABLE ON -S, -D, -T ONLY) **-MW: METAL WASHER (SHT 2, SEE FIG 4) (AVAILABLE ON LEAD STYLES -01 & -03 ONLY) (5 POS MIN, 30 POS MAX, .300 MAX TAIL) ROW SPECIFICATION -S: SINGLE (USE SQT-61-S) -D: DOUBLE (USE SQT-62-D) -T: TRIPLE (USE SQT-62-T) -Q: QUAD (USE SQT-62-Q) -5: FIVE ROW (USE SQT-62-5) -6: SIX ROW (USE SQT-62-6) * = NOT RELEASED FOR PRODUCTION ** = MW OPTION, DO NOT DESIGN IN, SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS 02/06/2002 .0787 2.000 REF (TYP) 02 01 (SEE NOTE 7) "B" REF SQT-XX-X (SEE TABLE 3) .064 1.63 REF .250 6.35 REF "A" .015 0.38 REF 2 MAX SWAY (EITHER DIRECTION) .0197 0.500 SQ REF (TYP) C C-79-XX-X (SEE TABLE 1) 2 MAX SWAY (EITHER DIRECTION) FIG 1 SQT-120-01-XX-6 SHOWN 01 02 (POSITON PATTERN SINGLE ROW ONLY) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM CONTACT RETENTION: .5 LB 3. -01 POSITION OFFERED FOR SINGLE ROW& ONLY FOR -S, -D, & -T ROWS RIGHT ANGLE ONLY. 4. -01, -02, & -03 & ONLY FOR -S, -D, & -T ROWS POSITIONS TO BE LAYER PACKAGED. 5. STOCK 62 POSITION FOR -D AND 61 POSITION FOR -S, -01 LEAD STYLE ONLY. TO BE CUT TO POSITION FOR CUSTOMER. 6. MAXIMUM BURR: .005[0.13] 7. ENDWALL AFTER CUTTING: .031[.79]+/-.004[0.10], VOIDS MAY BE PRESENT. CONTACTS MUST NOT BE VISIBLE THROUGH THE ENDWALL 8. MAXIMUM CUT FLASH: .020[0.50] 9. MAXIMUM HEIGHT VARIATION: .005[0.13] 10. INSERT PK-07-N INTO SPECIFIED POSITION AND BREAK OFF TAB. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE MAX BOW ALLOWED: .004[.10] IN/IN c:\enterprisevault\DWG\MISC\MKTG\SQT-1XX-XX-XXX-X-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM SOCKET STRIP ASSEMBLY DWG. NO. SQT-1XX-XX-XXX-X-XXX-XXX BY: BRATCHER 07/24/1995 SHEET 1 OF 3 REVISION CF 90° 90° .600 15.24 .208 5.28 IN PROCESS 1 IN PROCESS 3 IN PROCESS 2 (LEAD STYLE -01-S,D,T-RA) REEL .600 15.24 (LEAD STYLE -01-T-RA) (LEAD STYLE -01-D,T-RA) TOOLING .0200 0.508 REF SD1 (POSITON PATTERN SINGLE row ONLY) OPERATOR SQT-XX-X (SEE TABLE 3) 'A' TOP VIEW REEL 01 02 02 01 R.025 0.64 OPERATOR FRONT VIEW WASHER REEL ASSEMBLY ORIENTATION VIEW .025 0.64 REF DETAIL 'A' SCALE 4 : 1 .065 1.65 REF .0787±.0050 2.000±0.127 (TYP) FIG 3 C FIG 2 -RA: RIGHT ANGLE (LEAD STYLE -01-S,D,T) SQT-01-MW-T 2 MAX SWAY (EITHER DIRECTION) * FIG 4 C-79-12-X (SHEAR TO LENGTH) .090±.010 2.29±0.254 *-SD1: SOLDER DONUT (ONE PER POSITION) (ROW STYLE -S,-D,-T & -Q ONLY) *NOT ENGINEERING APPROVED 'B' C-79-53-X (SHEAR TO LENGTH) C-79-12-X (SHEAR TO LENGTH) .050±.010 1.27±0.25 .0050 0.127 MAX MEASURE AT THE TAIL **-MW: METAL WASHER (ONE PER POSITION) (AVAILABLE ON LEADSTYLES -01 & -03 ONLY (5 POS MIN, 30 POS MAX) ** -MW OPION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS 2/06/02. .0030 0.076 MAX MEASURE AT THE TAIL DETAIL 'B' SCALE 6 : 1 c:\enterprisevault\DWG\MISC\MKTG\SQT-1XX-XX-XXX-X-XXX-XXX-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM SOCKET STRIP ASSEMBLY DWG. NO. SQT-1XX-XX-XXX-X-XXX-XXX BY: BRATCHER 07/24/1995 SHEET 2 OF 3 REVISION CF PACKAGING VIEWS SQT-1XX-01-XX-D (SEE TABLE 2) SQT-1XX-02-XX-D (LOCATE PLUG AS SHOWN) (SEE TABLE 2) SQT-1XX-01-XX-D-RA SHOWN (LOCATE PLUG AS SHOWN) (SEE TABLE 2) SQT-1XX-03-XX-S SHOWN (SEE TABLE 2) SQT-1XX-05-XX-X (LOCATE PLUG AS SHOWN) (SEE TABLE 2) * PROPRIETARY NOTE DO NOT SCALE DRAWING SQT-1XX-03-XX-6 SHOWN (SEE TABLE 2) c:\enterprisevault\DWG\MISC\MKTG\SQT-1XX-XX-XXX-X-XXX-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 1:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM SOCKET STRIP ASSEMBLY DWG. NO. SQT-1XX-XX-XXX-X-XXX-XXX BY: BRATCHER 07/24/1995 SHEET 3 OF 3
SQT-106-01-F-D-RA 价格&库存
很抱歉,暂时无法提供与“SQT-106-01-F-D-RA”相匹配的价格&库存,您可以联系我们找货
SQT-106-01-F-D-RA
    • 1+17.37720
    • 10+16.99920
    • 46+16.74000
    库存:10
