SSM-106-L-DV-A
SSM-106-L-DV-A
    SAMTEC(申泰)
    SMD,P=2.54mm
    2X6P 间距:2.54MM 立贴
SSM-106-L-DV-A 数据手册
TIGER CLAW™ SURFACE MOUNT SOCKET 8 G b p s (2.54 mm) .100" PITCH • SSM SERIES SSM Mates: TSW, MTSW, TST, TSS, ZST, ZSS, DW, EW, ZW, TSM, HMTSW, HTSW, TSSH, BST, HTSS, TLW, MTLW SSM - 1 PLATING OPTION 02 thru 36 - –F (–SV, – SH, –DH) (–DV) = Single Row Vertical Pin –DV –L = Double Row Vertical Pin = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –SH = Single Row Horizontal Pin –S = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail (2.54) .100 x No. of Positions ROW OPTION –SV = Gold flash on contact, Matte Tin on tail 02 thru 40 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (SSM/TSW): 5.2 A per pin (2 pins powered) Voltage Rating: 405 VAC / 572 VDC Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: SV/DV = (4.34 mm) .171" to (7.24 mm) .285" or pass-through from top; (5.56 mm) .219" plus board thickness minimum from bottom; SH/DH = (4.34 mm) .171" to (6.35 mm) .250" Normal Force: 125 grams (1.21 N) average - NO. PINS PER ROW –DH = Double Row Horizontal Pin (3.18) .125 —SH ALSO AVAILABLE OTHER OPTION –“XXX” = Polarized Position (–BE not available) –BE = Bottom Entry (–DV & –SV only) –LC = Locking Clip (–DV & –SV only) Contact Samtec for –DH & –SH –K = (6.50 mm) .256" DIA Polyimide film Pick & Place Pad (2 positions min.) –DV & –SV only –M = Metal Pick & Place Pad (5 positions min.) –DV only (5.72) .225 —DH –P = Plastic Pick & Place Pad (–DV & –SV only) (6 positions min. Contact Samtec for availability on smaller positions) (8.13) .320 PROCESSING Lead–Free Solderable: Yes –DH Coplanarity: Less than 28 positions (0.15 mm) .006" max* More than 27 positions (0.20 mm) .008" max* –SH, –SV, –DV Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact IPG@samtec.com) - –TR = Tape & Reel (29 positions max.) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (29 positions max.) (2.54) .100 x No. of Positions (2.54) .100 (7.37) .290 Alignment pin (MOQ Required) —SV (2.54) .100 x No. of Positions 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT (5.08) .200 HIGH MATING CYCLES (7.37) .290 Note: Some lengths, styles and options are non-standard, non-returnable. —DV —LC —P —M samtec.com?SSM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
SSM-106-L-DV-A
物料型号:TIGER CLAW™ SURFACE MOUNT SOCKET
器件简介:该产品是Samtec公司生产的表面贴装插座,适用于多种应用场景。
引脚分配:文档中未明确提供引脚分配信息,但提到了多种引脚配置选项,如单排垂直引脚、双排垂直引脚等。
参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:磷青铜 - 镀层:金或锡,覆盖50微米(1.27微米)镍 - 电流额定值:每针5.2安培(2针供电) - 电压额定值:405 VAC / 572 VDC - 工作温度范围:-55°C至+125°C(金镀层)或-55°C至+105°C(锡镀层) - 插入深度:根据引脚类型有所不同
功能详解:文档中未提供详细的功能解释,但提到了产品具有高插拔次数和长寿命的特点。
应用信息:适用于需要高插拔次数和长寿命的应用场景。
封装信息:提供了多种封装选项,如塑料拾放垫、金属拾放垫、锁定夹等。
SSM-106-L-DV-A 价格&库存
很抱歉,暂时无法提供与“SSM-106-L-DV-A”相匹配的价格&库存,您可以联系我们找货
SSM-106-L-DV-A
    • 1+29.21400
    • 10+28.56600
    • 37+28.14480
    库存:5
    SSM-106-L-DV-A
    • 37+32.06534
    • 74+26.49139
    • 111+21.94517
    • 518+18.69269
    • 1036+16.11731
    • 2035+13.71120
    • 5032+11.82500
    • 10027+10.03554
    库存:27
