SFM-120-01-L-D
SFM-120-01-L-D
    SAMTEC(申泰)
    插件,P=1.27mm
    2X20P 间距:1.27MM 直插
SFM-120-01-L-D 数据手册
REVISION DV DO NOT SCALE FROM THIS PRINT NOTES: ANY CHANGES MADE TO THIS PRINT MUST ALSO BE MADE TO THE SFC PRINT 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: .5 LB. SFM-1XX-XX-XXX-D-XXX C 3. COPLANARITY: .004[0.10] = POS 05 THRU 26 .006[0.15] = POS 27 THRU 50 No OF POSITIONS 4. TUBE ALL POSITIONS. PARTS TO BE TUBED WITH NOTCH GOING WITH ARROW. ALL POSITIONS AVAILABLE 5. PINS CAN BE ORIENTED IN ANY DIRECTION; -02 THRU -50 BOTH ROWS MUST FACE SAME WAY. (USE BODY: SFM-XX-D-XX-X) 6. SEE NOTCH FOR PROPER ORIENTATION. C 7. MAXIMUM PIN HEIGHT VARIATION: .003[0.08] FROM PIN TO PIN AND ROW TO ROW, MUST BE MEASURED BETWEEN ADJACENT PINS. LEAD STYLE 8. DUE TO HIGH AMOUNT OF INSERTION FORCE -01: THROUGH HOLE NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH (USE CONTACT: C-44-01-XXX) AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL (SEE FIG 1, SHT 1) PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. -02: SURFACE MOUNT 9. DIMENSION TO BE MEASURED AT BEND. (USE CONTACT: C-44-02-XXX) 10. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES (SEE FIG 2, SHT 2) MAY BE PACKAGED ACCORDING TO THE SAMTEC -03: STRAIGHT MODIFIED PACKAGING EFFICIENCY STANDARDS (SPES) FOUND (USE CONTACT: C-44-03-XXX) ON WWW.SAMTEC.COM. (SEE FIG 1, SHT 1) 11.-FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY -L1: THROUGH HOLE (LOW INSERTION) PER REEL, BASED ON OPTIONS SELECTED. (USE CONTACT: C-61-01-XXX) 12. LOAD VISION TRAYS WITH PIN #1 OPPOSITE STANDARD (SEE FIG 1, SHT 1) AWAY FROM THE TERMINAL INDICATOR SIDE OF TRAY. -L2: SURFACE MOUNT (LOW INSERTION) (USE CONTACT: C-61-02-XXX) *DIMENSIONS N/A FOR -N OPTION (SEE FIG 2, SHT 2) *.145 3.68 REF -L3: STRAIGHT MODIFIED (LOW INSERTION) (USE CONTACT: C-61-03-XXX) *.020 0.51 REF .120 3.05 REF (SEE FIG 1, SHT 1) .050 1.27 -T1: THROUGH HOLE (PHOS BRONZE) *.080 2.03 REF 02 (USE CONTACT: C-119-01-XXX) REF (SEE FIG 1, SHT 1) -T2: SURFACE MOUNT (PHOS BRONZE) CL (USE CONTACT: C-119-02-XXX) (SEE FIG 2, SHT 2) OPTIONS (LEAVE BLANK FOR STANDARD AND USE SFM-XX-D) -N: NO POLARIZATION NOTCH (USE SFM-XX-D-XX-N) -A: ALIGNMENT PIN (USE SFM-XX-D-A-X) (SEE FIG 4, SHT 2) -LC: LOCKING CLIP (SEE FIG 6, SHT 3 & NOTE 8) (AVAILABLE ON ALL LEADS) -P: PICK AND PLACE PAD (SEE FIG 5, SHT 2) (AVAILABLE ON 5 THRU 50 POSITION ONLY) -TR: TAPE & REEL (SEE SHT 4) (NOT AVAILABLE WITH -DS OPTION) (SEE NOTE 10) -K: POLYIMIDE FILM PAD (.005[0.13] THICKNESS) (SEE FIG 3, SHT 2) (USE K-DOT-.157-.250-.005) -SN: SOLDER NAIL FOR .062 BOARD (SFM-XX-D-SN AND WT-27-01-T) (AVAILABLE WITH LEAD STYLE -02, -L2 & -T2) (NOT AVAILABLE WITH -A & -LC) -SN2: SOLDER NAIL FOR .093 BOARD (SFM-XX-D-SN AND WT-27-02-T) (AVAILABLE WITH LEAD STYLE -02, -L2 & -T2) (NOT AVAILABLE WITH -A & -LC) -DS: DUAL SCREW DOWN FOR .062 BOARD (SEE FIG 8, SHT 3) (ONLY AVAILABLE WITH -01, -02 AND -03 LEAD STYLE)(NOT AVAILABLE WITH OPTIONS -N, -A, -LC, -P, -TR, -K, -SN AND SN2), (USES SFM-XX-D-DS, CPS-RR-XX-XX-X, ACCRT-01 AND WT-27-XX-T ALWAYS FILLED) -FR: FULL REEL QTY. TAPE & REEL (NOT AVAILABLE WITH -DS OPTION) (SEE NOTE 11) 01 BODY SPECIFICATION -D: DOUBLE ROW .050 1.27 REF PLATING SPECIFICATION -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, (No OF POS x .050[1.27]) + .015[0.38] REF MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, (No OF POS x .050[1.27]) + .155[3.94] REF SFM-XX-D-LC-X MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, C-XX-01-XXX 3µ" GOLD ON TAIL (SEE NOTE 5) -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, .180 4.57 REF MATTE TIN ON TAIL .015 0.38 REF -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10+/-5%) TAIL (ONLY AVAILABLE ON -02 OR -L2 LEADSTYLES) "A" C CL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, (SEE TABLE 1) MATTE TIN ON TAIL 2 MAX SWAY -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, (EITHER DIRECTION) MATTE TIN ON TAIL "B" REF -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, .050 1.27 C MATTE TIN ON TAIL .005 0.13 REF (NO OF POS x .050[1.27]) - .050[1.27] REF CL "A" CL .110 2.79 REF "A" 1 MAX SWAY (EITHER DIRECTION) SECTION "A"-"A" C FIG 1 THROUGH HOLE/STRAIGHT MODIFIED UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 INSULATOR: LCP UL 94V-O, COLOR: BLACK CONTACT: TIGER EYE: BeCu TIGER EYE LITE: PHOSPHOR BRONZE F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 1 OF 4 "R" (SEE NOTE) REVISION DV "S" C (SEE NOTE) (No OF POS x .050[1.27]) - .050[1.27] REF (TOL ACCUM ±.005[0.13] OVER 50 POS) C-XX-02-XXX C +.003 +0.08 .190 - .007 4.83 - 0.18 (SEE NOTE 9) 02 IN-PROCESS 01 C 3 MAX SWAY (EITHER DIRECTION) -X2 FIG 3 -K: POLYIMIDE FILM PAD (SAME AS FIG 1, DIFFERENT AS SHOWN) FOR HAND FILL ONLY NOTE: DIMENSION APPLIES PRIOR TO RE-PRESS, SEE SECTION "B"-"B" FOR FINISHED DIMENSION NOTE: "R" = USED MEASURED DIMENSION REF "S" = {("R" - .1575[4.000])/2}±.020[0.51] SFM-XX-D-LC-X "B" +.002 +0.051 C .185 - .005 4.70 - 0.127 (SEE NOTES 7 & 9) "B" .190 4.83 .1575±.0050 4.000±0.127 .019±.020 0.48±0.51 SEE NOTE 7 FIG 2 4° SEE NOTE 3 SEE NOTE 7 .161 4.09 REF SEE NOTE 2° SECTION "B"-"B" -X2: SURFACE MOUNT (SAME AS FIG 1, DIFFERENT AS SHOWN) .394 10.01 REF "A"±.010[0.25] (SEE TABLE 2) .225 5.72 REF (NO. OF POS x .050[1.27]) + .125[3.18] REF PPP-02 .062 1.57 SFM-XX-D-A-X .050 1.27 REF FIG 5 .050 1.27 REF R REF (NO. OF POS x .050[1.27]) + .075[1.91] REF FIG 4 -A: ALIGNMENT PIN (SAME AS FIG 1, DIFFERENT AS SHOWN) -P: PICK AND PLACE PAD (PAD TO BE ORIENTED A SHOWN FOR 5-12 POSITION PARTS) (FOR 13-50 POSITION PARTS, PAD MAY BE ORIENTED IN EITHER DIRECTION) (SAME AS FIG 1, DIFFERENT AS SHOWN) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 2 OF 4 REVISION DV SFM-XX-D-LC-X (NO OF POS x .050[1.27] + .360[9.14] C .218 5.52 REF .065 1.65 .056 1.42 REF 2 MAX SWAY (EITHER DIRECTION) (NO OF POS x .050[1.27] + .075[1.91] REF 02 2 MAX SWAY LC-05-TM (EITHER DIRECTION) .010 0.25 REF 01 FIG 6 -LC: LOCKING CLIP (SAME AS FIG 1, DIFFERENT AS SHOWN) (AVAILABLE IN ALL LEADS) CPS-RR-M2-01-X 'E' SFM-XX-D-DS .070 1.78 REF C .145 3.68 .335 8.50 REF "D" C WT-27-XX-T (NO OF POS x .050[1.27] + .600[15.24] REF .114 2.90 REF .012 0.30 REF ACCRT-01 DETAIL 'E' SCALE 6 : 1 (NO OF POS x .050[1.27] + .185[4.70] REF SFM-XX-D-SN "C" C FLUSH TO .005[0.13] ABOVE FIG 8 -DS: DUAL SCREW DOWN (SAME AS FIG 2, DIFFERENT AS SHOWN) "C" REF WT-27-XX-T * "C" (NO OF POS x .050[1.27] + .085[2.16] REF .026 0.66 REF 2 MAX SWAY (EITHER DIRECTION) SECTION "C"-"C" PROPRIETARY NOTE DO NOT SCALE DRAWING FIG 7 -SNX: SOLDER NAIL (SAME AS FIG 1, DIFFERENT AS SHOWN) F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 3 OF 4 PT-1-24-13-09 REVISION DV .630 16.00 PT-SFM004-X1-X3-D PT-SFM004-X1-X3-D PT-1-24-01-60 2.205 56.00 "D" "D" UNWINDING DIRECTION *FOR MACHINE LOADING OF TUBES FOR PARTS W/O PADS USE PT-1-24-14-09, TP-24-02 5 POS -01 AND -03 LEAD STYLES MAY BE TUBED USING PT-1-24-15-09, TP-24-02 2 POS -X1 STYLE TO BE TUBED IN PT-1-24-15-09 (SEE NOTE 6) PACKAGING VIEW PACKAGE PARTS IN TUBES AS SHOWN (SEE NOTE 4) SECTION "D"-"D" SCALE 2 : 1 PACKAGING VIEW -TR: TAPE AND REEL F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 4 OF 4
SFM-120-01-L-D
1. 物料型号:文档中没有明确指出具体的物料型号,但提到了SFM-1XX-XX-XXX-D-XXX作为参考型号。
2. 器件简介:文档描述了一种双排插座条,具有多种选项和配置,适用于不同的应用需求。
3. 引脚分配:文档中提到了不同位置的引脚分配,例如,奇数位置和偶数位置的引脚长度和宽度有所不同。
4. 参数特性:文档详细列出了各种参数,如引脚长度、宽度、间距、插入力、共面性等。
5. 功能详解:文档提供了关于如何使用不同选项(如无极性槽、对齐销、锁定夹、拾取放置垫、胶带和卷轴包装等)的说明。
6. 应用信息:文档中提到了该插座条适用于多种应用,包括自动放置和手动放置,并强调了某些选项不兼容自动放置。
7. 封装信息:文档提供了关于封装的详细信息,包括尾长、尾宽、引脚样式和包装管等。
SFM-120-01-L-D 价格&库存
很抱歉,暂时无法提供与“SFM-120-01-L-D”相匹配的价格&库存,您可以联系我们找货
SFM-120-01-L-D
    • 1+37.82160
    • 10+36.89280
    • 38+36.26640
    库存:14
