MPSC-01-24-01-01-01-L-RA-LC
    SAMTEC(申泰)
    VERTICALMINI-POWERW/SIGNALSOC
MPSC-01-24-01-01-01-L-RA-LC 数据手册
HIGH-POWER SYSTEMS 20-60 A FEATURES & BENEFITS p er bla de • Current Rating: 23 A - 58.7 A per power blade • 3.81 mm, 5.00 mm and 6.35 mm pitch • Dual blade contact system • Power only or power/signal combinations available • Right-angle and vertical orientations • Rugged screw down and locking clip options • Discrete wire cable assembly with 10-16 AWG wire • “Hinged” for unique mating in any orientation from 0° to 90° and space confined applications Selectively loading contacts achieves customer specific creepage and clearance requrements. Hermaphroditic options available (samtec.com?MPPT) Hinging options available (samtec.com?FMPT samtec.com?FMPS) KEY SPECIFICATIONS PET/PES PETC/PESC MPT/MPS MPTC/MPSC UPT/UPS FMPT/ FMPS UPPT MPPT (6.35 mm) .250" (6.35 mm) .250" (pwr) (2.54 mm) .100" (sig) (5.00 mm) .1969" (5.00 mm) .197" (pwr) (2.00 mm) .079" (sig) (3.81 mm) .150" (5.00 mm) .1969" (3.81 mm) .150" (5.00 mm) .1969" CCC (1 PIN)* 58.7 A 31.4 A 28.8 A 28.8 A 23 A 26.7 A 21.4 A 23.3 A CCC (2 PINS)* 48.5 A 28.0 A 24.7 A 24.7 A 18.6 A 22.9 A 19.8 A 20.5 A CCC (3 PINS)* 41.1 A 24.4 A 24.1 A 24.1 A 17.5 A 19.1 A 17.1 A 19.4 A CREEPAGE (3.66 mm) .144" (3.66 mm) .144" (2.86 mm) .113" (2.86 mm) .113" (5.5 mm) .217" (6.53 mm) .257" (1.91 mm) .075" (2.95 mm) .116" CLEARANCE (3.31 mm) .130" (3.31 mm) .130" (2.71 mm) .106" (2.71 mm) .106" (1.51 mm) .059" (2.71 mm) .106" (1.51 mm) .059" (2.71 mm) .106" VAC 725 VAC Signal: 450 VAC Power: 650 VAC 575 VAC 250 VAC 438 VAC 525 VAC 425 VAC 600 VAC VDC 1025 VDC Signal: 636 VDC Power: 919 VDC 812 VDC 354 VDC 620 VDC 742 VDC 600 VDC 848 VDC 100 100 100 100 25 100 100 100 SERIES PITCH CYCLES F-221 samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (5.00 mm) .197"(PWR) / (2.00 mm) .079"(SIG) • 30 A SIGNAL/POWER COMBO SYSTEMS - SERIES POWER PINS MPTC Per end MPSC –02 Terminal - –01 Socket - SIGNAL PINS POWER PINS –16 Per end –40 –02 - –01 –24 –80 MPTC LEAD STYLE –6.30 = (6.30 mm) 0.248" (MPTC only) –7.70 = (7.70 mm) 0.303" (MPSC only) - TAIL LENGTH - –01 OTHER OPTION –L = Use with (1.60 mm) .062" Thick PCB –LC = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Power & Signal) –03 = Use with (2.36 mm) .093" Thick PCB = Locking Clip (Manual placement required) –T = Matte tin on contact and tail (power), Gold on contact, Matte tin on tail (Signal) A Board Mates: MPSC Cable Mates: MPCC -V- PLATING OPTION (12.45) .490 (11.38) .448 POWER PINS/ENDS MPSC A Board Mates: MPTC (10.16) .400 A 16 24 40 80 SIGNAL SIGNAL SIGNAL SIGNAL PINS PINS PINS PINS –01 (27.44) 1.081 (31.45) 1.238 (39.44) 1.553 (59.44) 2.340 –02 (37.44) 1.474 (41.45) 1.632 (49.44) 1.946 (69.44) 2.734 View complete specifications at: samtec.com?MPTC & samtec.com?MPSC SERIES - POWER PINS MPTC Per end MPSC –02 Terminal Socket –01 - SIGNAL PINS –24 –80 - POWER PINS TAIL LENGTH - –01 Per end = Use with (1.60 mm) .062" Thick PCB –01 –02 MPTC-RA Board Mates: MPSC Cable Mates: MPCC - 01 - –03 = Use with (2.36 mm) .093" Thick PCB A (15.70) .618 - RA - –L OTHER OPTION –SD or –LC is a required callout = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Power & Signal) –SD = Screw Down –T = Matte Tin on contact and tail (power), Gold on contact, Matte tin on tail (Signal) POWER PINS/ENDS (12.45) .490 –LC = Locking Clip (Manual placement required) A 24 SIGNAL PINS 80 SIGNAL PINS –01 (35.25) 1.388 (63.25) 2.490 –02 (45.25) 1.781 (73.25) 2.884 A MPSC-RA Board Mates: MPTC PLATING OPTION (15.06) .593 POWER PINS/ENDS (10.16) .400 A 24 SIGNAL PINS 80 SIGNAL PINS –01 (36.25) 1.438 (64.25) 2.540 –02 (46.25) 1.831 (74.25) 2.934 View complete specifications at: samtec.com?MPTC & samtec.com?MPSC Note: Some lengths, styles and options are non-standard, non-returnable samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
1. 物料型号:文档中提到了多种系列的物料型号,例如PET/PES、PETC/PESC、MPT/MPS、MPTC/MPSC、UPT/UPS、FMPT/FMPS、UPPT和MPPT。
2. 器件简介:介绍了一种名为“POWER STRIP”的高功率系统,具有23 A至58.7 A的电流等级,3.81 mm、5.00 mm和6.35 mm的间距,双刀片接触系统,支持直角和垂直方向,以及坚固的螺钉固定和锁定夹选项。
3. 引脚分配:文档提供了不同系列的引脚分配信息,包括信号和电源引脚的数量,例如MPTC系列有16、24、40和80引脚/端的配置。
4. 参数特性:列出了关键规格,如每个引脚的电流承载能力(CCC),爬电距离和间隙,以及电压AC和DC的耐压值。
5. 功能详解:文档强调了“POWER STRIP”系统的功能特点,包括可选择的接触负载以满足特定的爬电和间隙要求,以及不同方向和空间受限应用中的“铰链”连接选项。
6. 应用信息:虽然文档没有直接提供应用案例,但从其特点和规格可以推断,该系统适用于需要高功率传输和信号组合的高功率系统。
7. 封装信息:提供了不同系列的封装选项,包括尾长、端接方式、镀层选项等详细信息。
MPSC-01-24-01-01-01-L-RA-LC 价格&库存
很抱歉,暂时无法提供与“MPSC-01-24-01-01-01-L-RA-LC”相匹配的价格&库存,您可以联系我们找货
  • 1+63.456891+8.22074
    • 1+65.63160
    • 10+63.39600
    库存:10
