PESC-02-40-02-01-S-VT-LC 数据手册
HIGH-POWER SYSTEMS
20-60 A
FEATURES & BENEFITS
p er bla de
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assembly with 10-16 AWG wire
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
Selectively loading contacts achieves
customer specific creepage and
clearance requrements.
Hermaphroditic
options available
(samtec.com?MPPT)
Hinging options available
(samtec.com?FMPT
samtec.com?FMPS)
KEY SPECIFICATIONS
PET/PES
PETC/PESC
MPT/MPS
MPTC/MPSC
UPT/UPS
FMPT/
FMPS
UPPT
MPPT
(6.35 mm)
.250"
(6.35 mm) .250" (pwr)
(2.54 mm) .100" (sig)
(5.00 mm)
.1969"
(5.00 mm) .197" (pwr)
(2.00 mm) .079" (sig)
(3.81 mm)
.150"
(5.00 mm)
.1969"
(3.81 mm)
.150"
(5.00 mm)
.1969"
CCC
(1 PIN)*
58.7 A
31.4 A
28.8 A
28.8 A
23 A
26.7 A
21.4 A
23.3 A
CCC
(2 PINS)*
48.5 A
28.0 A
24.7 A
24.7 A
18.6 A
22.9 A
19.8 A
20.5 A
CCC
(3 PINS)*
41.1 A
24.4 A
24.1 A
24.1 A
17.5 A
19.1 A
17.1 A
19.4 A
CREEPAGE
(3.66 mm)
.144"
(3.66 mm) .144"
(2.86 mm)
.113"
(2.86 mm) .113"
(5.5 mm)
.217"
(6.53 mm)
.257"
(1.91 mm)
.075"
(2.95 mm)
.116"
CLEARANCE
(3.31 mm)
.130"
(3.31 mm) .130"
(2.71 mm)
.106"
(2.71 mm) .106"
(1.51 mm)
.059"
(2.71 mm)
.106"
(1.51 mm)
.059"
(2.71 mm)
.106"
VAC
725 VAC
Signal: 450 VAC
Power: 650 VAC
575 VAC
250 VAC
438 VAC
525 VAC
425 VAC
600 VAC
VDC
1025 VDC
Signal: 636 VDC
Power: 919 VDC
812 VDC
354 VDC
620 VDC
742 VDC
600 VDC
848 VDC
100
100
100
100
25
100
100
100
SERIES
PITCH
CYCLES
F-221
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(6.35 mm) .250" PITCH • 40 A HIGH-POWER SYSTEM
SERIES
PET
NO. PINS
PER ROW
–02, –04,
–06, –08
Terminal
PES
LEAD
STYLE
–01
= Use with (1.60 mm) .062" Thick PCB
–02
= Use with (3.18 mm) .125" Thick PCB
Socket
PET
PLATING
OPTION
TAIL OPTION
–L
OTHER OPTION
–VT
= 10 µ" (0.25 µm) Gold on
contact, Matte Tin on tail
–SD
= Vertical
= Screw Down
(Right-angle only)
– RA
–T
= Right-angle
(Screw Down
option required)
= Matte Tin on tail
No. of positions x (6.35) .250 + (16.51) .650
Board Mates:
PES
Cable Mates:
PESS
(14.62)
.575
(14.50)
.571
(23.50) .925
-VT
PES
-RA-SD
Board Mates:
PET
(20.80) .819
(12.64)
.497
(12.00)
.472
-VT
-RA-SD
View complete specifications at: samtec.com?PET & samtec.com?PES
SERIES
PETC
Terminal
PESC
Socket
POWER
PINS
–01
–02
–04
SIGNAL
PINS
–12
–40
POWER
PINS
–01
–02
–04
- 01 -
PLATING OPTION
–L
–VT
= 10 µ" (0.25 µm)
Gold on contact, Matte Tin on tail
= Vertical
–T
= Right-angle
= Matte Tin
OTHER OPTION
–SD
= Screw Down
(Right-angle only)
– RA
–LC
= Locking Clip
(Manual placement required)
A
PETC
Board Mates:
PESC
(14.50)
.571
(14.62)
.575
PESC
TAIL
A
Board Mates:
PETC
A
POWER
PINS/ENDS 12 SIGNAL 40 SIGNAL
PINS
PINS
–01
(39.37) 1.550
(57.15) 2.250
–02
(52.07) 2.050
(69.85) 2.750
–04
(77.47) 3.050
(95.25) 3.750
(12.00)
.472
(12.64)
.497
View complete specifications at: samtec.com?PETC & samtec.com?PESC
Note:
Some lengths, styles and
options are non-standard,
non-returnable
F-221
PESC-02-40-02-01-S-VT-LC 价格&库存
很抱歉,暂时无法提供与“PESC-02-40-02-01-S-VT-LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+177.552101+22.95050
- 国内价格 香港价格
- 1+159.122721+20.56830
- 24+135.5076424+17.51580
- 48+123.0560548+15.90630
- 120+107.34129120+13.87500
- 264+97.20827264+12.56520
- 504+90.76779504+11.73270
- 1008+90.681921008+11.72160
